02-13-2017, 10:33 AM | #288 | |
Rep 74
I reconnected the module to can 1. In which case the High Port is orange and green while the Low Port is only green. I then VO coded the same modules. Then FDL coded as described in the manual method. No image yet. And also E-sys does not show the TRSVC or PDC in the ECU list. Only FEM_BODY, FEM_GW, ICM, KOMBI, HU_NBT, ZBE and a few more are present. I wonder the previous posts, where there initially is no image, however after a night's time everything was working like a charm in the morning. Any suggestions on how that happens? Should I wait for a night long? |
02-14-2017, 04:15 AM | #290 | |
Rep 74
I wonder if KCAN1 requires CAN termination by 120 ohm resistors. I am using the cut off KCAN1 cables that used to be connected to my old iDrive controller knob. While I retrofit NBT and touch iDrive controller knob, I cut KCAN1 wires. And I installed the rear view camera emulator on that cut off line since it was free and also close to the headunit. Since that's now the termination of the CAN line maybe I need to attach 120 ohm resistor. Any idea on CAN termination requirement for BMW? |
02-14-2017, 04:59 AM | #291 |
Rep 2,302
The TRSVC can only be seen if the original was installed.
The connection to the cutted K_CAN wires from the old controller should work. But about CAN termination i know nothing. Maybe you can ask the seller of the emulator. In my opinion there can be 2 problems. Either the camera doesn't send any video signal or the connection with the NBT is incorrect. Or the CAN connection is incorrect. |
Funkier13.50 |
02-14-2017, 06:46 AM | #292 | ||
Rep 74
f30tikka0.00 |
02-14-2017, 09:07 AM | #293 |
Rep 2,302
RVC = wert_02 means only Rear View Camera On.
wert_01 would mean Camera Off. For your installation the codings can be a problem because these codings are for the original retrofit with TRSVC ecu. But i found some other values in NBT. You can try this other values for CAMERA_SYSTEM. |
02-14-2017, 08:07 PM | #294 |
Rep 24
Hi
does anyone know the part number for the main harness (trsvc to NBT) i assume this harness is same one for both trunk method and driver seat method ? after reading all posts i only see the different length on HSD cable Thanks |
02-14-2017, 08:17 PM | #295 |
Rep 5,993
Wow that's awesome looks identical to OEM, must be already pre wired to accept the install. Great feature to have. Do you also get gps or did you already have this?
02-15-2017, 12:04 PM | #296 | |
Rep 74
03-18-2017, 10:13 AM | #297 |
Rep 3,815
So one for those that have done this on NBT F30
Got the car apart pins 51 52 on the CAN connection are blank nowires in plug to top into. Solution is to purchase some pins with wires Part Number The bushing contact part# is 61130005197. Soldered to the tails of the green and orange/green CAN wires from the camera unit and pop them into the empty 51 and 52 pins. Then added 3AG to VO and the did CODE on ICM, HU_NBT, REM, FEM_Body in coding section in Esys. TRSVC did not code as CODE buttonw as greyed out. All put together and tested which is great. One observation though comparing to the i3 which has same system the line guidance is slower Now to put my coding back and get rid of the warning message as well
F30 335i M Sport - now departed
03-26-2017, 07:27 PM | #298 |
Rep 412
Hello Guys,
Just spend the last hour to read the all 14 pages... I have a 6 month BMW M4 that I just bought 10 days ago with the last Idrive version 5. Can someone tell me if the ******ion are the same as the NBT version? Is it possible to simply do a retrofit with ISTA P or it requires FSC code? Thanks.
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
03-27-2017, 02:30 AM | #300 |
Rep 3,815
would be same adding 3AG to VO and coding. Bought my camera, unit and cable from ebay seller it was the F10 cable but its just case of undoing some of the felt tape to separate some of the cables and unit fits nicely to the lugs above the car battery on the bulkhead. Just need some nylon nuts as one that hold the boot fusebox. If you need the OEM install guide pm me.
03-27-2017, 05:20 AM | #301 | |
Rep 412
Ok so I can do it with ISTA P directly then?
03-27-2017, 06:13 AM | #303 |
Rep 412
Ok thanks guys.
I think I'm going to buy it, found a pretty good deal http://www.ebay.fr/itm/172226834408?...%3AMEBIDX%3AIT
04-12-2017, 10:54 AM | #304 | |
Rep 644
Have PM'd you. Cheers |
04-14-2017, 04:28 AM | #305 |
Rep 943
Drives: 2012 328i Modern Line
Has anyone ever been successful in finding the correct link cable to install the module in factory position in driver footwell?
04-14-2017, 04:48 AM | #306 |
Rep 2,302
04-14-2017, 05:01 AM | #307 |
Rep 943
I'm not finding any info on it. Realoem doesn't even have any.
:wave:
04-14-2017, 07:43 AM | #308 |
Rep 2,302
Yes, this is because I have sorted out the part numbers from the complete retrofit set.
To the complete retrofit kit belongs still the camera, the button and so on. But if you already have all parts except the cable set, you can order this at your BMW-dealer by this part number. |
