      09-13-2014, 03:14 PM   #7261
Pmarszal
Drives: 2011 BMW 528i
I am starting to learn coding and have a question about E-Sys token. DO I NEED IT? I have seen mixed answers and want to find out so i dont screw anything up in my car. I heard you dont need it if you are doing the basic coding like DVDinMotion and such. Is this true?
Pmarszal is offline
      09-13-2014, 03:18 PM   #7262
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
You do not need a Token solution to VO Code.
You do need a Token solution to FDL Code.
Considering 95% of coding is FDL Coding, including DVD-In-Motion, I would say you need a Token solution.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
shawnsheridan is offline   United_States
      09-13-2014, 08:20 PM   #7263
Pmarszal
What will happen when I try to code without token? Brick my car or will it give me an error? The reason I ask is because I dont know if my token is installed properly!
Pmarszal is offline
      09-13-2014, 09:08 PM   #7264
shawnsheridan
You will just get an error code. It won't do any harm.
      09-13-2014, 09:29 PM   #7265
Pmarszal
my token did not include any .jar files. Just .est file that I pointed E-Sys to. Is this the right way to do it?
Pmarszal is offline
      09-13-2014, 09:33 PM   #7266
shawnsheridan
Yes, but it won't work.
You will need to get with your Token solution provider for resolution.
      09-13-2014, 10:12 PM   #7267
shawnsheridan
Originally Posted by efwkm View Post
Hi Shawn,
I have some questions need you help.
1.activate idrive offce
I saw bmw coding datebase has code,idrive office is disabled based on country controllers. this will enables you to have access to the office menu which will be located on the main idrive menu,so need to modify the read FA remove country controller code SL8AX from the vehicle FA then vo code cmb_media and hu_cic.but i find my vehicle FA ,I don't have SL8AX or vo 8AX,what's the SL8AX mean in us bmw vo code?
my f35 vehicle FA salapa-element only has 1AK,1CA,255,2H3,2TB,2VL,3AG,430,488,494,4B8,4DM,50 2,522,534,544,548,5AH,609,676,6NK,6UH,6VA,6WA,702, 7K4,7S2,825,866,878,892,8AA,8KE,8SD,8SM,8IN,993.I searched bmwvin code P7K4A description means CKD CHINA HIGH,is this country controller?
I removed 7K4 from FA and try to vo code HU_CIC CMB_MEDIA, code HU_CIC MACRO_PIM > AKTIV , HU_CIC=>3003 SYSTEM_EINSTELLUNGEN=>COUNTRY=hongkong,after that,still no office menu show on idrive menu,do i miss something?
2.I saw a video ,that f30 changed vehicle emergency lights double flash,it's very personality,but i searched in f30 Fem_body ,it doesn't has DOPPELBLINKIMPULS_WARNBLK code which can change car emergency lights double flash,can we has it?and i searched key words BLINK in the fem_body module which code is correct to change the double flash ?
thanks.
For Office on China Spec CIC, remove remove 8AA, Leave 866, and VO Code HU_CIC, then FDL Code HU_CIC => NAVI_VARIANTE = china. For NBT, it should work with 8AA.
I have never found a way code the double blink flashers.
      09-14-2014, 12:31 AM   #7268
Pmarszal
What is the legality of coding your car? Is it legal? Will BMW take me court if this is done?
Pmarszal is offline
      09-14-2014, 02:06 AM   #7269
shawnsheridan
It's your car. You can do whatever you wan't to it. Why would they sue you?
Now if you somehow "break" the car coding it, and they can pin it on your coding, they may refuse to repair it under warranty.
      09-14-2014, 04:30 AM   #7270
williammm
Drives: F30 328i
Shawn, how can we prevent ourselves from "breaking" the codes?
Is there a way to "restore" back to normal?
williammm is offline
      09-14-2014, 04:33 AM   #7271
shawnsheridan
Load factory FA, VO Code ECU(s) to restore factory settings.
      09-14-2014, 10:29 AM   #7272
BeVeRM
Drives: F31
Originally Posted by IainSmith View Post
Hello All
ive coded a fair bit of my F20 M135i June 2014 now with success, however there are a couple of things which aren't 'working' or failing to find the option to code.
I have bus nav with HU_champ2
FIRST ISSUE
Ive coded for BMW Live and although i now see the items available, and also done the required update. when i try to access e.g.: the internet i get a error message back, and when i select BMW live it states it was not purchased as part of the car order? Details Below
I see under the available options status Internet and BMW Live. But yet when i select internet it is still stating a browser error. <Application error in Browser please try again or restart the application>
Also when i select BMW Live it messages with <this is an optional service that has not been purchased for this vehicle>
Under available services for the vehicle are
Assist My Info
Assist traffic information
Assist Emergency Call
Automatic tele service call
BMW Live
BMW Mobile Care
Battery Guard
Door Unlock
Internet
Teleservice Report
Vehicle finder
SECOND ISSUE
I thought id be able to change the Idrive/connected start up image to the M logo image. (Im sure I've seen the option but i can't find it on my car. <another forum member 'wibbles' has said this is only a option on the ProNav?> can anyone confirm this?
Third Issue
I want the car to remember the last damn setting on the AC.. and the code line is
IHKA 3002 OFF_MEMORY Air Conditioning will remember if ‘Off’ or ‘On’ from previous shutdown.
yet i can't find this on my car??
last Issue
I wanted to get the weather reading option on the screen, and i think its an option to do. advise would be great.
Thank you all in advance
Regards
Iain Smith
Hi Ian
Have you solved the BMW live and internet problem? I'm facing the same...
BeVeRM is offline
      09-14-2014, 02:27 PM   #7273
marcu
Drives: 335i High Exec Saphire Black
Shawn, could i get access to the software/token?
Much appreciated!
marcu is offline
      09-14-2014, 09:53 PM   #7274
brunoprado
Drives: Ex 135i now M235i and 320i
Help with installation
Hello folks
Good night for everyone
my name is Bruno i have been on this fórum from long time, but just now i bought another bmw 320i and im totally lost about install the Esys program, can someone help me please
i already tried to search in older posts but i did not find =/
thanks a lot
brunoprado is offline
      09-14-2014, 10:33 PM   #7275
shawnsheridan
Originally Posted by brunoprado View Post
Hello folks
thanks a lot
PM sent.
      Yesterday, 07:59 PM   #7276
shawnsheridan
Much appreciated!
PM sent.
      Yesterday, 08:38 PM   #7277
Aritaurus
Aritaurus's Avatar
Drives: 2012 328i Luxury Line
Hey Shawn, can I get the download links to 53.5 lite? Thanks!
2012 328i Luxury line | 03/12 production | Premium Package| Saddle Brown Dekota Leather
Mods
M Performance Grilles | M Sport Steering Wheel | NBT Navigation | Touch Controller | 6NR BMW Apps | 655 Satellite Radio | 2TB Sport Automatic Transmission with Paddles
Aritaurus is offline   Canada
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
