09-15-2020, 03:34 PM | #243 |
Rep 2,369
Drives: E63 645Ci
Just load up a previous version that worked for you on your USB stick and plug it to your unit, exactly as you would do with any update.
09-15-2020, 04:53 PM | #244 |
Rep 28
09-15-2020, 05:22 PM | #245 |
Rep 2,369
Drives: E63 645Ci
09-16-2020, 12:08 AM | #246 |
Rep 11
09-16-2020, 12:49 AM | #247 |
Rep 28
I update to 2.1.0 but still is the same problem with bluetooth. I don't have any idea to solved this. Maybe I do it something wrong
09-16-2020, 01:21 AM | #248 |
Rep 2,369
Drives: E63 645Ci
Check factory settings. If you have BT enabled, disable it, restart, enable and restart again... might help. Also did you install a custom boot animation? If so what was its size and where did you get it from? Did you make one yourself?
09-16-2020, 02:40 AM | #249 |
Rep 28
Ok so I try setup the factory settings and I try also this second metod. Maybe this is helps. I installed custom animation but is still working and it doesnt matter which version I install.
09-16-2020, 02:57 AM | #250 |
Rep 2,369
Drives: E63 645Ci
My only concern with custom boot animations is that from version 1.7.(something) onward, Chinese devs moved location of boot animation and available partition size for it. So if your custom animation is too big it might cause strange issues... and this kinda looks like one of them. Hence my question what size is your animation file.
09-16-2020, 05:08 AM | #251 | |
Rep 28
09-16-2020, 05:26 AM | #252 | |
Rep 1,048
Only real wipe method probably would be a Fastboot-Recovery, but only recommended to to as very last option when a system does not work at all anymore. Kri |
09-16-2020, 05:37 AM | #253 | |
Rep 28
09-16-2020, 06:00 AM | #254 |
Rep 2,369
Drives: E63 645Ci
I would get root permissions and delete boot animation manually first to see if it helps.
EDIT You could first try to clear cash and storage of the BT app in Android Settings > Applications. Last edited by RedErik; 09-16-2020 at 10:55 AM.. |
09-16-2020, 11:48 AM | #255 |
Rep 28
09-16-2020, 12:37 PM | #256 |
Rep 2,369
Drives: E63 645Ci
09-16-2020, 12:49 PM | #257 |
Rep 28
I have root on my head unit but I didn't see nothing. Custom bootanimation is still working.
09-16-2020, 12:51 PM | #258 |
Rep 2,369
Drives: E63 645Ci
09-16-2020, 01:02 PM | #259 |
Rep 28
In this location also is nothing. Folder is empty. but I import another bootanimation and its loaded and now I have another boot animation. One thing I see. Its only one boot animation becouse before was also image before boot animation. What you think to do now?
09-16-2020, 01:09 PM | #261 |
Rep 2,369
Drives: E63 645Ci
So what was it? Boot animation somehow messing everything up? I'm glad you got that sorted but I'm curious what you actually did to solve it. Wzajemne miłego wieczoru
09-16-2020, 01:14 PM | #262 | |
Rep 28
Edited: Now I can download. Something doesn't works but now I download and is works. So now this is also solved. Last edited by Leszek22.06; 09-16-2020 at 01:27 PM.. |
09-16-2020, 01:29 PM | #263 |
Rep 2,369
Drives: E63 645Ci
When you open up Play Store on your phone, go to My apps & games and then Library it should be there. If it's not I will send you a code to get it.
09-16-2020, 01:37 PM | #264 |
Rep 2,369
Drives: E63 645Ci
