01-19-2024, 10:40 AM | #1 |
Rep 1,381
New Maxton Design 4 Series Diffuser
We finally have a more aggressive diffuser design for the 4 Series that doesn't loose the middle slats..
Bought it through Maxton with a code for around £170 The plan is to carbon skin the middle with a carbon herringbone weave, then split paint it like I used to have on my M Performance diffuser. A lot of Maxton's designs are quite rounded looking which has put me off buying their products before, however this isn't too bad, there's some edges on a lot of areas that are sharper than their normal stuff so I took the gamble. Fitment is a solid 8/10 - improvements would be the actual mounting areas, they seem to have designed it to push on and be left, that doesn't fill me with confidence once air builds up though so I'm going to drill some holes where the original mounting points were. The quality seems pretty good, especially if you just want gloss black. Personally that's not my taste though so I won't be keeping it on until I've finished wrapping and painting it. If you've ever seen their 1 Series diffusers then you'll know what to expect, it's pretty much that exact design which they borrowed from the F90.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
01-19-2024, 05:26 PM | #2 |
Rep 423
Looks good. Any fitament issues. Usually you have to use heat gun etc on aftermarkets.
Your other parts on bumper look cool. Guessing its bespoke to you |
01-20-2024, 11:19 AM | #3 | |
Rep 1,381
Took some more photos today: I have heard some horrors about diffusers and fitment before however this fitted perfectly really. Whilst I'm not normally a big fan of Maxton's designs there is one thing you can bag with them and that's quality fitment, they're quite a big company now with in-house designers who model products on actual cars, just wish they would offer carbon products for the BMW range like they do on other cars, it would save me some hassle of carbon skinning it lol.
2015 435i - 401whp
01-20-2024, 11:24 AM | #4 | |
Rep 1,381
As I wasn't hitting MOQ a one off build cost was around £400.. sadly the factory I used went on to use the design and are now selling it on Aliexpress. I can't fully recall what it was listed as but they had a yellow F30 on the listing photo if that helps, I think they were pricing them at around £280. Fitment isn't good though as it was only ever a concept, you have to do some drilling into your bumper and a bit of cutting into the carbon piece.
2015 435i - 401whp
01-21-2024, 12:08 PM | #5 |
Rep 1,381
Got some time today to make a rough edit of how it'll look painted..
2015 435i - 401whp
01-21-2024, 08:19 PM | #6 |
Rep 1,790
Looks pretty snazzy! I really like the more aggressive look. If I can get someone to lay carbon over it I'm definitely interested in buying one. The existing M Performance and clones aren't aggressive enough imo.
This is the link? https://maxtondesign.com/product-eng-20407-Rear-Valance-BMW-4-Coupe-Gran-Coupe-M-Pack-F32-F36-Version-with-exhaust-on-both-sides.html?country=1143020186 |
01-22-2024, 04:30 AM | #7 | |
Rep 1,381
That's the one, they do actually make quality carbon pieces now but unfortunately this isn't one they offer it on. I think they had a big investment over the past 1-2 years as they were originally just a small depot near me, they would only sell plastic and "carbon look" products, now they've got huge operations around Europe with enclave facilities. It's definitely possible though, I'm planning on just doing the middle but there's definitely plenty of people offering carbon skinning services in the US.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 01-22-2024 at 06:15 AM.. |
eff32fl1051.50 |
01-22-2024, 09:07 AM | #8 |
Rep 467
If you have the contacts of those (US vendors) readily available, do you mind sharing (or DM)? I have a "project" in mind, but can't justify CF skinning the parts at home. Thanks!
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
01-22-2024, 09:36 AM | #9 | |
Rep 1,790
I also asked Maxton if this diffuser was available in carbon hoping they'd be willing to do a custom job for a fee but no dice. Last edited by eff32fl; 01-22-2024 at 10:23 AM.. |
Oksamit78271.50 |
01-23-2024, 05:43 AM | #10 | |
Rep 1,381
I did think of a better plan later on though, the underside has a really clean negative mold, I'm hoping to use release agent on it and create an impression that I can lift out and stick on the other side.
2015 435i - 401whp
01-24-2024, 02:35 PM | #11 |
Rep 1,381
Annoyingly I didn't spot the centre line wiggled near the bottom, I kept correcting it earlier on but I guess each adjustment on the sides threw it out again.
It's in with mould release so hopefully I can just trim the sides down, bond it on and then get this sucker painted finally!
2015 435i - 401whp
01-24-2024, 03:44 PM | #12 | |
Rep 1,790
01-24-2024, 06:20 PM | #13 |
Rep 1,381
Just the middle bit, I wanna keep the paint scheme I had before with only the middle being black; except it'll be carbon this time.
