BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F80 steering wheel M1/M2 buttons on F30
Studio RSR
      03-13-2024, 07:12 PM   #1
daronk
daronk's Avatar
Drives: BMW 335i
Can I code the M1/M2 buttons from a F80 wheel on my F30? Would like them to toggle the drive mode (comfort/sport).
I realize that there is a kit to install M1/M2 buttons on a M-Sport wheel but this steering wheel is an OEM F80 and already has the buttons.
thanks
      03-14-2024, 07:56 AM   #2
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
thanks
Interesting question.
I suggest you contact the manufacturer of the M1/M2 kit and ask this question - I'm sure they could give an answer.
https://mnlasercutting.com/shop/p/bm...12-buttons-kit
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      03-14-2024, 07:17 PM   #3
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
You still will require the kit. If it was able to be coded the kit wouldn't be a thing.
      03-15-2024, 10:06 AM   #4
daronk
daronk's Avatar
Drives: BMW 335i
Two different steering wheels here that kit works with an M sport wheel. I emailed them and they said it doesn’t work on a F80 wheel which already has the buttons. They claimed that the computer in the right side pod is different.
F80 wheel already has the buttons and is coded with the “M menu” under settings.
      03-15-2024, 05:47 PM   #5
beefyman
beefyman's Avatar
Drives: BMW 2017 F31
2017 BMW  [0.00]
I believe you will need some coding. Reach out to one of the many coders on this forum and they can help you.
      03-15-2024, 05:52 PM   #6
eff32fl
eff32fl's Avatar
1052
Interesting. So does that mean the kit would technically work with an F8x wheel since the PCB in the left side pod is replaced with a PCB from the kit so it can interface with the driving mode toggle but the PCB in the right side pod which controls media wouldn't work. Am I getting that right?
      03-16-2024, 02:04 AM   #7
HeartbreakerF80
HeartbreakerF80's Avatar
Drives: F31 M Sport | F80 M3
I have an F80 wheel too but you need the electronics from the M Sport wheel.
The kit essentially turns those buttons into up and down buttons as it just mirrors the drive selector drive on the center console.
The M1 and M2 buttons in the F80 are fully customizable and have a completely different PCB board underneath the buttons.
