08-14-2013, 03:19 PM | #1 |
Rep 35
Winter Tires for F30
Not sure if this was discussed in a different thread but how is the performance of the run flat all seasons in winter that come with the F30? This is will be my first year driving in the Canadian winter and not sure if I should invest in some tires.
What are some good options available and are people going for run-flat winter tires or normal winter tires?
2013 F30 328i Sports Line | Jet Black on Black | Executive + Premium Package
08-14-2013, 03:22 PM | #2 |
Rep 1,805
I would get a set of dedicated blizzaks.
You will enjoy driving in the snow, the car will be unstoppable... The difference is night and day.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
08-14-2013, 04:33 PM | #3 |
Rep 4,721
all depends on whether you drive mostly locals or highways, any hills on your daily drive that that are steep which will then become very slippery in winter conditions. Obviously, dedicated winters are the proper way to go but if you want to save some $, then all season may be your compromised solution.
The issue with xdrive with all season tires is drivers are way too confident of their awd vehicle and the result of driving a bit too fast & thinking it will grip on any road surface conditions. |
08-15-2013, 12:06 AM | #4 |
Rep 267
I am going to buy a set of RFT winters for sure for my F31. I have had a dedicated winter wheelset here in Canada for many years and I would never run A/S tires - well, maybe on the west coast.
I would rather not be stranded with a flat in the winter without a spare. Options are limited. First I am going to wait and see what BMW releases for their winter package in September and go from there. |
08-15-2013, 08:52 AM | #5 | |
Rep 137
Drives: 2016 4 Series
I'm not really worried about a flat tire in winter. A good, dedicated winter tire should last you well into your 4th winter and by that time, it is time to change them anyway. I also have the BMW assist in case there is an emergency and I need a tow truck. |
08-15-2013, 01:28 PM | #7 |
Rep 34
08-15-2013, 02:46 PM | #8 |
Rep 821
08-15-2013, 02:46 PM | #9 |
Rep 821
08-15-2013, 03:17 PM | #10 |
Rep 149
Drives: 2016 340ix Msport mppsk
You can have the best technology in the world but you're only as good as your weakest link. Anything < 7c and as turn into hockey pucks. You wont be able to stop on a dime any longer. What's your deductible? $500 maybe how much would an accident increase your insurance premiums? How much is a set of 4 tires? Doesn't seem that much if you have a car for 4± years. Plus your as tires wi
L last longer. At least in Ontario its optional. i recommend maragoni tires. These guys make amazing tires. http://tyre.marangoni.com/en/Home.aspx Last edited by N33D4SP33D; 08-18-2013 at 10:51 AM.. |
08-15-2013, 03:17 PM | #11 |
Rep 936
08-15-2013, 11:53 PM | #14 | |
Rep 3,523
I am not running RFTs for winter. Not worth it, too heavy and a pain to fix. Had same tires on my M3 for 4 years and had 1 puncture. I ordered a mobility kit and will just take it as it goes. RFT tire risk is just that, risk. I live in a decent area and have a short I commute. Dealers here will get them at $680 a piece. That's crazy money. |
08-16-2013, 09:02 AM | #15 |
Rep 345
I ran Blizzaks on my RWD 335 for years in Ottawa - highly recommended. The cornering and stopping are key. Ordered rims and tires from Tire Rack - delivered to my door - under $2000 IIRC.
This year I swapped my back to my Conti all seasons in a bit early (spring break) for the 335 and we had one last snow fall - scary. I didn't do RFTs - way too expensive. Just kept a can of goop and a compressor in the trunk. I'll be swapping out the 225-45s for 225-50s for the F30 this fall - the rims fit according to the forum.
2017 M240i xDrive Loaded 2013 328 xDrive Premium, Executive 2007 335i Premium |
08-16-2013, 04:40 PM | #16 |
Rep 64
I've been using Blizzak LM-60's on my 335 along with a set of dedicated winter rims. No xdrive here, didn't want it!
Winter doesn't stand a chance against my 335. My car would be an ice sled without the Blizzaks. But it is (almost!) a tank with them on. Also, you might want to consider the Blizzak WS-70 dedicated winter tires for slightly better ice and snow traction compared to the the LM-60 performance winter tires. Nokian Hakka's are also an excellent choice for winter tires. |
08-16-2013, 05:58 PM | #17 |
Rep 2,101
I would definitely suggest a set of winter tires. I am running a set of Michelin Pilot Alpin runflat winters on my F30 and was fortunate that I was able to reuse the style 162 reps from my old E90.
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
08-17-2013, 04:55 PM | #18 | |
Rep 3,523
The WS70 are certainly better but its dry cold road performance is not as good. Last edited by sparkyg; 08-17-2013 at 05:02 PM.. |
08-17-2013, 06:37 PM | #19 |
Rep 1,075
I used Blizzak WS-70's which may have been a slight overkill in TO, but if you ski or go to Ottawa ( I do both ), it performed well. By well I mean as good as expected in snow that "falls" into your car as you open the door. I mean snow that is above the center line of your hub caps and snow that causes your kidney grills to block up.
And I mean well for a RWD MSport, which means you won't get stuck, but you have to drive accordingly to stay out of trouble. My old e90xi felt "unstoppable" but I never faced as severe weather in it.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
08-17-2013, 08:09 PM | #20 | ||
Rep 139
08-18-2013, 04:22 PM | #21 |
Rep 345
I'll likely be doing the Blizzak WS for the 328 -the little bit of extra edge in the really sloppy stuff over the LMs. BTW - anyone want a lightly used set of LMs (4 seasons - maybe 20k on them) - 17" 225-45 non-run-flats - Ottawa area - you're welcome to them - the dealer's likely charging me an environmental disposal fee when I swap them off for some 225-50s. They should be good for at least 1 more season, or perhaps 2. Just ping me.
08-18-2013, 04:41 PM | #22 |
Rep 614
this one got good reviews: http://www.1010tires.com/Tires/Revie...+GSi-5#Reviews