2015 435i - 401whp
eff32fl1051.50 |
01-25-2024, 07:54 AM | #14 | |
Rep 467
However, I have a question... You are making the skin using a back side as negative mold, but how are you planning to stick the skin to the outside without fit-up issues? All the ribs/fangs are now "reduced" by being offset uniformly inwards off the mold surface. Additionally, the diffuser is made out of material that has thickness to it... I'd imagine 1.5 - 2 mm, so all the surfaces on the back side are already offset inwards (including the ribs/fangs)... To further explain, I've tried to sketch an example of horizontal section (parallel to the ground) using a 2 mm thickness of diffuser and 1 mm of skin made on inside. See images: Skinning Skinning zoomed on Middle rib: CF skin shifted to the outside Zoomed on middle rib Zoomed on other rib All geometry features were exaggerated to show possible interference... I don't imagine the fairly rigid skin could be stretched or can it be stretched with heat? The skin you are creating would work if there were no ribs in the diffuser, imho. With your skill set in CF skinning I'd reconsider and do attempt the skinning on outside surface, to be honest.
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 Last edited by Oksamit78; 01-25-2024 at 08:46 AM.. |
fortythirtyfive639.50 |
01-25-2024, 10:24 AM | #15 | |
Rep 1,381
The new plan is to make it using one piece of fabric for the flat side and the ribs will have to be secondary cuts of fabric laid in before vacuum forming it, basically just how you would with pre-preg. As it'll be thicker this time I'll definitely be going from the front. I have also noticed how much brighter the carbon is when its been squashed in a mould (the filament strands lay flatter with less excess resin) so now I'm considering making a top side mould for my hood and starting it again I was having some resin issues before and it would look HD in-comparison to what it is right now.. it's just SO much sanding and like $450 in materials down the drain. Hand laid: From a mould: Can't help but think I often shoot myself in the foot haha
2015 435i - 401whp
01-25-2024, 10:57 AM | #16 | |
Rep 467
So, now all you need - the stamping die for GTS hood from BMW factory/supplier and you are good to go to mass produce hood skin inserts. 1. How do you plan to produce a fairly rigid top side mould off the GTS hood? 2. The skin then would be attached to the hood using epoxy and edges be "blended in" with body filler? I know it wouldn't be nice to the eye, but producing a CF skin overlay that is glue able to the hood without any additional body work could be a cool thing to offer for purchase.
01-25-2024, 06:03 PM | #17 | |
Rep 1,381
For anyone with the facility and space to do so they could definitely do it! A guy who goes by the name of Dan Pritchard has done it on his Porsche. He's even made custom bumpers and diffusers using spray foam for modelling. As for rigidity it's just a case of layering heavier gsm fabrics or even throwing plain weave in there, it's a much stiffer weave compared to twill. Adhering it would be a job for something like Methacrylate adhesive. As you mentioned though the edges want to be kept thin or at least tapered by a bodyshop for blending. The only other thing to watch out for when bonding carbon to aluminium is galvanic corrosion, even when sealed the moisture from heat cycling will eventually attack the two ruining the finish, you can either lay down fibreglass before your carbon fabric to insulate any reaction or put down a good enough layer of resin before your fabric touches the metal surface, the latter would need to cure slightly so that it forms a barrier.
2015 435i - 401whp
Oksamit78271.50 |
03-24-2024, 12:04 PM | #18 |
Rep 21
Drives: Bmw 440i f32
Nice diffuser but Where did you get those rear carbon bumper canards?
03-25-2024, 05:53 PM | #19 |
Rep 467
These look similar:
https://www.aliexpress.com/item/1005...Cquery_from%3A
03-25-2024, 09:01 PM | #20 |
Rep 1,381
Yep thats pretty much them - I had a design file that I was playing with and I ended up giving it up to a factory in China as they were going to build some carbon ones for me, instead they ghosted me and as I presumed began making them for everyone lol.
I bought a set through a friend as they refused to deal with me having done a runner lol, they don't actually use the finished design though so if you do buy a set through them you'll need drill new holes in both the carbon and bumper to mount them, then you'll need to create some recesses for the existing bumper screws to sit inside of; otherwise you'll have a 4mm gap between the trim and underside of your bumper. Oh and the resin system they're using sucks, it's super cloudy leaving the carbon with a blue tint. It's impregnated through the fabric too so you can't just sand it off and re-lacquer it. Doesn't look like they sold many though so I very much doubt they'll correct any of the design / material issues they have - if you really want a set go for them, but you'll need to hack them up to make them fit and the finish was enough for me to bin my set.
2015 435i - 401whp
03-26-2024, 12:46 PM | #21 | |
Rep 21
03-26-2024, 06:22 PM | #22 |
Rep 1,381
The ones I have I paid £300 in total after shipping and taxes, they'll be the same though as I'm fairly sure my friend bought them from the same reseller.
2015 435i - 401whp
