BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Any updates for companies cracking the DMEs?
proTUNING Freaks
      03-29-2022, 11:19 PM   #23
dmanb2b
Drives: G07, F97, F30, E90, E46, E30
Originally Posted by Info@mad-us.com View Post
Tire pressure is low gotta update your dme.
      03-30-2022, 03:38 PM   #24
SRB440IGC
Drives: 2018 BMW 440i GC
Originally Posted by oem.plus_440gc View Post
You can either send your DME codes to PTF support email or you can use the MHD app and it will show you right there if you are able to flash or if you are locked.
Kern417 on youtube has the video showing it.
Also don't make the same mistake I did and order the Enet cable with adapter before reading that it ONLY WORKS WITH IOS. Good stuff.
      04-02-2022, 05:18 PM   #25
MTWO
Drives: M2
Originally Posted by dmanb2b View Post
Can we stop confusing DMEs produced after June 2020, with the older DMEs? If you have a DME made before June 2020 and it has been locked by the dealer, a $200 bench unlock is all that's needed. Newer DME's, yes outside of the FEMTO/Russia option, choices if any are very limited....for the time being
If you send your DME to PTF they bench unlock free
dmanb2b2124.50
      04-02-2022, 05:19 PM   #26
MTWO
Drives: M2
PTF just pushed an update to and it tells you if you need bench unlock or obd ok or if you need femto
      04-03-2022, 07:23 AM   #27
dmanb2b
Even better
bm3, bmw f30, dme, dme locked, ecu, encryption, mhd, tuning, unlock
