01-06-2014, 05:42 AM | #155 |
Rep 458
Thanks Shawn. That makes a lot of sense.
I have tried to VO code the HBT twice and has mentioned above it fails. I don't know if this is because the VIN doesn't match because I don't have the emulator yet.? |
01-06-2014, 06:10 AM | #156 |
Rep 41,104
Ahh, ok. I forgot.
01-06-2014, 07:57 AM | #157 |
Rep 458
Do you think it will work with the emulator (bimmertech)?
Does that work two way? Ie fools the NBT into thinking the car is the same VIN and the other way around? |
01-06-2014, 08:03 AM | #158 |
Rep 41,104
People code with Emulators, so I know that will work. What I don;t know right now for sure is if your coding issue is due to the lack of the emulator. Again, no point in speculating on any of this stuff.
01-06-2014, 10:26 AM | #159 |
Rep 1,982
Drives: 2020 G20 320i M Sport
Have you tried VO coding it with a different build date? It didn't work for me when I used 07/12 but when I used 11/12 it changed the language from German to English, and it change the vehicle profile from F31 back to F30.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
01-06-2014, 11:02 AM | #160 | |
Rep 458
We're you using and Emulator when it worked or were the Vins different? |
01-06-2014, 12:14 PM | #161 | |
Rep 1,982
I think you might have to go with an older build date since that head unit is older than your car. Try 11/12 because that's when NBT was first rolled out in Europe for the F30. It could be that the software on that NBT is not new enough for you to VO code with the 12/13 build date.
01-06-2014, 01:24 PM | #162 |
Rep 458
That worries me as there may be other options on the car that rely upon my later build date that I would screw up by setting it backwards. Also, if it was an incompatibility between the deployed NBT and the build date, wouldn't the calculate FP throw an error?
How do I go about updating the software on the NBT to a later version. That may work better. Last edited by steddyman; 01-06-2014 at 01:32 PM.. |
01-06-2014, 05:07 PM | #163 |
Rep 458
Just looking at the list of options on my existing VIN and the one on the donor VIN. Could a mismatch here cause problems for me?
For example I haven't added the following options which show on the VIN for the NBT: 612, 614, 615, 616, 6AA, 6AB, 6NL I have the following options set on my FA: 609 (added), 654, 6NS (changed from 6NL) 654 is the DAB tuner, which of course this model of NBT does not have. Should I be adding all the above options to my FA and removing 654? |
01-06-2014, 07:35 PM | #164 | |
Rep 41,104
It does matter though what was in the Donor's VO as that is what is currently applied to NBT. If their exists an incompatibility with its current coding and your car's hardware and other ECU's coding, there will be issues. You really need to let it rest for now until your emulator arrives, and you can apply the proper coding, and then assess what you have and what if anything isn't working as it should be.
01-06-2014, 08:10 PM | #165 | |
Rep 1,982
Is your vehicle really a 12/13 production? It could also be that your version of the psdzdata files are not new enough to VO code that far. I'm currently using 51.1 and it still won't let me VO code my HU_NBT with 09/13 which was the donor vehicle's build date. The furthest I can go is 07/13.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 01-06-2014 at 08:16 PM.. |
01-07-2014, 01:33 AM | #166 | |
Rep 458
Aritaurus has stated that he could VO code his head unit with out the emulator installed even though it had a different VIN so I don't think that is the problem. The fact my VO has DAB specified will surely be trying to enable that on the NBT when I VO code it. If that is the case then won't it fail as the manufacturing date and region of the done NBT means it doesn't have the necessary hardware to take it. |
01-07-2014, 01:36 AM | #167 | |
Rep 458
I can VO code other options on the car, which makes me think the data is compatible. The build date of the NBT is late 2012. |
01-07-2014, 10:53 AM | #168 | |
Rep 1,982
There's really no harm in using the older build date worse case scenario is that you will get an error and the settings won't propagate. Just make sure you go to options and uncheck "Write to VCM after TAL execution" if you don't, this will write the modified VO to your car which you do not want. You're really only using the modified VO as a reference point to program the head unit only. If you don't write the VO to the car, it won't affect any of your other ECU's. At first, I tried 07/12 and that did not work, then went with 11/12 and and the settings propagated. Later on, I changed it to 07/13 so I could get the latest idrive features. I also added 614, 615, 6AL, 6NK to my VO and it all coded fine enough though I should be using 6AM, 6AK, 6AC, 6NS since the head unit is from a 2014 model. In your case, I would VO code HU_NBT with the 11/12 build date and use 6AL, 614,615, 6NK since the head unit is from a early 2013 build. Try not to use the new option codes as those are usually specific to 2014 models. |
01-07-2014, 02:49 PM | #169 |
Rep 458
YES!
I cracked it. My theory was right, option code 654 was preventing the NBT from VO coding. I removed it from the FA, updated the car, then the VO coding of both the KOMBI and NBT completed without errors. I now have everything working, including sound, except for Navigation. My Emulator should arrive tomorrow and I'll fit it in the next couple of days. Thanks for all your help Shawn and Aritaurus. |
01-07-2014, 03:15 PM | #170 | |
Rep 41,104
01-08-2014, 04:15 AM | #171 |
Rep 1,470
Well done Steddyman! This thread has been compulsive viewing over the last few days following your trials and tribulations! I take my hat off to you, excellent work.
Also great to see all the help you've been getting from shawnsheridan and Aritaurus. What a fantastic community... |
01-08-2014, 02:36 PM | #173 |
Rep 458
Well. I still have one odd problem that perhaps somebody who has gone from Entry to NBT can help with.
For some reason when I swap to the Nav iDrive controller (not touch) it is no longer recognised. I have tried VO coding it previously but it always failed with a timeout like the controller wasn't there. I put it down to a faulty controller so got a replacement one today from the original reseller (still have the old one). This one is exactly the same, still won't work so I doubt it is a second faulty iDrive controller. Anybody got any ideas on what I could do to make this work? Thanks |
01-08-2014, 03:31 PM | #174 |
Rep 458
I noticed this entry on the options list, that is not on my car. But it does not appear to be on the options list of the donor car either. Does anyone have this code on their FA?
S8S8A COUNTRY-SPECIFIC NAVIGATION CONTROL Also, I checked the VIN of a car within five of mine, which is another UK 330d but with Pro Nav with all the standard UK services. This is of course the NBT with touch in the UK, but should I be coding my car with these codes? S609A - Navigation system Professional S654A - DAB-Tuner (I know this one won't work) S698A - Area-Code 2 for DVD S6ACA - Intelligent emergency call S6AEA - TeleServices S6AKA - ConnectedDrive Services S6AMA - Real Time Traffic Information S6ANA - Concierge service S6APA - Remote Services S6NHA - Hands-free with USB interface (I changed this to 6NS) S6NRA - Apps (this isn't standard so I would need an FSC code for this) Last edited by steddyman; 01-08-2014 at 04:14 PM.. |
01-09-2014, 05:15 AM | #175 |
Rep 41,104
First, make sure all of these NBT FDL's are set to nicht_aktiv:
ZBE_TOUCH ZBE_TOUCH_BROWSER ZBE_TOUCH_INTERACTIVE_MAP ZBE_TOUCH_SPELLER If it sill does not work, disconnect the emulator, and see if it works then. And yes, I know the old controller works fine with the emulator.
