11-15-2014, 05:22 PM | #23 |
Rep 350
I just installed mine a few minutes ago.
Very easy to do, just route the cables inside the corrugated plastic. Before installing please install EWG firmware and put the values suggested on the BT post. I forgot to double click the start button and got drivetrain malfunction error but that is documented also on the post. Ok, now to the impressions: Power is verryyyy smooth, better than before and stronger in high rpm. I am running map1,downpipe and 91oct total gas and feels great! Recommended to all of you with EWG. Terry great job ! Last edited by K320; 11-15-2014 at 05:30 PM.. |
11-15-2014, 06:20 PM | #24 | |
Rep 992
11-18-2014, 02:30 AM | #26 |
Iron man
24
Rep 137
Is the FF connector still required in order to install the EWG harness?
2013 328i M-sport Totaled|2013 c63AMG|2014 G63AMG|2015 S65AMG|2015 S63AMG COUPE|2009 GL450|2015 fiat 500 abarth|2011 porsche boxster|2012 Lamborghini Gallardo gone but not forgotten|
11-18-2014, 04:04 PM | #28 | |
Rep 1,436
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
11-20-2014, 07:13 PM | #30 |
Rep 992
I will correct which I said map 2 was not faster than map 1. Map 2 seems about 0.2s better than map 1 in 0-60.
I am also thinking that map 2 equates to the stock 335 in 0-60 and 1/4 miles, not map 1. What do you guys think? Last edited by MyFragileHalogen; 11-21-2014 at 03:20 PM.. |
11-24-2014, 11:19 PM | #31 |
Rep 26
Guys,
Please check boost level for those who have the ewg installed and make sure it doesnt overboost. Mine got overboosted to 24 constantly with map 1 and 25.3 at one point causing JB to shut itself down. Becareful people. Matthew |
11-25-2014, 02:01 AM | #32 |
Rep 1,436
you need to send data log for Terry for analysis. so he can come up with new firmware
11-25-2014, 05:59 AM | #34 |
Rep 1,436
11-25-2014, 03:32 PM | #36 | |
Rep 992
I agree that everyone should datalog it after installation. |
11-25-2014, 05:15 PM | #37 |
Rep 152
A workaround for this issue is to lower FF but this may lead to lower boost levels at higher rpm. Do you have decat dp? Post some logs so we can better assist you
11-25-2014, 08:25 PM | #38 |
Rep 350
I believe I need the laptop connected to do some datalogging right? I just connect the laptop for firmware upgrades and to check current map bit never done datalogging. What is the correct procedure to a successful datalog?
11-25-2014, 09:12 PM | #39 |
Rep 992
After it's "connected" to a laptop on JB4 tool, you simply start log (or press F1) and drive while it's connected. A USB extension cable helps. Usually people do 3rd to 4th gear pull. Then hit Stop and Display (F2) and Export Log (F7).
11-26-2014, 12:00 AM | #40 | |
Rep 350
Will do and send log to Terry. |
11-26-2014, 02:01 AM | #41 | |
Rep 26
Matthew |
11-26-2014, 04:25 AM | #42 |
Infidel
122
Rep 1,102
And people wonder why rods are being thrown and what not. you put to much trust in some tune/tuner.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
11-26-2014, 07:28 AM | #43 |
Rep 1,436
yea but it's safe in map 0 which I'm running for a period of time till i take a log & see how it goes. that's why i refused to get a tuner with no customer support. what if it happened with AFE ? how would you know or even adjust it. it's still same principle of tuning so it might happen.
11-26-2014, 08:00 AM | #44 | |
Infidel
122
Rep 1,102
