BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9/10 HU theming and discussion
      03-05-2024, 01:11 PM   #1343
pinkycz
Drives: E90,E91, F20
Originally Posted by elshanguliyev View Post
Hello, have a good time.
I connected the computer to the monitor but can't access root.
No matter how hard I tried to get root, it was not possible.
Has anyone encountered such a problem?
Hi,
I have similar unit 825X_Pro with Android13 and run into the same dead end.
Mine is
Tried the PX6 way from the start of this thread as suggested by RedErik
Upon connecting via adb attempting to root I get
Code:
>adb root
cxj said not suport, 88
that's it.
Trying su in shell gives me "su:not allowed"
will be a bit harder to gain root to these HUs I guess
Any ideas appreciated!
      03-06-2024, 04:38 AM   #1344
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
Originally Posted by pinkycz View Post
Hi,
Mine is
Code:
>adb root
that's it.
Your unit is locked down, you would need to root it first. Unfortunately we don't know much about these so can't help you, sorry. Try looking at XDA or 4PDA.ru forums.
      03-14-2024, 09:13 PM   #1345
S EyeLand
Drives: F90 M5C
Hey guys, I bought this screen for my F90. It's great, resolution is crisp, and the OS is very snappy. Anyway, the default boot animation is the only weak point. The resolution claims to be 2560*720 which seems correct. I'm guessing i would have to create a custom animation. Otherwise, the process would be the same?
      03-15-2024, 01:53 AM   #1346
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
That is not a KSW unit. We don't know what the procedure for changing animations is... if there is one at all.
      03-22-2024, 06:23 AM   #1347
pinkycz
I have now managed to get bootanimation working on my 825X_Pro unit (8259 chipset). I bought it from Ali seller SZ-KIANDA Official Store - Shenzen Kianda Auto Electronic Co., Ltd. The unit runs Android13, mine is 8GB Ram, 128GB SDRAM.
Anyone who would like to give it a try, I suggest to read the RedErik post on the first page of this thread related to PX6 units.
My 8259 unit was only playing "android" glowing logo at the boot start. Confusingly, I did not find this being a dedicated bootanimation, it appears the system has none, so this is Android OS default.
You need to be able to establish adb connection to your HU. Follow the guide to the point where there is
Code:
adb root
command. This will probably error as did on my unit, so keep reading.
Enter the following commands:
Code:
adb shell
you will now be in HU's shell and enter
Code:
su @#zxcvbnmasdfghjklqwertyuiop1234567890,.
remount
At this point your will be kicked from shell and back to command line.
Insert the USB disk with your bootanimation.zip file and check how is this udentified under your HU (you can use ES Explorer or similar file epxlorer on your HU).
Reconnect back after remount, you should now have RW access to your HU.
Code:
adb shell
If you haven't identified how is your USB stick recognised on your system, you can now check in shell too
Code:
cd /storage/
ls
My stick is detected as udisk1. As it has two partitions, storage list them as udisk1p1 and udisk1p2. I have stored my boot animation on the primary partition, yours might be different so modify the below to match your input device
Code:
 cp /storage/udisk1p1/bootanimation.zip /system/media/bootanimation.zip
That's it. I did not need to adjust permissions using CHMOD so this was the finish for me.
You can now reboot your unit and your effort be rewarded by desired bootanimation playing.
thanks to RedErik for his work, I hope my bit will allow few more guys to enjoy it on their units too now.
      03-23-2024, 07:49 AM   #1348
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
Code:
adb root
Code:
adb shell
Code:
remount
Code:
adb shell
Code:
cd /storage/
ls
Code:
Excellent work! I will include your guide in the post about changing animations. I'm sure it will help a lot of people. Thanks again for sharing that!
      03-25-2024, 01:22 PM   #1349
ypolyachenko
Drives: 2004 E61 530d
Originally Posted by LuQ View Post
I have Windows 11 Home.
What if I try to change it manually, by factory menu?
I need bootlogo.zip file in OEM folder.
If I make just bootlogo.zip with imagefv.bmp inside, and press "Import", I get information that logo is changed successfully, but really nothing changes, so i think that in bootlogo.zip file should be more specific folders or files (like in bootanimation.zip) to do it right.
I was fighting with bootlogo for some time.
At first, I successfully changed the boot animation part. The rest of the attempts were with a "Success" message, but no real effect.
Then I reset the current boot animation with bootanimation_clear.zip.
Reboot and one more attempt with success for both bootlogo and bootanimation parts.
The content of the OEM folder in my case was
OEM\
imagefv.bmp <-- image created using MaPaint
bootanimation.zip <-- archive created using BootAnimator tool
voila
you can check my bootlogo and bootanimation here
      03-25-2024, 01:28 PM   #1350
ypolyachenko
PX6 guide can you write to me?
Thank you for your help.
Possibly this recent guide will help in your case
      04-20-2024, 06:37 PM   #1351
petrutaursu
Drives: bmw e90
Talking Guys I made a custom M sport animation for bmw
I couldn't find a nice one online so I made my own. Link here: https://youtu.be/bjXrH2QU0o8
      04-28-2024, 05:00 AM   #1352
Meg_the_Face
Drives: 530d F10
Hi, I'm sorry if this has already been asked, but I couldn't find it. Is it possible to install ID8 Theme on my Android 10 SD 625? Thanks in advance
      04-28-2024, 05:11 AM   #1353
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
If you have a native Android 10 unit (i.e. not updated from Android 9), then you can update to the latest A10 version and use the fully unlocked factory config file to enable all UIs. Everything is explained in the first few posts of Android 10 thread.
      04-28-2024, 07:36 AM   #1354
Meg_the_Face
Drives: 530d F10
Hi RedRrik, thank you for the info. I didnt see it sorry, i will have a look. And it is defintive a native android 10 head unit.
      04-29-2024, 03:19 AM   #1355
Meg_the_Face
Drives: 530d F10
Thanks, i have install it
