BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Interior led lights
      07-13-2015, 10:41 AM   #23
jazza
jazza's Avatar
301
Drives: F32 428i
Originally Posted by nickhelou View Post
Thanks for the videos! Is that an LED Strip in the back?
Yes, four strip 2.70€ (2.97$)
BCforged HB29 - M4 trunk - Bilstein B12 Sportline Damptronic - 435i type exhaust cf Cyba tips - M4 grills - 3D design cf diffuser - Kerscher cf lip
      07-13-2015, 10:47 AM   #24
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Nice! Wish BMW would have included a Porsche Boxster-911 type of light under the trunk liner, would have made it all so simple
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      07-15-2015, 06:25 PM   #25
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Well, here they are the pics
And there's another issue that perhaps for some is unimportant. In the E92 also already happening and it seemed an incomprehensible error in the design and it's repeated in the F32.
When you lift the lower trunk lid, it covers the dome and you see nothing.
One way to solve it (I did it also in the E92)
Jazza,
Was thinking about the same problem in the trunk. Did you get an LED strip and run the wire to the original trunk LED?
Here's an LED strip, I am considering; would appreciate your thoughts
http://www.ebay.com/itm/291161780706...84.m1436.l2649
Thank you very much
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      07-16-2015, 12:34 PM   #26
jazza
jazza's Avatar
301
Drives: F32 428i
Originally Posted by RSnic View Post
Jazza,
Thank you very much
Yes, you just have to connect in parallel to the wiring of the original LED
      07-16-2015, 02:50 PM   #27
DD335i
Drives: '14 BSM F30 335i
Nice job
And awesome seats! Lol
'14 F30 335i Msport bsm-black dakota
Tech-Premium-HK
South Florida Real Estate
      07-19-2015, 10:18 AM   #28
RSnic
RSnic's Avatar
Jazza,
What I had in mind was to tap into the wires connecting the existing light and mount one of those LED strips that put out about 400-500 lumens on 6-8 watts.
Is that what you are describing?
BTW, is there a simple way to tell which wire is positive?
Thank you very much
Al
Retired: 2014 328i
BMW CCA
      07-19-2015, 07:13 PM   #29
whoisthis
Drives: bmw
So..is there a diy on how to do interior lighting mod?
Something like ebay link on what exact leds to buy would help alot for complete beginners..
F30 328i sedan
      07-19-2015, 08:04 PM   #30
ahero4eternity
Drives: bmw
The lights I've replaced thus far have all been plug and play. It's taking me longer to type this out than to replace one of the footwell lights.
      07-20-2015, 01:27 AM   #31
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
All you need is a flat head screwdriver or anything that would make it easy for you to pry them out. Simple plug n play.
      07-20-2015, 01:55 AM   #32
whoisthis
Drives: bmw
I maybe interested in just doing trunk led, sunvisor open lights and dim white led at the bottom of each door( to match welcome light)
Could you give me a link on what/where to purchase the item?
F30 328i sedan
      07-20-2015, 10:57 AM   #33
jazza
jazza's Avatar
301
Drives: F32 428i
Jazza,
Thank you very much
Yes, that's exactly
No matter know what the positive is. If LED stripe not lit, change the polarity of the cable
      07-20-2015, 11:08 AM   #34
jazza
jazza's Avatar
301
Drives: F32 428i
Regarding the links, I bought them in a Spanish web, but I've seen the same LEDs in many other webs.
The most difficult to find are those of the vanity mirror. I've Only seen here:
http://www.ebay.com/itm/271650692072?rmvSB=true
      07-20-2015, 11:11 AM   #35
jazza
jazza's Avatar
301
Drives: F32 428i
Auto quote
      07-21-2015, 06:31 PM   #36
whoisthis
Drives: bmw
Auto quote
uh...$45 for the sun visor light?
what about bottom of each door lights( to match welcome light)?
F30 328i sedan
      07-22-2015, 09:48 AM   #37
jazza
jazza's Avatar
301
Drives: F32 428i
Yes, "little bit" expensive
Door lights 24.75€ (27$) but in an European web. I see that, for example, at Burger Mortsport cost 49$ and I think are exactly the same ....
      12-21-2016, 08:32 AM   #38
STLBimmer
Drives: 2016 M4 & 2015 i8
Codes
Anyone having trouble with these aftermarket LED throwing codes?
      12-21-2016, 09:51 AM   #39
jazza
jazza's Avatar
301
Drives: F32 428i
No troubles at all
      08-14-2017, 02:56 AM   #40
F10_M5
F10_M5's Avatar
Drives: F10 M5
Impossible, the LEDs are integrated in board, no sockets.
-TRUNK
-DOORS
-FOOTWELL
-VANITY MIRROR
I haven't removed the roof domes, but the system is the same ...
Jazza, do you have Trunk, Doors, Footwell & Vanity Mirror parts numba? Can you please share the parts numba, thanks!
      08-15-2017, 02:31 PM   #41
jazza
jazza's Avatar
301
Drives: F32 428i
Here you have!
http://www.realoem.com/bmw/enUS/show...diagId=63_1354
or here
http://bmwfans.info/parts-catalog/F3...various_lamps/
      08-15-2017, 05:14 PM   #42
F10_M5
F10_M5's Avatar
Drives: F10 M5
Thanks!
      08-16-2017, 01:30 AM   #43
hakisalapaki
Drives: BW 2012 F30
Hi All,
I do change my Trunk, Doors, Footwell & Vanity Mirror leds too,but except dome light front and back.Seems much complicated,anyone dissasambled those,and changed stock leds to brighter ones?
      08-16-2017, 02:02 PM   #44
jazza
jazza's Avatar
301
Drives: F32 428i
Originally Posted by hakisalapaki View Post
Hi All,
Yes I did! Promina leds buyed in Amazon Japan. In the end I changed again the footwell leds (Promina, as well) like you can see in this video
