Vorsteiner
      03-27-2014, 08:42 AM   #6117
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
Originally Posted by Aritaurus View Post
You weren't able to do this with zeitkriterium 07/13+ ?
I didn't try that.
I guess it does not matter.
I think for zeitkriterium >=0703 options should be 609, 6AK, 6NR, 6NS, 6AR.
      03-27-2014, 11:03 AM   #6118
carzaddict
Drives: M-Sport 328i X-drive
Hey Shawn, I just checked my E-sys and its telling me I have PSdZ version 4.7.....how does that translate into a version number you've been telling people? (for example 51.2)
I have a 2013 (June build) car with CIC.....and E-sys 3.23.4..........is there a significant change to convince me to upgrade my PSdZ files to 51.2? Would it cause any harm?
thanks
2011 Jaguar XFR
2013 VW Beetle
      03-27-2014, 11:07 AM   #6119
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
It does not translate at all, as the PSdZ version displayed in the E-Sys => Help => About screen has nothing to do with the PSDZData used for coding.
In your case, you would only need to update your PSdZData if your car had newer than 51.2 on it, and you were unable to code it.
      03-27-2014, 11:20 AM   #6120
carzaddict
I was able to successfully code it with the PSdZdata I have now (not sure what version)
i thought maybe newer versions had newer features?
But then I also figured newer versions were for newer cars and had features for stuff like NBT and not CIC. unless i have it all wrong.
2011 Jaguar XFR
2013 VW Beetle
      03-27-2014, 11:24 AM   #6121
shawnsheridan
No. Newer PSdZData adds nothing. The features available to your are based on the the software on the car, not the software you use to interface with the car. The only way to possibly get newer features is to program the car and flash new firmware onto the ECU's. You update your PSdZData out of necessity, when the car has newer software on it then you have for coding it, not for benefit.
      03-27-2014, 11:35 AM   #6122
BooGooBird
BooGooBird
BooGooBird's Avatar
Drives: 2012 BMW F30 335i
The 6WA LCD panel is only on the bottom right. There's only plastic on that other side so the answer is no.
I am not talking about the bottom right and left. I am talking about the area where you can see your mpg bar right below your RPM meter, but on the bottom of your speed meter, you get nothing on F30s, but on F10s, it has other information showing up on there like gas distance bar.
      03-27-2014, 11:38 AM   #6123
BooGooBird
BooGooBird
BooGooBird's Avatar
Originally Posted by Mariuss View Post
How do I display the 'Charge power' display in the right binnacle? I have 2012 F30 and can only show Actual consumption or 'suggested way stepping on the gas'. Is there a coding I could do to enable this?
I think that's the new ECO par for 2014 F30s, I believe you can code it to 2014 version, or it might be just the label name that you could simply change, I am going to give it a try this weekend.
      03-27-2014, 11:43 AM   #6124
Mariuss
Czech_Republic
Drives: 2012 320d
There is no display there on F30, see it during the night - you can see where the display ends on the F30 (between the instruments but there's nothing on the right).
      03-27-2014, 11:45 AM   #6125
Mariuss
Czech_Republic
Drives: 2012 320d
If it's a simple parameter change, I would go for it. If it requires coding the whole car to 2014, I'm hesitant to do it.
Btw. I assume it shows, how much your battery is charging during the coasting/braking, is that so?
      03-27-2014, 12:19 PM   #6126
sbc55
Drives: F10
Originally Posted by avgor123 View Post
I didn't try that.
I have tried with VIN with the above... but didn't reset the NBT ... but I did VO code the NBT after the "write"... I will try again and will reset the NBT accordingly.
Can you let me know when you said you update the service, you are using the "Update BMW services" under connecteddrive -> options?
No matter how I code, I still not able to enable BMW Live in the menu... For now, I only have 3 items
-Mobile care
- Hotline
- Your service
under connecteddrive menu.
