12-12-2012, 02:22 PM | #1 |
Rep 573
LSD for the F30?
Anybody heard/know what WaveTrac's plans are to build a torsen LSD for the F30? Does the F30 have the same horrible ring gear welded to the differential carrier that the 2007+ E90's had?
12-12-2012, 03:33 PM | #2 |
Rep 886
I would like an answer on this too! The F30's open diff is really a bummer to drive with :/
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
12-12-2012, 04:30 PM | #3 |
Rep 300
even with 255's in the rear? seriously?
| '13 328i M Sport - Estoril Blue | '12 300C SRT8 | '12 Wrangler Rubi Unlimited - COD MW3 Edition|
12-12-2012, 08:15 PM | #4 |
Rep 886
Coming out of slow speed corners, damp surface, having just your inside tire spinning is no fun, seriously
12-12-2012, 10:24 PM | #5 | |
Rep 573
Worse with DTC juddering away trying to fix it |
12-13-2012, 11:00 AM | #7 |
Rep 22
12-13-2012, 01:22 PM | #8 |
Rep 4,323
Umm....for manual trannies only, correct?
12-13-2012, 03:27 PM | #9 |
Rep 573
Post 2007 E9x's wavetrac had a kit where you'd send your dif/ring gear assembly to them, and they'd separate the ring gear from the diff with a CNC machine, then they'd drill and thread it to allow bolt mounting to the wavetrac diff - super fun, like an extra $700 fun or something like that
12-13-2012, 03:43 PM | #10 |
Rep 573
I'd hope they'd offer one for both manual and auto with different gear ratios (being that the final drive ratio's are different between the two)
328i MT - 3.91:1 328i AT - 3.15:1 335 MT - 3.23:1 335 AT - 3.15:1 |
12-13-2012, 03:46 PM | #11 | |
Rep 4,323
Have they ever offered an LSD for auto's? Usually past will dictate outlay for new existing models.
12-13-2012, 04:06 PM | #12 | |
Rep 573
http://wavetrac.net/application_bmw335.htm |
12-13-2012, 05:38 PM | #13 |
Rep 886
We need to start emailing wavetrac to begin developing a differential for the F30!
12-14-2012, 01:24 AM | #14 | |
Rep 22
Нere in Moscow the only way available now is to install a complete rear shaft with Quaife diff. The price is 5k$ incl. labor hours. |
