07-07-2013, 12:58 PM | #221 | ||
Rep 3,780
0-120 is a different race than a 60 mph roll. If one car is Xdrive, the other RWD, Xdrive has an advantage in 0-120, although the advantage/pendulum swings-the point where it reverses is 100% GUESS. Now a 60mph roll, Xdrive simply has no advantage as I said, these cars do not have the power to overcome traction at such a speed. So Xdrive is left with a weight penalty and slightly higher drivetrain loss and no traction advantage left. My car is not so much a comparison, but an example of when RWD traction is an issue and stock 275whp or as your brought up, tuned 350whp cars are not going to contend with traction issues at 60mph rolls. My car for example will require 700 or so hp to find traction issues at such a speed. If I had AWD and 700hp(say like a tuned GTR, but without the damn weight of a GTR lol), being able to plant 700hp from a roll would be a neat trick. Pretty much at a certain power level, or more accurately as you brought up-power to weight ratio, traction becomes an issue even from a roll. You could have a 750whp CTS-V that weights 4000lbs and have similar traction issues to a 2000lb Elise with half the power(other factors such as tires etc not withstanding).
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
07-07-2013, 02:32 PM | #222 | |
Rep 665
It also doesn't take more than common sense from those with experience driving high hp cars to know that a PPK tuned f30 335i isn't going to spin the wheels at a 100, 80, or even 60 mph roll. My F30 335i will be tuned this week and I'll be able to verify the obvious. |
07-07-2013, 02:37 PM | #223 | |
Rep 3,780
07-07-2013, 03:00 PM | #224 | |
Rep 665
07-07-2013, 03:05 PM | #225 | |
Rep 3,780
63.215mph. That is when it will happen.
07-07-2013, 03:33 PM | #227 | |
Rep 3,780
It's at what speed that is the question. You are talking about two otherwise identical cars. You are adding weight and you are slightly diminishing the power that reaches the ground due to higher losses of the Xdrive drivetrain. These are not opinions, I promise. BUT, those negatives are used as a positive thanks to the gains in traction utilized in slipper situations or in the dry at launch....but it's launch up to a certain speed. At a certain speed, that launch advantage is over, there is no traction to take advantage as you are already moving. Instead, the negtives are still with you, the 150-200lbs, the drivetrain loss. When already moving, two identical cars, adding weight and making less power to the wheels are never and have never been positive attributes. Power to weight ratio is one of the hallmarks that you just cannot get away from. Two identical cars, but one being heavier, is NEVER-EVER the faster car. Now if you throw traction into it from different drive wheels, then you can have the heavier car be faster due to traction. But only for so long. That is the key.
07-07-2013, 04:12 PM | #228 | |
Rep 1,656
I have because that is some thing that is important to me. Besides a slight room in rear seats the F30 335i has nothing to offer that is superior to the E9x 335i.
I would take a E92 335is over any F30 335i M sports on track and off track. The E92 335is offers greater overall performance and better driving dynamics than a F30 335i M sport. So if I was in a market I would buy that over the F30 335i M-sport and its lack of performance upgrade and inferior steering feel/feedback. So enjoy your F30 335i with inflated sticker price and no upgrade in performance as well as poor steering feel and feedback. I have enjoyed my E92 Cobb tuned 335i for over 4 years and will continue to do so. The current F30 335i offers no upgrade for me to desire it. Quote:
nickname"BAD 3",MHD E85 tune,RennArt catback non-resonated exhaust,VRSF Downpipes, VRSF 7"FMIC,VRSF stock side inlets,SSQV BOV,ECS CP,M-performance alcantara steering,retrofit M3 paddle shifters,Alpina B3 tranny flash,AFE power seal CAI,LED angels,ST Coilovers,M3 upper/lower control arms,E93 M3 Front Swaybar ,235/35/19x9 ,275/30/19x9.5. M sport bumpers, CF diffuser. When in doubt..flat out.
