BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Any recommendations for LED brake lights? SOLVED
      03-23-2024, 10:26 PM   #1
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
I lost my OEM halogen left brake light today after 11 years of dutiful performance
Any suggestions? I am not a $150/pair exotic bulbs kinda guy. I retrofit my halogens with LEDs for Daytime Driving and Low-Beam for under $25 a pair that work great, so LED brake bulbs in that range.
I haven't visually confirmed yet, but I believe it's P21W (outer) for 2012 F30 328i.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
      03-24-2024, 11:29 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I have these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Make sure of what bulbs you have, the charts aren't always right.
      03-24-2024, 12:30 PM   #3
fe7565
fe7565's Avatar
Thank you. I checked what bulb I need to buy, and didn’t say anything wrong with the filament. So I checked the connection and there was severe pitting. Cleaned it off with sandpaper and now it works. However, I need to prepare some replacement bulbs since they are 11 years old.
In the big excitement, I forgot to check the part number of the bulb. The two pegs are on the bottom and 180 degrees. So should be P21W
      03-24-2024, 05:30 PM   #4
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
Over the years of use, the filament metal evaporates, some of it settles on inside surface of the glass bulb, the intensity of the buld lowers (bulb light becomes dimmer). Filament becomes more fragile and could let go at any moment. It is good to be prepared with replacement at hand or, at least, have the source lined up for purchase.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      03-24-2024, 06:18 PM   #5
fe7565
fe7565's Avatar
Thank you. Ordered LEDs, which should also reduce amperage.
      03-24-2024, 09:36 PM   #6
Billfitz
Billfitz's Avatar
If I needed any additional convincing on the need for LEDs for brake, turn and back up lights it's the all too common failure of the rear lamp ground connectors that burn out from excess current.
