06-05-2017, 07:10 AM | #1 |
Rep 309
Change to non run-flats?
I have a 2013 328i xdrive with factory run-flats. They have a few nails in them and I hear quite a bit of tire noise so time for new tires. Should I replace with run-flats or switch to something else? They do ride a bit hard but I'm concerned about not having a spare.
Also, can you put non run-flats on a car that came with them? Thanks. |
06-05-2017, 08:11 AM | #2 |
Rep 775
I'd go non-runflats... unless you are really in a place where flat tires happen often.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
06-05-2017, 10:38 AM | #4 | |
Curmudgeon and Pedant
690
Rep 3,489
I personally like the F3x with RFT's, especially non-sport package all-season tires like the Bridgestone Driveguard or even the original Pirelli P7, and see no reason to replace them with a go-flat. If you decided to put go-flats on the car, nothing needs to change, although the tire pressure may need fiddling to get good wear and performance. |
06-05-2017, 02:10 PM | #5 | |
Rep 2,036
dberry0832.50 |
06-06-2017, 10:48 AM | #7 |
Rep 17
http://www.shopbmwusa.com/PRODUCT/342/BMW-MOBILITY-KIT
Might not be the cheapest, but its small and all in one.
