BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Video + PC Gaming / Computing > Post Up Your Rig!
Studio RSR
      07-29-2014, 06:31 PM   #133
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25084
Drives: '22 Chalk Gray Porsche C2S
Originally Posted by Wraith. View Post
Built in fall 2011:
I7 990X 4.3 Ghz(under water)
E770-A1 Classified 3 (under water)
(3) GTX-580 Classified HC 3GB Tri-Sli (under water)
12GB Corsair Dominator GT (under water)
Asus Xonar Xense/PC350
(2) 120 GB Intel X-25 SSD
1500 Watt Silverstone ST1500
3 independent water cooling loops
Asus VG278
CM Cosmos Black Label case #32
Wow! Looks like the inside of the Matrix (..in Zion). Love it!
      07-29-2014, 06:34 PM   #134
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25084
Originally Posted by dearwinter View Post
Built during the Fall of 2012.
Here are some system specs:
CPU: Core i7 3770K 3.5GHz (Overclocked to 4.8 GHz)
Motherboard: Asus Maximus V Extreme
Memory: 16 GB G. Skill
Graphics Cards: GTX 480s (2) 700 MHz (Overclocked to 840 MHz)
Power Supply: Corsair 1000 Watt
Hard Drives: 128 GB SSD, 500 GB Caviar Blue, 640 GB Caviar Black, 1 TB Caviar Green
Water Cooling Components:
Triple Radiator
Single Radiator
440 ML Water Reservoir
Water Pump (1200 liters per hour)
Nickel Plated CPU Block
Nickel Plated GPU Blocks (2)
Nickel Plated Compression Fittings
1/2” Inlet Diameter Tubing
I love this set-up too. Damn!
      08-08-2014, 08:49 AM   #135
Wild_Will
Wild_Will's Avatar
Drives: 2020 Hurucan Evo
Ive been building for about 10 years now -
Ive since made a few adjustments as far as wire tucking,add a Panasonic Slim Slot Loading Blu Ray Drive,changed from a 780 Lighting to a Asus Mars 760.
Case:Silverstone FT03
Mobo:Asus Maximus Gene VI
CPU:Intel 4770K
Memory:Crucial Ballistic Tactical Tracer 16GB at 1866MHz
GPU:Asus Mars 760
PSU:Silverstone Strider Gold Modular 850 Watt
Fans:Noiseblocker PL-2 X3 120MM,Noiseblocker PL-1 X2 80mm
SSD:Intel 520 Series 240GB
HDD:WD Cavair Green 2TB
Optical Drive:Panasonic Slim Slot Loading Drive
Monitor:Asus ROG Swift 2560X1440 at 144hz
