12-25-2013, 06:05 AM | #5325 |
Rep 40,665
But if it is visible only with Diagnostic Tools, and nothing on Kombi or NBT displays, this I would not be concerned with.
12-25-2013, 06:13 AM | #5326 |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
12-25-2013, 07:20 AM | #5327 |
Rep 122
Hi again!
Is there anybody here who has working Internet (or just presenting in menu) on NBT running on 51.1 software? Please give me the .NCD file for comparing. I have lost Internet in menu after upgrade the NBT from 48.3 to 51.1. And Internet was working before flashing. Last edited by avgor123; 12-25-2013 at 11:55 AM.. |
12-26-2013, 07:03 PM | #5328 | |
Rep 58
Drives: 435i X-Drive M Sport ('13)
Any feedback / photos? thanks guys! |
12-26-2013, 08:05 PM | #5329 | |
Rep 40,665
12-26-2013, 11:33 PM | #5330 |
Rep 94
Shawn you are the man once again! Followed the steps in your PM and get updated files and a token. I was able to get on and code and everything seemed to go fine. However this time I did all my reading of the modules and edits then I activated the FA and wrote each module one after the other. I have not had time to troubleshoot but everything said it went fine but a few obvious things I tried did not work. Is there an order or only so many I should do at a time? I will go read them back tomorrow and see if the changes actually stuck or not. thanks again shawn!
12-26-2013, 11:36 PM | #5331 | |
Rep 40,665
12-27-2013, 08:45 AM | #5332 |
Rep 94
Sorry for the stupidity but what is the difference shawn? I read the CADLs or whatever the guide said then did edit FDL mad the changes. Activated the FA then did code on each of the ones I had changed. I will look again and get the exact things clicked. Also like when I did kombi etc it did the thing where it said it needed service and time reset etc which makes me think something happened. Anyway now that I am off today I will look at it more and see if nothing worked or maybe just specific things. thanks as always
12-27-2013, 09:10 AM | #5333 | |
Rep 40,665
ECU => Code = VO Code = Encodes entire ECU (all parameters) to predefined values to support all options defined in Vehicle Order. ECU => CAFD => Code FDL = FDL Code = Encodes only individual ECU Parameters with custom values, overriding the predefined VO values.
12-27-2013, 11:45 AM | #5335 |
Rep 22
Thanks for the tutorial worked great! For some reason my coded dvd in motion is not working (everything else does). I set all 3 options (the speed one and the disable park one). i have 2014 320i.. using latest 3.23.4 and latest data files ... my modules also have slightly different names like instead of HU_CIC mine is called HU_NBT ..
12-27-2013, 06:18 PM | #5337 |
Rep 40,665
If you were connected to the car, and wrote FDL Chnages to the ECU, they should stick.
12-27-2013, 06:18 PM | #5338 |
Rep 40,665
12-27-2013, 06:21 PM | #5339 | |
Rep 40,665
Go back and check both Speedlock Werte values and verify they are FF.
12-28-2013, 01:31 AM | #5340 | |
Rep 6
Thanks Shawnsheridan.
12-28-2013, 12:49 PM | #5341 | |
Rep 6
Hi shaw.
Two things: I'm looking for your tutorial but i don't find it. Could you please tell me where is it? I need the last psdzdata. Could you please PM me the last data files.? Thanks Quote:
12-28-2013, 12:54 PM | #5342 | |
Rep 40,665
PM sent.
12-28-2013, 10:26 PM | #5344 |
Rep 40,665
Sorry, but I cannot, as you are still too new to receive PM's. When you can send and receive PM's, send me one.
12-29-2013, 09:18 AM | #5345 |
Rep 4
Hi, Shawn!
I got cable and downloaded Esys 3.18.4 with psdz 47.5 But now i understood, that my car will not work with this version. My F34 was made in october’13. Can you send me esys prog and psdz files which will work with my car? Also i’d like to understand, is it possible to buy token for fdl coding? Thanks! |
12-29-2013, 10:03 AM | #5346 |
Rep 6
Thank´s.
I refer the coding tutorial. "How to change FA in F Series Car". Last edited by motajo; 12-29-2013 at 04:56 PM.. Reason: error |
