BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Variable BMW High Beam Assistant in USA?
Studio RSR
      01-23-2018, 01:33 PM   #243
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Originally Posted by ktula View Post
Originally Posted by andrewc89 View Post
Yeah, when I press the start stop button i can see the beams move up a bit. Can't really tell if there's any side to side movement.
I have mine configured for so long so I can't even remember how it used to react before enabling VLD. If you have fog lamp, with VLD enabled, I believe turn on/off the fog lamps will cause the headlights to move from side to side.
I have an M2 so no fogs. Oh well I'll just assume the coding worked lol. Thanks for the info. I'll keep an eye out to see if they work while I'm driving at night.
      01-23-2018, 01:50 PM   #244
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
If you have cornering lamps/fogs, if not active before, they will also turn on when turn wheel in garage.
      01-23-2018, 02:04 PM   #245
AndrewC1989
Unfortunately my M2 doesn't have either of those. I'll just have to go for a drive at night and see what happens.
      03-08-2018, 04:33 PM   #246
AndrewC1989
Just incase anyone else stumbles upon this thread wondering the same thing, I did eventually find out how to see if the VLD coding has worked while parked. The headlights have to be set to auto. My issue was that I had them turned on manually because I was coding in the daylight. At dusk, turn the car on, set the lights to auto, and then turn the high beams on and you'll see them move from left to right.
      11-28-2019, 04:18 AM   #247
hokiedood
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
Can anyone confirm whether I can code anti-dazzle on my LCI F30 and have to tunnel effect? I have a 340i produced on 2016-03-11.
I have the following lighting options:
2016 340i | EB | M Sport
      11-28-2019, 09:21 AM   #248
Almaretto
Almaretto's Avatar
2374
Nope. It cannot be done.
