03-04-2019, 10:21 PM | #4203 |
Rep 101
Installed a carbon fiber intake and shot a DIY
https://f30.bimmerpost.com/forums/sh....php?t=1590073
📺 Subscribe to my F30 YouTube Channel https://www.YouTube.com/M3Beats
📷 Follow my F30 335i on Instagram https://www.instagram.com/m3beats |
fuseryder122.00 N26Ghost496.50 CleanKM103.50 floridaorange10168.00 RoarinRow65.50 Digital_83262.00 ZoranTerzic140.50 EricVR4603.50 HondaGoneRogue432.50 |
03-05-2019, 12:17 AM | #4204 |
Rep 391
Drives: F87 M2C
Not any good ones, I'll have to go out to take some pictures. Any I take in the garage is too dark so you can't even seen the color if I have the whole car in frame.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
TK335iMSPT299.00 |
03-05-2019, 01:28 AM | #4205 |
Rep 1,827
Finally got around to changing my spark plugs. Ran almost 20k miles on NGKs, back to OE Bosch. Idk if it's all in my head, but I swear the car feels smoother, both at idle and under load.
I did it the right way by taking off the strut brace. Well, ALMOST the right way...I didn't have replacement bolts so I reused the old ones. They still torqued to spec, so I suspect it'll be alright, at least for the time being. Strangely, my coil packs on cylinders 3 & 5 were yellowed, noticeably more so than the others. Not sure what that's all about. Also, plugs on 5 & 6 unscrewed a bit more easily, leading me to believe that I wasn't able to torque them properly the last time I did it since I tried working around the strut brace that time using wobble extensions and universal joints. Start to finish, took me about an hour or so. Maybe a little more to put all the pieces back together.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
vinzcast21161.00 |
03-05-2019, 12:28 PM | #4206 |
Rep 94
New m3/m4 style fenders. New android 10.25" screen to replace original 6.5" idrive. & new forge charge pipe to replace my original one that split & detached on high boost haha
2013 335i ActiveHybrid3 - BMS Cold Air Intake, Wagner Tuning Performance Intercooler. Stage 2 468bhp engine/elec motor combined.
Digital_83262.00 |
03-05-2019, 02:06 PM | #4207 |
Rep 2,671
Flashed - stage 2 bm3 today
Car drives like I had originally hoped it would now. It's plenty tame in comfort and plenty fast in sport/sport+ now. Probably time to get colder spark plugs, I know it's not mandatory but any input is appreciated. Also - anyone know if I should change the oil more often? Last oil change was in Nov. Probably only 4k miles ago. But I'm pretty ocd about that. |
03-05-2019, 07:41 PM | #4208 |
Rep 214
Picked up some fun things to do after my trip to Japan.
M-Performance rear diffuser and Bavsound Stage 1 with extra tweeters for the rear. So maybe stage 1.5?! |
03-05-2019, 08:33 PM | #4209 |
Rep 943
Drives: F30 328i Msport
Thorough wash after such a filthy winter.
03-05-2019, 10:30 PM | #4210 |
Rep 106
Drives: 2014 335i xDrive M Sport
03-05-2019, 10:47 PM | #4211 |
Rep 446
highway 7 coquitlam
Mod bug will bite you if you buy a BMW ================================= |
03-06-2019, 07:21 PM | #4212 |
Rep 7
i fried my car
Okay so I'm running a bootmod3 stage 2 tune and i was getting some misfires, so I ordered ignition kid from fcp euro to replace plugs and coils as that would be the first idea to fix. Ran car before working on it , no codes or atleast significant ones. After working on it and finishing up i went to start it up and nothing, it just cranked but never kicked over and started. Ran codes and i got a multitude of short circuit codes. Only thing that i can even think of is when i was working on it my ratchet touched a metal piece it couldve been a terminal im not sure tbh but it sparked up for a second. Really hope i didnt fry my car/dme and i just didnt install the plugs correctly or something. Im clueless
113027 relay ignition injector, supply voltage injection line break 1f0515 valvetronic supply voltage cable disruption 1f4a02relay ignition/injector control short circuit to ground 133102 valvetronic relay control short circuit to ground cd9010 1b5202 terminal 15n_1 care provided by cas electrical short circuit to ground 1b5402 terminal 15n_3 1b5302 15n_ 2 130002 /130202 vanos solenoid valve inlet outlet short circuit to ground 122002 diverter valve control shortcircuit to ground 12b102 lambda probe heating before cat control short circuit to ground 123002 wastegate ansteurung kurzschluss nach masse 102a01 air mass meter signal electrical fault 164020 inlet camshaft sensor electric short circuit to positive 164030 exhuast camshaft electric short circuit to positive 1C0202 Engine oil pressure control valve , control short circuit to ground my shop says i fried my dme what do you guys think? |
03-06-2019, 09:28 PM | #4213 | |
Rep 1,953
Drives: 2013 328i xDrive
03-07-2019, 05:07 AM | #4215 | |
Rep 446
newer synthetic oils that comes from BMW can last up to more than 7k miles
floridaorange10168.00 |
03-07-2019, 05:09 AM | #4216 |
Rep 446
Where did you get the android screen? curious since I am kind of interested
03-07-2019, 10:06 AM | #4217 |
Rep 1,953
03-07-2019, 10:11 AM | #4218 | |
poopycat
266
Rep 791
Make sure to read up on the issues there, if that's it. |
03-07-2019, 12:43 PM | #4219 |
Rep 247
Parked in a shitty spot.
03-07-2019, 01:06 PM | #4220 | |
Rep 105
I change my oil every 6-7k miles... it's inexpensive enough that it's worth the added piece of mind. Most of the issues I hear about with these engines are oil related... so make sure your engine is (1) warm and (2) clean before giving it the beans. The harder you drive your car, the more contaminants get into your oil... I read the thread where four(?) BMW engines blew in Chicago during a winter storm recently... some of them had frozen oil in their oil pans... no thanks to that.
2014 BMW 435i M Sport
Bootmod3 Stage 2 93 Oct VRSF Catless DP, VRSF Chargepipe, Wagner Knockoff eBay FMIC, Injen Air Intake, H&R Springs |
floridaorange10168.00 ROBBMAC165.50 |
03-07-2019, 04:09 PM | #4221 |
Rep 509
Drives: 2016 435i
Bought #85
First mod today... tint!
2016 435i MSport ZHP #85
03-07-2019, 07:56 PM | #4222 | |
Rep 2,671
^SICK!!!
--- Today I used some new products - sonax brilliant shine and sonax polymer sealant. I think I like the new angelwax spray I bought but the sealant worked well on my 6 yr old car. Last edited by floridaorange; 03-07-2019 at 08:05 PM.. |
03-08-2019, 08:52 AM | #4223 |
Rep 172
Drives: 2015 328i
Installed BMS oil catch can.
Digital_83262.00 |
