02-28-2016, 03:15 PM | #243 | |
Rep 1,003
05-12-2016, 06:35 PM | #246 |
Rep 41
Hi guys,
I own a BMW F31 (European version 318d) with halogen headlights and I'll make the retrofit to xenon. Currently, I'm collecting the parts and I already have the following: - Passenger side headlight (Adaptive) (63117259528) - 2 x Ballasts (63127296090) - 1 x Led module set (63117398766) - 1 x ECU module (63117316186) I'm following this thread as well as kapkanimd's thread and I've the following doubt: I found the adaptive headlights in Germany's ebay with the part numbers 63117259527 and 63117259528 respectively. But in realoem.com, the adaptive headlights for my model (3K11) should be 63117338701 and 63117338702. I already bought one of them (63117259528) and now I'm not sure if it will work with the ECU (63117316186). Does anyone know if the headlights will work with the ECU and why the parts have different numbers? Maybe is related to the region or something... Hope I didn't buy incompatible parts so far Many thanks |
05-18-2016, 01:39 PM | #247 | |
Rep 1,139
06-07-2016, 02:35 PM | #248 |
Rep 25
F30 Xenon upgrade
hi, please can somebody talk me through all the parts i need for the halogen to xenon upgrade.
im from the UK and i have a May 2012 318D Manual Sportline Saloon with halogen headlights. im getting mixed up with different part numbers. Thank you |
07-19-2016, 11:47 AM | #249 |
Rep 16
Gents,
Does anyone know if 63 11 7 259 525 (526) are adaptive xenons or standard xenons? Seller is claiming these are adaptive, but I can't find any confirmation of that. All I was able to determine is that 523 (524) are standard xenons and 527 (528) are adaptive. No clue on 525 (526). Any idea? |
09-08-2016, 06:24 PM | #250 | |
Rep 41
I will replace my F31 halogens with xenons soon (the only part missing is one Driver module for headlight 63117316186). I will use your tutorial to install the xenons but unfortunately, the wiring diagram links are broken Can you please share the wiring diagrams again? Many thanks! |
09-18-2016, 07:00 PM | #251 |
Rep 41
Hi everyone,
Finally, I got all the parts for the retrofit and I'm almost ready to start. My only concern before starting with the retrofit is the FEM harness change. I have the German version of the F31 and the tutorial from kapkanimd is written for the US version. It seems pretty much the same, but comparing to Doni's post, there are two different pins: US version (kapkanimd): Move pin 26 from connector A173*2B to ---> pin 53 in connector A173*3B Move pin 34 from connector A173*3B to ---> pin 41 in connector A173*3B Move pin 51 from connector A173*3B to ---> pin 53 in connector A173*4B Move pin 39 from connector A173*3B to ---> pin 54 in connector A173*4B EU version (DoNi): Move pin 26 from connector A173*2B to ---> pin 53 in connector A173*3B Move pin 34 from connector A173*3B to ---> pin 41 in connector A173*3B Move pin 49 from connector A173*4B to ---> pin 53 in connector A173*4B Move pin 37 from connector A173*4B to ---> pin 54 in connector A173*4B Can anyone confirm if DoNi's scheme is correct for the EU version? As anyone tried it? Many thanks |
09-25-2016, 01:43 AM | #252 | |
Rep 20
I made the reequipacion, thanks to everyone who helped me. here's how I did it: http://www.bmwfaq.com/threads/reequi...lluvia.865650/ |
10-10-2016, 05:58 PM | #253 | |
Rep 41
I'll be on vacation next week and I will use some of the time to do the retrofit. Hopefully, the wiring will be the same as yours, because we both have the LHD EU version |
10-11-2016, 01:42 AM | #254 |
Rep 20
10-11-2016, 04:24 AM | #255 | |
Rep 6
Any news on this? |
10-11-2016, 04:27 PM | #256 |
Rep 3,863
Has anyone fitted these ?
http://hoskinsauto.com.au/light-upgr...light-upgrade/ OEM headlights too expensive and hard to retrofit |
10-12-2016, 05:48 PM | #257 |
Rep 740
The LED angel eyes are controlled by the drivers control module. The only thing thats directly connected to the harness is the xenon, high beam shutter and parking lights.
10-14-2016, 10:24 PM | #259 |
Rep 740
10-15-2016, 12:11 PM | #260 | |
Rep 6
Coding error driver module (TMS) Links | 8040F0 Coding error driver module (TMS) rechts | 8041F0 Wrong version installed light-control unit | D90D16 Missing LIN slave driver module headlight links | D90D2F Missing LIN slave driver module headlight rechts | D90D32 Any ideas? |
10-15-2016, 04:46 PM | #261 | |
Rep 740
10-16-2016, 01:33 PM | #263 |
Rep 740
I'm assuming you VO coded 524? For the error "Wrong version installed light-control unit | D90D16", there should be 8 types in FEM BODY 3064 => LCE_BEL_LIN_VAR. If you're not sure which type you have, try them all and see if one works. Maybe this may fix the other errors you have?
