BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 2017 440i Build Help
      09-09-2022, 01:33 PM   #1
bmw.gp
Drives: 2017 BMW 440i
2017 BMW 440i  [0.00]
Hey guys, was hoping to get some advice on my 2017 F32 build. I don’t have any plans to take it to the track anytime soon, so I’m really just trying to get better sound and a bit more power. Would the best way to do this be to get the MPE and a Stage 1 flash/piggyback tune? For context, I live in California and it’s my understanding that any bigger mods (catless/high flow DP, HPFP, etc.) wouldn’t pass smog. This will be my first experience with modding and I don’t want to have to deal with changing parts back to OEM when the time comes to smog, so I want to stick with the easy stuff for now.
Any advice or build suggestions would be much appreciated. Thanks!
      09-09-2022, 01:52 PM   #2
blacksapphire440i
Novice
blacksapphire440i's Avatar
303
Drives: 2018 440i Gran Coupe
Stage 1 or MPPSK is OK. If you want more sound get your resenators chopped off or get an aftermarket axleback. MPE is a great option for keeping it OEM
      09-09-2022, 02:01 PM   #3
midxotic
midxotic's Avatar
199
Drives: 2011 E90 M3
2018 BMW 340ix  [9.50]
Here are some options:
1. MPPSK - M Performance Power and Sound Kit - Cat back exhaust with valves (quiet in comfort/eco and loud in sport/sport plus) and a mild engine tune similar to MHD/BM3 Stage 1 flash. This is expensive but does not void warranty. (about $3,000)
2. AWE or Dinan Midpipe and a Stage 1 tune with MHD or BM3. This will give you some more sound and still utilize the factory exhaust flap with the stock muffler. You can also get a dual resonator delete which does the same thing as the Dinan/AWE Midpipe and might be cheaper. (about $600-$700 for the midpipe and $500 for the tune; cost of dual resonator delete varies by exhaust shop)
3. Catback Exhaust and Stage 1 Tune. This is if you want more noise than option two. Some catback exhausts utilize the factory valve (AFE) and some do not (Dinan/AWE). If the valve is something you want to keep, I would make sure you pick the right catback or just stick with option 2. ($2000 for the catback, $500 for the tune)
      09-09-2022, 03:01 PM   #4
bmw.gp
Thanks guys, this is great information. It sounds like option 2 is the most bang for your buck, but I’ll do some research on the sound difference between a res delete / midpipe and an upgraded axleback.
I’m also considering just picking up a used MPE and a MHD/BM3 flash since the full MPPSK is so much more expensive and only gets you an increase of around 30hp (compared to BM3’s supposed 40-60hp increase on 91 octane).
440i, advice, build, f32, mpe, tune
