BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > How to determine if steering wheel has heating?
European Auto Source
      08-03-2017, 11:18 AM   #1
Icon5585
Drives: 2014 335i xDrive
I'm looking at purchasing a sport line steering wheel with paddle shifters off eBay, but can't tell if the steering wheel has the heating element or not. Is there an easy way for the seller to determine if it has heating or not? My current steering wheel has heating and would like to not lose that functionality.
Thanks in advance
EDIT: The steering wheel was not on the vehicle, so the obvious solution of checking for the heating button is out of the question :P
      08-03-2017, 12:14 PM   #2
BMW11
Drives: 3-Series
This is how the seller can check for you if it has heating function: ask the seller to start the car presses the steering wheel heater button if it has one and then places hands on the steering wheel and waits if it gets warm then it has heating if does not get warm then it doesn't have it or is not working. the VIN number code may also tell you
      08-03-2017, 12:17 PM   #3
AudiA4
AudiA4's Avatar
340
Drives: 2014 335i (EB) 6MT, M Sport
The clue would be if the seller's car does NOT have a steering wheel heater button on the side of the column, then his steering wheel would not have the heating element.
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust
2006 E90 330i (Silver) 6MT, Sport
      08-03-2017, 12:47 PM   #4
SteveinArizona
Drives: BMW 330e
+1. If you don't have access to the car to check for the button, but do have the VIN number use this site:
https://www.bmwvin.com/
      08-03-2017, 01:24 PM   #5
BMW11
Drives: 3-Series
oh really, obviously
      08-03-2017, 01:25 PM   #6
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2015 BMW 328i xDrive M-Sport
Other way to check is if the steering wheel has the proper electronics module part number which supports heating - should be the following part numbers:
With Heating and Vibration
61319218379
61317468008
With Heating ONLY
61319218381
61317468009
I actually happen to have a Sport Line steering wheel with heating, paddles and vibration motor for sale
      08-03-2017, 01:39 PM   #7
Icon5585
How convenient , PM Sent and thank you everyone for your help.
      08-03-2017, 01:51 PM   #8
AudiA4
AudiA4's Avatar
340
You went on to describe having them determine if the steering wheel warmed up when the button was depressed...I'm guessing you meant just to verify that it's working correctly.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