      03-27-2014, 12:27 PM   #6127
BooGooBird
BooGooBird
BooGooBird's Avatar
I'm not sure about that, I thought the bar is for the range that you could optimist your max efficient not for battery charging, the battery charging bar (short one on the end of eco bar)is showing when is your battery being charged, right?
      03-27-2014, 12:40 PM   #6128
avgor123
avgor123's Avatar
Russian Federation
Yes, exactly.
I can send you my .NCD file for comparing if you give e-mail address.
      03-27-2014, 12:49 PM   #6129
sbc55
Drives: F10
Yes, exactly.
Thanks. You have sent me the file...
      03-27-2014, 06:50 PM   #6130
BMWSKI
BMWSKI's Avatar
131
Drives: E63 AMG Saloon :)
Hi Guru's!
I have a new 335d saloon and I would like to know what gear I'm in when in standard 'D' driving mode. I can see it on sport mode (S3 for example) but I would like to see 'D3' when regular driving...Is this possible through coding?
If so, what is the info to carry it out please?
TIA
      03-27-2014, 07:37 PM   #6131
carzaddict
my buddy wants me to do some coding for his 2014 3 series.
I am assuming I have to update my PSdZData.....if I do....would I be able to go back and do coding to my car? would coding my car with the newer data cause a mess?
2011 Jaguar XFR
2013 VW Beetle
      03-27-2014, 10:52 PM   #6132
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Newer versions of the PSdZData are backwards compatible with older firmware.
Upgrading to a newer PSdZData will not affect your ability to code your car with older firmware.
      03-28-2014, 03:12 AM   #6133
avgor123
avgor123's Avatar
Russian Federation
Originally Posted by BMWSKI View Post
Hi Guru's!
TIA
No, it's impossible.
      03-28-2014, 05:53 AM   #6134
BMWSKI
BMWSKI's Avatar
131
Thanks!
      03-28-2014, 09:02 AM   #6135
silica666
Scotland
Drives: 2014 f30 335D XDR Msport
You should VO Code this rather than FDL Code it:
I've hit a bump, when following the stages to change FA I get as far as read FA from car, I get no edit button and no file listed in vehicle order c:\data........f20.xml.
If I go direct to editors and viewers I get C:\data\FA\falistsample.xml but can't find anything relating to entwicklungsbaureihe=f20 which is what I assume I need for the f30?
Please advise
Ian
      03-28-2014, 09:04 AM   #6136
shawnsheridan
Please advise
Ian
Hit the Save button first, then you can hit the Edit button.
      03-28-2014, 10:56 AM   #6137
sbc55
Drives: F10
Hi,
My steps was:
Prerequisites
- FA has 609, 614, 615, 616, 6NS, 6NR, original VIN, zeitkrit >=0712
- NBT was VO coded and then FDL coded for Internet/BMWLive
1. write fake VIN to NBT
2. reboot NBT (push 30 sec volume button)
3. check VIN is fake and FSCs are rejected
4. update connected drive services via BT data
5. check internet and BMWonline items are appeared under connected drive (it may take a few minutes)
6. write back original VIN
7. reboot NBT
8. check VIN is original and FSCs are accepted
9. do not update connected drive services ever
tried the above. Step 3 check VIN is fake and FSC are still "accepted"...
I think my problem is dunno how to force the fake vin in. I have tried using the mobile call service under connected drive and it still show the original VIN.
I am trying to change FA VIN and FDL code HU-NBT but encountered error during cddeploy... should I disable VCM and MSM update?
      03-28-2014, 11:02 AM   #6138
sbc55
Drives: F10
Originally Posted by g4movtpt View Post
thanks avgor123, thanks Shawsheridan.
Very clear your explanations.
i will continues doing test with my NBT, is the best way to learn, LOL.
I am having same problem of not getting BMW online/internet after upgraded to 52.1. Are you able to enable these features now? Mind to share your experience.. thanks.
