09-21-2017, 06:12 PM | #89 |
Rep 1,480
Drives: 2020 M340Xi (G20)
alexgarcia ,
Glad to be of assistance. I have changed out regular incandescent bulbs for LEDs in my car's back up, front and rear turn signals. All the bulbs were error free (they had built in resistors), BUT I still had to do some coding. Think there are two separate aspects that we have entwined in this discussions: • First, if LED bulb does not have resistor (built in or hooked in), the bulb will flicker -- think that has to do with normal variations in current (which for incandescent bulb would merely be a variation in intensity). • Second, BMWs have two built-in diagnostics to check whether the bulb is working: cold (at start up); and warm (periodically, think it is every 5 minutes). If the car gets nothing back, then there is an error code or something to indicate a bad bulb. For the first aspect, getting error-free bulbs will be the cure; while coding is the only way to overcome the second, which you can operate the car safely with no problems (I know I did for a couple of weeks). Every bulb you change will need three code changes:
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
09-22-2017, 12:51 AM | #90 | |
Rep 12
RSnic
Again I appreciate your time to provide with a really detailed explanation of all points in our discussions. If I am allowed a summary see and check I got it all right: Flickering is covered by means of resistors (built in or hooked in)...I still need to find out if mine are built in (i hope since the parts I bought are retrofitted, --retrofit is a new word to me and I hope I am understanding it right... an OEM part intended for an upgrade) since I have a complete housing and the leds (if not built in then I am not getting the proper understanding of the retrofit concept)....anyways I wanted the full housing replacement not only the leds. Finally having resolved the variant of current still need to deal with the car checks (3 in total) ...and here comes my real challege: getting required software and hardware to do the coding and secondly getting the actual codes for this particular job... I think I will still be asking questions here and there for a while...then I can move on to the screen upgrade feeling much safer.... Final question...Is it safe if I install these fog leds now ? or shall I waint until I have all set in place... Thanks, Quote:
09-22-2017, 04:58 AM | #91 |
Rep 943
Drives: 2012 328i Modern Line
I still think the light output from this mod even with correct coding is worse than halogens.
:wave:
09-22-2017, 07:10 AM | #92 | |
Rep 1,076
Sometimes think if I should just go back to stock. |
09-22-2017, 08:25 AM | #93 | |
Rep 1,480
You have almost correct. If you are just changing bulbs, then that is what you are doing -- period. If, however, you are changing the reflective housing, then you are doing a retrofit. As others have pointed out, just changing either Foglights or Headlights from incandescent to LEDs is not really all that good because the original housing is designed to reflect & focus the incandescent bulb. I personally agree with them. That is why, though LED bulbs are terrific, I have only changed out turn signals and back up lights -- BUT, as the saying goes to each their own! As to whether installing LEDs and later doing the coding is safe, please see my earlier post as to what I did with my rear turn signals. I installed yellow LEDs with built in resistors and didn't code them for several days -- they flickered, due to both types of checks (at start up, cold, and periodically, warm check) Feel free to continue to ask questions -- that what I like about this forum; I have learned a great deal from people asking and others answering! Again, hope that helps!
Al
alexgarcia1.50 |
12-15-2017, 02:17 AM | #94 | |
Rep 12
Back with some more questions. I installed my fog led lights after a while and they flickered so I bought some resistors ment for my leds JDM Alstar. Then they continued flickering and I was advised to install 2 at each side. They continue to flicker. Now I have finally received my ENET cable and even I have no coding experience I want to rush to see if that will correct the flickering. I am a bit lost here. Thanks |
12-15-2017, 07:37 AM | #95 |
Rep 16,139
Go back and read Post # 81, if you want a more detailed explanation of why coding is a necessity read this:
http://f30.bimmerpost.com/forums/sho....php?t=1377259 |
12-17-2017, 12:37 PM | #96 |
Rep 12
Billfitz I will do the coding. I guess it is most people´s fear mine too. But will overcome that and thanks I now understand what the issue around flickering is.
12-17-2017, 02:05 PM | #97 | |
Rep 16,139
I put off seriously considering LED for a year because of coding. I kept reading review after review of LED bulbs waiting for someone to say 'this really is plug and play', and it never happened. Then I watched the video of how to code and saw it wasn't hard at all, so not only did I code my lights but also a number of other items. It's worth learning just to get rid of the stupid disclaimer on the screen every time you start the car.
11-07-2018, 05:46 AM | #101 |
Rep 4
Very nice topic includes every detail for lci front fog retrofit.
But, I have another question Does anybody know whether the "pre-lci fog lights" fit to "lci front bumper (non-m sport)"? I'm planning to do lci bumper retrofit (non-m sport) for my pre-lci F30 and wondering if I can use my halogen fog lights for the "lci bumper (non-m sport)". (I dont care the light color of the fogs because never use them except low sight distance in adverse weather) |
02-21-2019, 08:13 AM | #102 | |
Rep 388
02-21-2019, 11:13 PM | #104 |
Rep 388
Can anyone confirm this is the correct coding I need using bimmercode? I am just worried I will mess something up in expert mode. But I don't want my lci leds fogs to flicker when on. Thanks for the input
FEM_BODY 3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_IS_LED -> aktiv : LED Foglights front right 3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right 3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_IS_LED -> aktiv : LED Foglights front left 3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left 3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_abbiegel_L_output -> nsw_l : Foglight when turning 3062 Mapping_abbiegel_R_output -> nsw_r : Foglight when turning 3073 KL_ENABLE_RE -> KL_Ein : Foglight when turning 3066 KL_ENABLE_LI -> KL_Ein : Foglight when turning 3073 C_CLC_ENA -> enable : Foglight when turning 3073 C_BLC_ENA -> enable : Foglight when turning 3063 Mapping Nevelschw L Part of WL soft-on nicht_aktiv : Foglight left as welcome 3063 Mapping Nevelschw R Part of WL soft-on nicht_aktiv : Foglight right as welcome |
02-22-2019, 01:52 AM | #105 | |
Rep 334
Just one other point about an error that just gets propagated through all these posts: both the KL_ENABLE items are 3066, NOT 3073. |
02-22-2019, 07:34 AM | #106 | ||
Rep 388
02-22-2019, 07:50 AM | #107 |
Rep 334
Does your light switch panel have two wheels on the right: instrument brightness and headlamp height adjuster. If no headlamp control then my warning shouldn't apply. If the control is there, you won't break anything by trying with C_BLC_ENA both disabled and enabled.
02-22-2019, 07:53 AM | #108 | |
Rep 388
02-22-2019, 08:46 AM | #109 | |
Rep 334
EDIT: just re-read your first sentence, which makes no sense. Are we both looking at the same item: the main light control panel on the right of the dashboard (for RHD car) or the left (for LHD car)? Last edited by cjn; 02-22-2019 at 08:52 AM.. |
02-22-2019, 12:43 PM | #110 | ||
Rep 388
