      10-31-2014, 04:26 PM   #7525
shawnsheridan
shawnsheridan's Avatar
Originally Posted by edgargroen View Post
Can i get the links to the latest software?
(F30 320d 2012)
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-01-2014, 08:53 AM   #7526
ascarneiro
Drives: BMW F30 2014
Originally Posted by Frogman View Post
You're probably right. The 5AP and 8S4 are "decode ..." codes. They are codes that disable a feature in the car.
If you don't have those codes, then the feature should not be disabled in your car.
If you have 552 and 5AC, you should have both features enabled already. if not, then there may be something else that is preventing it from working.
Frogman,
Thank for help me.
I take a look on FA of my car, have this:
1CA,1CB,216,230,249,258,2A6,2PA,2XE,320,420,423,42 8,431,481,4AD,4AE,4DL,502,507,520,521,522,544,548, 5AC,606,698,6AC,6AE,6NS,6S3,6VB,7AC,889,8KA,8S3,8S M,8V1
As you can see, the car have 5AC but not 552 (have 522!).
I search for 522 and found this in another topic:
- "High beam assist (5AC), adaptive xenon headlights (522 / 524) are all standard on Canadian F30 / 335's"
Ok, so my car really have 5AC (factory) and the 522 (factory) should be the "adaptive xenon headlights"
It's a lot of terms to light:
- 522 = Adaptive Xenon Headlights
- 5AC = High Beam Assist
- ??? = Active High Beam Assistant
- ??? = Variable Light Distribution
So the the last two of this list are something different of my car have?
      11-01-2014, 12:39 PM   #7527
Frogman
Drives: 2012 F30 328i
Originally Posted by ascarneiro View Post
Frogman,
Thank for help me.
Yeah, sorry, 552 was a typo, it's 522.
I don't see any specific enable codes for VLD or no-dazzle high beams.
As far as I can see, you have everything you need to have these enabled.
      11-01-2014, 01:46 PM   #7528
ascarneiro
Frogman
Thank very much for your time, you help me a lot.
      11-02-2014, 12:06 PM   #7529
Altavista
Drives: 2014 328i
Can someone point me to the links to get the software? I have a 2014 328i.
Thank you in advance.
      11-02-2014, 12:40 PM   #7530
shawnsheridan
PM sent.
      11-02-2014, 01:28 PM   #7531
BimmerNo5
Trinidad_and_tobago
Drives: 328i GT
I'm not sure whether it's ShawnSheridan or Frogman but could one of you please send me the links to the latest software. I already have my ENET cable.
Thanks
      11-02-2014, 01:35 PM   #7532
shawnsheridan
Thanks
PM sent.
      11-02-2014, 05:40 PM   #7533
dwillia4
Drives: 2011 335i Coupe, 2012 X3 28i
Hi. I currently have a 2014 F30. I have esys 3.23.4 and my token is more than a year old and has expired. Can you point me to where I can purchase a new one? My car is still at F020-13-07-503 which is what it was when I coded it last year. I assume that I don't have to change my esys or data versions? Thanks in advance!
      11-02-2014, 08:02 PM   #7534
shawnsheridan
If your I-Level is unchanged, you can keep your current PSdZData.
PM sent.
      11-03-2014, 11:36 AM   #7535
PSILVA
Drives: F31 318dA
Hi, i have the base audio in Europe and i just upgrade de spreakers and add front tweeters, i want the equalizer in the display so i have to code the FA and add the 676 option, does anyone know what more a i have to code?
Thanks
      11-03-2014, 02:48 PM   #7536
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
I tried to find on google, but could not find a answer for sure...
but is it possible if i normal lock the car ( with a single click on the key fold ) or with a single touch on the comfort key ( ribble ) to automatic lock the windows and sunroof ? ( code it )
or do i always have to push 2-3 seconds for it ?
thanks and greets from Holland
Kriszty
      11-03-2014, 06:45 PM   #7537
shawnsheridan
There will always be some delay, and a need to hold the button but you can minimize it by coding FEM_BODY => KOMFORT_SCHLIESSEN => Werte=00.
      11-04-2014, 02:34 AM   #7538
PSILVA
Drives: F31 318dA
Yesterday i try to change the konfortclima to the last memory but someting goes wrong the ventilation speed is on don't turn off, i try to load the original CAFD file and code fdl but the ventilation is on.
Please help
      11-04-2014, 03:05 AM   #7539
kriszty
kriszty's Avatar
329
thx
      11-04-2014, 04:05 AM   #7540
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
Thanks
If you only added tweeters but didn't add an amplifier you don't need code 676.
You can't get an equalizer without adding amplifier connected via MOST bus.
      11-04-2014, 08:22 AM   #7541
PSILVA
Drives: F31 318dA
I think I made a mistake in coding because the ac vent does not turn off, I have the backup files on a usb stick, can you please explain me how to replace the original encoding(step by step please)
The coding is done in the IHKA module.
Thanks
      11-04-2014, 10:25 AM   #7542
shawnsheridan
Thanks
Forget your backup files. Just VO Code IHKA.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on IHKA (the ECU itself not the underlying CAFD) => Select CODE.
      11-05-2014, 03:43 AM   #7543
Jean-Marc
France
Drives: BMW 1M Valencia Orange
Hello,
I am owning a 2014 F30 335Xd. Start/stop is getting on my nerve but my dealer in France is not too helpful... I would love starting some coding.
Could you please tell me were to get recent PSDZDATA Files, E-SYS and token ?
Thanks !
Best regards,
Jean-Marc
      11-05-2014, 04:23 AM   #7544
shawnsheridan
Originally Posted by Jean-Marc View Post
Hello,
Thanks !
Best regards,
Jean-Marc
PM sent.
      11-05-2014, 12:09 PM   #7545
Jean-Marc
France
thanks a bunch !
      11-05-2014, 01:14 PM   #7546
Buckeyes
Buckeyes's Avatar
Drives: 2013 335i M Sport
Hi, I'm very interested in coding and my question is where do I get E Sys? Also what is token and how do I get one? Is it included with e Sys?
Thanks
