View Poll Results: Please answer the following questions: | |||
My F30 335i/335xi has this particular rattle (if so, please check other options as applicable) | 46 | 85.19% | |
Rattle occurs mostly in the first 10 to 15 minutes of driving | 16 | 29.63% | |
Rattle does NOT necessarily occur mostly in the first 10 to 15 minutes of driving | 20 | 37.04% | |
Rattle occurs mostly in winters | 8 | 14.81% | |
Rattle does NOT necessarily occur mostly in winters | 17 | 31.48% | |
Rattle occurs mostly during medium acceleration | 31 | 57.41% | |
Rattle does NOT necessarily occur during medium acceleration | 9 | 16.67% | |
I have the HUD option | 30 | 55.56% | |
I do not have the HUD option | 9 | 16.67% | |
I can make the "rapidness" of the rattle vary with the acceleration(throttle) | 29 | 53.70% | |
I CANNOT make the "rapidness" of the rattle vary with the acceleration(throttle) | 4 | 7.41% | |
I have an 8AT | 38 | 70.37% | |
I have the 6 MT | 6 | 11.11% | |
My issue has been resolved (if so please post what was the resolution) | 4 | 7.41% | |
My issue is still not fixed. | 32 | 59.26% | |
This issue has seriously taken away the joy of driving | 21 | 38.89% | |
This issue has not significantly taken away the joy of driving | 17 | 31.48% | |
Multiple Choice Poll. Voters: 54. You may not vote on this poll |
02-18-2014, 12:17 AM | #23 |
Rep 1,044
So as of now 21 of the 25 people facing this issue still have not managed to get this noise fixed. Is it because you have not yet taken this issue to the dealer or is it because they could not fix the issue?
02-19-2014, 02:08 AM | #25 |
Rep 1,044
Ok, I got my car back today and I drove it for several miles and could not hear the rattle.
As per tech service notes: The rattle was in the dash area. Evaporator was rubbing inside the heater box causing a vibration noise traveling up through the dash. Modified the evaporator by adding felt tape and also around the inlet and outlet pipes. Also the outside of the heater box had to be modified where it was rubbing in spots on the firewall. It may be too soon to rejoice, but initial impressions are what I was hoping for |
02-19-2014, 01:42 PM | #26 | |
E36, E46, E90, E92, F32
96
Rep 368
02-19-2014, 06:22 PM | #27 | |
Rep 88
02-19-2014, 09:19 PM | #28 | |
Rep 4,545
2023 840GC | 2021 740i | 2019 X3
03-27-2014, 04:07 PM | #30 |
Member
Rep 16
Hi,
I'm having the same problem. For me it started after around 600 Km, and it only happens while accelerating in relatively low speeds (say from 40 to 80 km/h). The sound lasts for 1-2 seconds and goes away until same conditions happen again. Turning off the A/C seems to do the trick, so I guess it has to do something with the unit, as also described by others here... http://www.4-seriesforums.com/6-bmw-...dashboard.html This is certainly ruining my driving pleasure, not to mention not being able to enjoy the HK system, as I'm always looking for that terrible noise... |
03-27-2014, 09:21 PM | #31 |
Rep 70
Rattle Fix
Tomerk, see this post, should fix the problem. And certainly spread the word to the 4series forum you are on.
A permanent Fix for the 335i/435i 2500 RPM Rattle/Buzzing/Whirring Noise? http://www.f30post.com/forums/showthread.php?t=949816 |
03-28-2014, 09:59 PM | #32 | |
Member
Rep 16
Now all I have to do is convince BMW IL that there is a problem... I'll keep you posted as soon as I have some news. |
03-31-2015, 04:52 PM | #33 |
Rep 153
Rattle noise is GONE
My new 335i had the very same rattle on acceleration. After way too many trips to BMW service, they actually listened to us and read the posts on this site. There is a kit that is sold by BMW, with a weight that is installed on the a/c hose.
Promise, noise is gone... and thankfully so, as we were at wit's end. If you need the exact kit, post back. |
01-08-2016, 09:14 PM | #34 | |
Rep 728
335i same rattle as the video. Not too annoying as I rarely use the A/C in SOCAL and most times it is minor enough that I can ignore. I thought it was the A/C hose. Dealer installed the house weight, shop foreman still hears noise. Took part of the dash partially apart, and it is the heater box rubbing against the evaporator. Thus far the dealership has done a great job with the car and all its issues. I accredit it to the quality of character of the shop foreman and the service team. Guys are excellent, particularly the foreman from what I have seen dealing with him. Other dealerships would have told me to pack sand. |
01-10-2016, 11:54 AM | #35 | |
Rep 886
It's SIB 64 01 14. See link: http://f30.bimmerpost.com/forums/sho...d.php?t=949816 |
01-10-2016, 11:31 PM | #36 | ||
Rep 1,044
Finally after 3 years of car ownership I can actually enjoy the car whole heartedly. |
