BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > 2014 F30 LED - Halogen to LED Conversion
      02-03-2016, 03:47 PM   #1
harman.guron
Drives: 2014 328i F30
Smile 2014 F30 LED - Halogen to LED Conversion
Hi Everyone,
Greetings! This is my first post but I have been a visitor here from past three years! I will jump on the topic right away
I recently did the upgrade of my halogen to LED from UMNITZA. I also upgraded my fog lights to HID with ballasts.
Pros:
1. Looks very near to OEM
2. No errors
3. Smooth Installation
4. I will say value for money because I feel like they are worth it.
5. Very bright, crisp and sharp
Cons:
1. LEDs are little on the brighter side but perfect for dark pitch road. The make is LUXEN NHK Canbus.
2. A little flickering on startup which I heard can be fixed by Coding.
Overall I am very satisfied and I was looking for the replacement from a long time.
Pics - https://www.dropbox.com/sh/67wk5qh38...p5Z8W4l5a?dl=0
Another Thread for the same lights: http://f30.bimmerpost.com/forums/sho....php?t=1191601
I am happy to answer any questions or any further information needed
      02-03-2016, 04:01 PM   #2
lesnica
Drives: M4
How exactly do you adjust the lights ?
      02-03-2016, 04:02 PM   #3
harman.guron
It has those screw thing to adjust the beam. I did it once as it was a little off. Very easy to do it.
      02-03-2016, 06:14 PM   #4
Adamr916
Adamr916's Avatar
Drives: 2014 328d
Does it have any kind of decent cut off? I know it won't be xenon type, but as far as the cut off from the halogens to this, was there much of a change? This is the only reason why I'm still up in the air about them is because I don't want it to be a big glob of light off the front of my car like it was when I put led bulbs into my low beams.
      02-03-2016, 06:15 PM   #5
Who?
Who?'s Avatar
485
Drives: F87 LCI
I was afraid of that, mine has beam control next to my steering wheel, and throws an error if i install headlights with manual adjustment
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      02-04-2016, 12:08 AM   #6
ji99lypuff
Drives: 2014 bmw 328xi
the lights look great! They flickr on startup and then dont flickr again? Definitely the best alternative to halogen lights. I bet its so much nicer driving around at night especially with extra hids in the fog lights.
      02-04-2016, 06:59 AM   #7
ATL0501
ATL0501's Avatar
Drives: '21 540 Msport
Looks great man! But question on the fitment..Image 3115 and 3118 (showing comparison of factory halogen vs LEDs) it looks like there is significant gap between hood line and quarter panel to the housing. It doesn't seem to fit into that curve as well. The after picture is also noticeable gap. Are my eyes deceiving me or did this not bother you much?
Bernina Grey Amber Effect 21 540 Msport
Carbon Black/Cognac 21 X3 x30i M sport
Black Sapphire 14 328Xi M sport
      02-04-2016, 08:04 AM   #8
shoguniori31
shoguniori31's Avatar
Drives: 2016 Bmw 428i MT
looks nice. wer did you get them? do they only flicker on start up or even while your driving?
      02-04-2016, 09:25 AM   #9
lesnica
Drives: M4
On my set they flicker on startup for maybe 3 sec, with the exception of 1 that flickers just a bit longer.
      02-04-2016, 11:02 AM   #10
scostu
scostu's Avatar
Drives: 2016 F25
harman.guron
Looks fantastic!
      02-04-2016, 04:37 PM   #11
harman.guron
I didn't see any issue with the cut off or a big glob of light. Like you said they are not xenon and also not completely adaptive, they are very near. I also did a comparison with my buddy's OEM and found it very near.
      02-04-2016, 04:38 PM   #12
harman.guron
Can you fix that with coding? There should be some workaround to that.
      02-04-2016, 04:41 PM   #13
harman.guron
They absolutely are. Yes just on startup and now for some reason I didn't notice any flickering for the past two days
      02-04-2016, 04:44 PM   #14
harman.guron
For me, it was just the one on driver side for maybe 2-3 seconds. I start my car in off position now just so only DRLs are running and switching back to the automatic. Two days in a row I started my car in automatic and there was no flickering so fingers crossed
Do you know whats the technical explanation about it?
      02-04-2016, 04:47 PM   #15
harman.guron
Good observation. I looked at the car again and didn't notice much difference. Maybe its the angle of pic (I am a horrible photographer). I am planning to visit Umnitza again so will check with them as well.
Although it shouldn't have changed as the bumper was fit in the exact same way it was taken off and the lights dimensions are exactly the same. Thanks for pointing it out
      02-04-2016, 04:49 PM   #16
harman.guron
Thank you! Umnitza - Located in Concord CA.
Link for the lights - https://www.umnitza.com/headlights-p...ngel-eyes.html
No they only flicker for about 3 seconds at startup (that also if you have the lights on). If you start at off position and switch to headlights afterward, no flickering at all. Additionally I didn't notice any flickering whatsoever for the past two days.
      02-04-2016, 04:50 PM   #17
harman.guron
Originally Posted by scostu View Post
harman.guron
Looks fantastic!
Thank you so much
      02-04-2016, 04:51 PM   #18
ATL0501
ATL0501's Avatar
Yeah no problem. Keep me updated and if you get chance to post a shot of the lights against a wall from distant. Thanks man. Really considering these!
      02-04-2016, 04:57 PM   #19
jojo7
Drives: F320i
Please, where did you get the led fog lights?
      02-04-2016, 05:28 PM   #20
lesnica
Drives: M4
No clue, one of the beams in the driver side flickers alot longer than usual. I've had them on since late november and nothings changed.
      02-04-2016, 06:40 PM   #21
Sedoy
Drives: F10
What about the brightness, are those lights noticeable brighter than halogen?
      02-04-2016, 07:12 PM   #22
lesnica
Drives: M4
Edit: I tried your way with starting the lights with DRLs only then switching to auto and your right their is no flickering.
f30, led
