08-18-2013, 03:34 AM | #4379 | |
Rep 3,225
All in the cheat sheet PEte. http://www.bimmerfest.com/forums/sho...d.php?t=676313 H |
08-18-2013, 04:05 AM | #4380 |
Rep 10
@shawnsheridan
i'm not sure how to read svt, i must go in expert mode ---> VCM-->VCM MASTER-->read SVT That's correct ? i know thats there a way for working offline with e-sys but don't know how to do sorry for the stupid questions Last edited by shinerune; 08-18-2013 at 04:19 AM.. |
08-18-2013, 04:21 AM | #4381 | |
Rep 40,752
It is Step 10 in the E-Sys - Getting Started Coding.pdf guide:
08-18-2013, 12:46 PM | #4384 |
Rep 40,752
Certainly you cannot code the car Offline, so define "use". What exactly is it you want to do Offline?
08-18-2013, 01:26 PM | #4386 |
Rep 40,752
Yes, this is simple. Read your SVT, then disconnect from car. Then open each CAFD (.ncd) file with FDL-Editor, makes the FDL Changes you want, and save them. Connect back to car, Activate FA, and FDL Code each ECU CAFD you modified. Make sure after you reconnect that you do not read SVT nor any ECU again before writing your coding changes, otherwise the read step will override the Offline changes you made.
08-18-2013, 02:03 PM | #4388 |
Rep 88
08-18-2013, 02:12 PM | #4390 |
Rep 40,752
This should be standard functionality with both CIC and NBT. No coding necessary.
08-18-2013, 02:12 PM | #4391 | |
Rep 40,752
For F30, I would assume the same, although someone with Kafas needs to confirm.
08-18-2013, 10:27 PM | #4392 |
Rep 304
Hey guys,
Anyone know how to enable the rear fog lights without having the headlights on ? My E90 was able to turn them on with only the angel eye/turn signal combo. Thanks ! |
08-19-2013, 04:39 PM | #4393 |
Rep 50
Hello,
I'm a happy owner of a 01 2013 535xiT with 6WB (Digital KOMBI), 5AG (line change assist), 8TH (speed limit info) and 5AC (auto-high beam) and NBT (thanks SergAA from Bimmerfest forum). I'm a beginner in coding but I'm trying to code LDW in my car using this: KAFAS: 3000, TLC_START_VERSION, default_on 3000, TLC_ON_OFF, aktiv 3000, SEND_MESSAGE_327, aktiv 3000, SEND_MESSAGE_345, aktiv 3006, ACTUATOR_ON_OFF, aktiv-> maybe the problen is here ERROR AFTER CODING HERE. KOMBI: 3003, TLC_VERBAUT, On_F10 3004, ST_TLC_TIMEOUT, aktiv 3004, ST_TLC_ALIVE, aktiv 3004, ST_TLC_APPL, aktiv 3003, HUD_TLC_ENABLE, aktiv HU_NBT: 3001, LANE_DEPARTURE_WARNING, aktiv SZL_LWS 3000, Lenkrad_Vibration, aktiv (enabled by default) FRM LIN_PUBU_TLC, aktiv And It's works perfect for 15 seconds and then I have this error LANE DEPARTURE WARNING FAILURE and stops working. Any ideas to fix that ? It seems this coding lines works well, including HUD display, for some people. Thanks. Last edited by 007bandido; 08-19-2013 at 04:46 PM.. |
08-20-2013, 01:51 AM | #4394 |
Rep 88
Hi,
does any one know if its possible to extend the NBT Welcome screen run time? I coded this, and it would be nice to actualy see it, when I open my car, by the time I get in, its gone Pete |
08-20-2013, 02:20 AM | #4395 | |
Rep 109
08-20-2013, 04:36 AM | #4396 |
Rep 3
Hola a todos, saludos desde espaņa.
Quisiera poder empezar a codificar mi nuevo F30 07/2013 320d y pido por favor saber donde conseguir el programa E-sys y los arhivos necesarios para codificar. jmhuesc@gmail.com Gracias. |
08-20-2013, 04:37 AM | #4397 |
Rep 3
Hi all, greetings from Spain.
I wish I could start coding my new F30 07/2013 320d and pray you know where to get the E-sys and private archives needed for encoding. jmhuesc@gmail.com Thank you. |
08-20-2013, 04:47 AM | #4399 | |
Rep 40,752
08-20-2013, 12:16 PM | #4400 |
Rep 88
