02-08-2015, 08:28 AM | #245 | |
Rep 29
FlorinQCK-2.50 |
02-08-2015, 08:31 AM | #246 | ||
Rep 1,894
FlorinQCK-2.50 |
02-08-2015, 12:23 PM | #247 | |
Rep 84
520i Touring
FlorinQCK-2.50 |
02-08-2015, 01:32 PM | #249 | |
Rep 29
do you have a link for the 2014-2 Europe Premium maps? I can find the -1 but not the -2 doing the google searches. Thanks for the help. |
FlorinQCK-2.50 |
02-14-2015, 03:50 PM | #251 | |
Rep 985
Drives: 08 M5 Sapphire Black
Yes, make sure the emulator is not plugged in.
FlorinQCK-2.50 |
03-04-2015, 08:10 PM | #252 | |
Rep 3
FlorinQCK-2.50 |
03-04-2015, 08:25 PM | #253 | |
Rep 41,034
FlorinQCK-2.50 |
03-05-2015, 09:55 AM | #254 |
Rep 3
Good point, lol, I am a newbie at this, appreciate your patience. So looks like my other option is to try to connect to the car through the fsc generator, described in the youtube and posted in the beginning of this forum. I bought an ENET cable, do you know if it will work. Also, it looks like i will have to install inpa that comes with EDIABAS. Do you know of any reliable links? I dont need a latest version just something that will get me connected to the car. I have access to both 32 and 64 windows. Thank you!!!
FlorinQCK-2.50 |
03-05-2015, 12:01 PM | #255 | |
Rep 41,034
ENET Cable is for Fxx car only. For Exx you need DCAN Cable. That said, SWID Reader with DCAN doesn't not work, which leaves only expensive ICOM Interface to read 1B file from CIC in Exx car.
FlorinQCK-2.50 |
03-13-2015, 02:38 AM | #257 | |
Rep 235
Drives: 2014 F31
I copied api32.dll to c:\windows\system because i was getting an api32.dll not found error when i ran SWID_reader.exe. As soon as i removed it from c:\windows\system, this error went away. Then i went ahead and fixed the api32.dll not found error by adding c:\ediabas\bin to PATH in system variables. |
FlorinQCK-2.50 |
03-15-2015, 12:31 PM | #259 |
Rep 41,034
I assume by "code" you mean Map and Upgrade Index:
2014-1 = 00280007 2015-2 = 0028000A.
FlorinQCK-2.50 |
03-16-2015, 02:50 PM | #260 | |
Rep 42
Anyway, I'm not able to obtain a fsc code. I'm using a diy find on e90post, the post was suppressed but I have a copy of the web page. I had to edit a "data03" file found in "/mnt/hbdebug/” with an ENET cable. I'm suppose to use this edited file (save as "a.hex") with the fsc.bat edited with the region code you gave me, to obtain a "code.txt" which is still empty. I know I'm not in the E90 forum but if someone has an idea |
FlorinQCK-2.50 |
03-25-2015, 07:01 AM | #261 |
Rep 4
Hello,
I always get the message that the ignition is off in the SW ID reader. Is it because I'm connected to my E87 via OBD2 cable? I have not found any clear statements if an ENET cable is a prerequisite for this or if this is possible via OBD2 cable too. Thanks in advance for any hints. Last edited by elefum; 03-27-2015 at 04:10 AM.. |
FlorinQCK-2.50 |
03-30-2015, 10:11 AM | #262 |
Rep 150
Hey all,
I feel like I'm very close but just can't quite get there... I have a 2013 F10 with NBT maps I have the North America Next 2015-2 Maps I have generated an FSC file from my car using an ENET cable I converted it to base64 The file loads properly into the FSC Generator Problem: The FSC generator I have does not list 'North America Next 2015-2', only 2015-2. I've tried updating the lookup.xml file and adding an entry for 2015-2 which does generate codes but none of them have been valid. Can someone share the correct XML block for the Generator for 'North America Next 2015-2' ? If I've left out any information that might be helpful please let me know... EDIT: I found this block that someone used for the same maps I'm trying to use... <SgbmId id="NAVD_000014B8_255_002_162" SWID_FscShort="00A80007" name="Road Map NORTH AMERICA Next 2015-2" supplier="TAS" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> I did also use '00A80007' for the FscShort, but I'm not entirely sure where to derive the SgbmId from. I understand that it comes from the maps but where? It does seem that this number is only one digit different than the 2015-1 so that would make sense... Anyone know for sure? Last edited by flip; 03-30-2015 at 10:34 AM.. |
FlorinQCK-2.50 |
03-30-2015, 11:17 AM | #263 | |
Rep 1,894
Anyway the xml above looks good to me. |
FlorinQCK-2.50 |
03-30-2015, 11:45 AM | #264 | |
Rep 150
FlorinQCK-2.50 |
