04-13-2015, 09:11 PM | #90 |
Rep 1,035
04-13-2015, 09:12 PM | #91 | |
Rep 498
04-13-2015, 09:20 PM | #92 |
Rep 1,035
Those holes might already be there... Just pop under there and take a peek. Mine were already there. Four on each side...
Btw.. if they are there, it will take you 15 mins to install this thing once the car is jacked up and 5 mins to de-install back to OEM... and no one will be the wiser |
04-13-2015, 09:30 PM | #93 |
Rep 1,035
Here is the secret weapon... these and a pair of needle nose pliers. Don't make me send you 8 of these Bobby!!! Actually, the pliers are only used to take them off. You can put them ON with your fingers
1. push rivet into hole 2. push pin into rivet 3. profit!! Last edited by squidlyboy; 04-13-2015 at 09:36 PM.. |
04-13-2015, 11:49 PM | #94 | |
Rep 498
I have to decide whether it'll look good on a car of stock height. Also need to compare the ground clearance to my '04 Z4 which is actually pretty low. Anyone have ground clearance in inches on stock height? |
05-16-2015, 12:06 PM | #95 | |
Rep 1,739
Thanks again for helping in these DIY posts and in PM.
So I got my car up enough to see all holes clearly. - I don't have the #1 holes. This must get drilled when the OEM lip is installed. I'll have to drill them. - Holes 2 and 3 have existing rivets and they will go through the inner bracket of the lip. - Hole 4 is there as well with another rivet. But the rivet will NOT go through the inner lip bracket...just through the lip itself, correct? [Nevermind, I saw other pics you posted and this is correct] - There is another hole in the bracket that sits roughly between hole 3 and hole 4. There is no matching hole in the bumper and the hole in the bracket gets covered by the lip. I assume this doesn't get used? [Nevermind, I saw other pics you posted and this is correct.] - There are three other holes in the bracket, not in the same line as the others. These also would get covered by the lip. I assume these are not used either? If they were, there is no way one could insert the rivets unless the bracket was attached to car first, THEN the lip snapped on. [Nevermind, I saw other pics you posted and this is correct.] - There are no holes in the middle of the bumper for the middle post of the lip/bracket. I'll have to drill those too. Quote:
05-16-2015, 07:00 PM | #96 | ||
Rep 1,035
And as you noticed, the order of doing things would have to be done differently. It would be: 1) Drill these extra bracket holes in the bumper 2) Attach rivets to these extra bracket holes FIRST to pre-secure bracket-only to bumper 3) THEN attach the 10 c-clips/screws to secure the Lip to the already installed Adapter. So you would have to do these 10 c-clips/screws upside down under the car instead of in your living room as pre-work. That makes the install a little more difficult, but not much more... 4) Attach rivets to #1, #2, #3, #4 (for both sides, so 8 total) as usual to attach Lip/Adapter assembly to bumper 5) Screw 2 center screws through the Lip/Adapter assembly center to bumper The difference in doing so would add 8 additional rivets to secure the bracket itself to the bumper. A little overkill, and thats probably why the factory/dealership doesn't use these extra holes as well. The 8 that are currently used are plenty IMO. The Lip is not going anywhere. I was planning to add this to the DIY as an option, but i needed a little break from all that writing ... |
05-27-2020, 12:49 AM | #97 | |
Rep 3
03-20-2021, 09:04 AM | #98 |
Rep 1
I drive in Manitoba, Canada, and the roads are not very good here. After driving 43000km I am amazed by the sturdiness of the M Performance splitter cause it's taking a beating here. Yesterday again while driving in a shitty street in Winnipeg it hit the ground quite strongly I honestly thought twas' broken, but no as you can see on the pictures lol.
Still, anticipating it'll happen soon enough, and not wanting to pay the BMW price. What carbon fiber splitter would you recommand ? I found those 2 online the price is fair and they look good : https://www.********.com/184/1/0/73/...front-lip.html https://x-ph.com/xph-performance-loo...-f36-4-series/ Thanks !!! |
