BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > 2014 F30 LED - Halogen to LED Conversion
      02-23-2016, 05:27 AM   #45
AdamRichF30
Drives: F30 Sport 318D
please can you upload a video of these headlights in depth?
im really condisdering buying some. Thank you
      03-06-2016, 12:38 AM   #46
harman.guron
Drives: 2014 328i F30
Sorry for the late response. I am not sure if I will be able to post a video with detail review but overall I am very happy with these lights and no issues in two months. They are worth every penny that I spent and car looks complete with these lights
      03-06-2016, 01:17 AM   #47
harman.guron
Originally Posted by Astute_BMW
Do you need coding or get error after fitting? Are they really plug and play which i can do myself?
No errors at all. Its purely plug and play as long as you know how to remove bumper and the headlights. The vendor also told me that they will post tutorials very soon for the complete process
      03-09-2016, 01:28 PM   #48
deejaylew
Drives: 328
No flickering on startup? Iv'e got flickering.
Also I'd like to add that I coded out the checks for low, high and DRL. Not sure if i need to add in the left and right blinkers but it appears the low beam is the light that flickers on startup.
      03-10-2016, 06:53 AM   #49
harman.guron
Very rare. I started starting the car with lights off and turn them on after few seconds. You can turn the flickering completely off by coding but its not worth it.
      03-10-2016, 09:40 AM   #50
scostu
scostu's Avatar
Drives: 2016 F25
You stated you coded the cold/warm checks out....but did you code the low/high bulbs to be LED?
FL_R_KALTUEBERWACHUNG = nicht_aktiv
FL_R_WARMUEBERWACHUNG = nicht_aktiv
FL_R_IS_LED = aktiv
FL_L_KALTUEBERWACHUNG = nicht_aktiv
FL_L_WARMUEBERWACHUNG = nicht_aktiv
FL_L_IS_LED = aktiv
http://f30.bimmerpost.com/forums/sho...g+led+low+beam
      03-13-2016, 11:12 AM   #51
lesnica
Drives: M4
Does anyone know how to code out the flickering on these lights on startup?
      03-30-2016, 01:42 PM   #52
TrickyT
TrickyT's Avatar
Drives: 2015 Alpine White 328i xDrive
I got those from Umnitza as well. The make is Luxen NHK Canbus
Sorry, I just found this for the fogs. Thanks for posting all of this.
https://www.umnitza.com/bixenon-comp...h-options.html
Is that the right one?
Or these
https://www.umnitza.com/luxen-led-he...n-6k-6459.html
      03-30-2016, 06:05 PM   #53
Adamr916
Adamr916's Avatar
Drives: 2014 328d
Or these
Pay the money for the OEM led fog lights, if you purchased the Umnitza LED headlights, they'll match relatively close in terms of looks and color.
      03-31-2016, 09:36 AM   #54
TrickyT
TrickyT's Avatar
How hard is that install? does it require a wiring harness or coding?
I can't find an OEM for the 2015 328i
      03-31-2016, 09:59 AM   #55
Adamr916
Adamr916's Avatar
Drives: 2014 328d
OEM LED fogs
Just like changing out a bulb, no additional wiring from what I've seen, but, like with any led bulb, you will need to code
      03-31-2016, 12:30 PM   #56
scostu
scostu's Avatar
Drives: 2016 F25
DIY install for those from ECS
http://f30.bimmerpost.com/forums/sho....php?t=1027300
      03-31-2016, 04:53 PM   #57
TrickyT
TrickyT's Avatar
Originally Posted by scostu View Post
I have no coding experience and the cost is about 20% more onto my budget.
How would the LED Fogs look/work if I did not code them?
      03-31-2016, 05:49 PM   #58
Adamr916
Adamr916's Avatar
Drives: 2014 328d
They would just flicker on start up and every 10 or 15 minutes if you went the bulb route, the LED assemblies I believe won't function properly if they are not coded.
      04-01-2016, 07:56 AM   #59
TrickyT
TrickyT's Avatar
Umnitza says no flickering and no coding needed (I am getting the anti-flicker harness).
I'll post a thread once they come in and my results.
      04-02-2016, 10:56 AM   #60
harman.guron
Or these
Its the Luxen ones but I PMed you how to find the exact model i have.
      04-02-2016, 10:57 AM   #61
harman.guron
Or these
The luxen one matches pretty close too w/o any need of coding.
      04-02-2016, 11:03 AM   #62
harman.guron
Yep. No flickering for the fog lights
      07-26-2016, 09:37 AM   #63
Elfresh
Drives: 2009 BMW 335i
Originally Posted by lesnica View Post
How exactly do you adjust the lights ?
Wait so its not adaptive LED lighting?
      08-15-2016, 12:37 PM   #64
TrickyT
TrickyT's Avatar
Just a follow up. I got OEM LED fogs, got them installed and coded. Thanks for all the help. Love them with my new Umnitza lights.
f30, led