07-07-2013, 04:24 PM | #229 | |
Rep 3,780
Car makers bring out higher performing variants as a model line ramps up, to keep it fresh. The E92is(there is no such thing as an E90is sedan) came out years after the E92. It was the highest spec, highest performing, most expensive 3 series without stepping up to the M3. Now, in the E46, again, years after it was introduced, there was the ZHP, offered on coupe, vert and sedan, again bridging the gap a bit closer to the M3. But for the E9x, they kept it just for the coupe and vert. The F30 is a new model launch. So why compare a 2dr end of run performance variant to the sedan? To be a bit more fair, as I said, Canada for '14 will offer a top of the line MSport sedan with PPK, suspension, etc. That would be a bit more fair to compare and hopefully such a car makes it to the US. If not, all available parts are there, the car tested here with PPK shows the added power helps out...now imagine the suspension and other MP upgrades.
07-07-2013, 04:26 PM | #230 | |
Rep 397
Drives: 11 E90 M3 ZCP
07-07-2013, 04:52 PM | #231 | |
Rep 402
what is the weight difference between the AWD and the RWD?
07-07-2013, 04:58 PM | #232 |
Rep 397
Per BMWUSA:
335i xDrive: 3,710 lbs 335i RWD: 3,555 lbs Difference: 155 lbs |
07-07-2013, 04:58 PM | #233 |
Rep 3,780
The MSport in this test, 8spd auto Xdrive with 18" wheels:
3731 lb (53/47%) The MSport in the Habeous Popum Test, 8spd auto RWD 19" wheels(adds 13-15lbs vs 18" wheels) 3605lbs (51.5/48.5%) Now to be exact, if we subtract the 15lbs for the 19" wheels to equip the cars as closely as possible) that comes out to 141lbs. BMW sites have data as well, but they not get into specifics the way the mags do.
07-07-2013, 05:31 PM | #234 | |
Rep 402
Would be interesting to see what that 4% would mean in terms of real world performance. Audi S4 is 3900 Lbs ++ with AWD.
Kevin Quote:
07-07-2013, 06:18 PM | #235 |
Rep 3,780
When you go into a completely different car and drivetrain, it gets murky. The S4 is not offered in RWD to compare. The S4 has ALWAYS, back since the B5 days been heavier than a similar 3 series. The S4 is a bit different as it offers sports differentials that makes its AWD more of an aide than the 335. Only the X5/6M get the nifty AWD. The S4 is a bit more FWD in it's architecture, a S4 in FWD would not be a very good car lol.
07-08-2013, 08:21 AM | #236 |
Rep 3,619
Speaking of the S4 the results are in
http://m.motortrend.com/roadtests/sedans/1307_2013_audi_s4_first_test/ I don't know what to make of this review it seems lukewarm
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
07-08-2013, 09:12 AM | #237 | |
Rep 1,730
07-08-2013, 09:22 AM | #238 | |
Rep 3,780
07-08-2013, 09:34 AM | #239 | |
Rep 1,730
While the sport AT on the F30 is fantastic, it still has a torque converter. Even with brake torquing the crap out of it, you're still going to have loss, especially when shifting. I guess the new ZF8 on the 2014 will have more aggressive locking control, will be interesting to see how this feels on the road. |
07-08-2013, 09:41 AM | #240 | |
Rep 3,780
So that means the power to weight ratio is nearly identical even though the S4 weights nearly 300lbs more. So again, that means the 3.0T is making at least 25-30whp more than the PPK N55 in order to compensate for the weight and have the same trap.
07-08-2013, 09:49 AM | #241 | |
Rep 3,619
07-08-2013, 09:52 AM | #242 | |
Rep 1,730
This is unlike a mechanical center diff which essentially appropriates torque based on the "path of least resistance", which is influenced by the nominal gearing of the center diff (40/60 for current gen of quattro). If you want to make an Audi handle more like a RWD car, the only way to do it is to replace the center diff with an aftermarket component. BMW on the other hand can simply tweak their software. So from a pure performance point of view, the xdrive is the superior center differential technology since the computer can turn it into a RWD car if it so desires. The way Audi deals with the understeer is to stick on the rear differential, but that's a whole different discussion. Now does an xdrive car understeer more than a RWD car (based on drivetrain, not weight/distribution)? Of course it does, based on the pure fact drive force is going to the front wheels. But BMW engineers can simply code this out if they want to. So unless you have access to BMW's calibration tables, then I can't really see how one can definitively argue that xdrive hurts the F30's performance other than the added weight and the lack of sports suspension. |
