12-03-2014, 02:01 PM | #23 | |
Rep 1,893
12-27-2014, 10:32 PM | #24 |
Rep 34
I have the blackvue 2channel dashcam on order and wondering which fuse location to best tap into when deciding to hardwire with a power kit (motopark multisafer) unit.
MY15 320 will arrive next month so just pre-planning ahead. Owner's manual mentions two fuse box location: engine compartment area and cargo area. Most likely would use the fuse box in the cargo area for easy access/install. |
12-31-2014, 09:36 AM | #26 |
Rep 633
Looks like it's the second from the bottom left on the card, but it is marked as underside / service.. that would typically mean it has an inline fuse somewhere, but it's not a number on the fuse box..
The steering wheel has 48 & 55, but whether or not either one is the horn is not clear. The horn is not likely wired directly to the horn button, it likely goes thru a relay, so the draw will be less than 5 A at the wheel, which would fit that side of the circuit as 55. But that's a guess. The other side of the circuit is likely some inline fuse, but it's certainly not on the stuff printed on the card.
01-29-2015, 02:26 PM | #28 |
Rep 71
Lots of fuse assignment knowledge in this thread! Can someone tell me what fuse location is used for the colored ambient lighting on the door panel?
01-29-2015, 03:30 PM | #29 |
Rep 633
The Lighter fuses should be.. I don't think they are timed, but you can check that by hand. That would be 66 and 69 in the front and 162 in the trunk.
01-30-2015, 12:25 AM | #30 |
Rep 187
04-22-2015, 10:51 AM | #32 |
Rep 633
The 'Car-on-hoist' icon means it's not on the main fuse panel(s), which suggests that it is a dealer service item ... might be inline.
05-11-2015, 03:06 PM | #33 | |
Rep 2,438
The thing is that I did all hardware retrofit, and now need to connect wiring though dont know where, to which box etc. |
05-23-2015, 04:03 PM | #34 |
Rep 1,607
Drives: 2020 M8 Comp First Edition
Can anyone please help which fuse powers the amplifier in the car. I have a f10 but same fuse box and hifi system.
Found it guys fuse 185 |
05-30-2015, 09:10 PM | #35 |
Rep 140
Drives: F80, G01
I'm hardwiring a dashcam (blackvue 650) in my car (f30) and using a powermagic pro. I heard there are some issues but it came as a bundle. I'm trying to see what the issues are.
But I've currently wired it into the following fuses. 161 (headlights) for the always on 162 (rear cig lighter) for the ACC+ That sound about right? Or should I look for something with less amps? |
12-21-2015, 09:23 PM | #36 |
Rep 3
Did you ever find out what fuse the door lighting uses? I have been searching for weeks and my new lighting is finally coming in tomorrow and I would like to tap the fuse so the extra lighting turns on an off the same time as these lights. Thanks
01-18-2017, 10:59 AM | #38 |
Rep 633
It looks like you have a 2017 120D.. The fuse maps I have are for an F32, if you look back up the thread. For the F32, Fuse 80 is located in the trunk (I guess that's the boot to you) wheel well*. Look on your fuse card to make sure it's in the same place.
Last edited by Lost Horizon; 01-18-2017 at 11:04 AM.. Reason: * Oops.. corrected |
01-18-2017, 11:05 AM | #39 | |
Rep 10
01-18-2017, 11:15 AM | #40 |
Rep 633
Sorry.. I saw you just joined in 2017. Leaping assumption. It looks like it is fuse 80 by the symbol. I corrected my email above on the location for fuse 80, which is by the battery, as I recall. I'm working off a phone in Hawaii, so that's my excuse and I'll stick with it. Does that help?
01-19-2017, 05:40 AM | #41 | |
Rep 10
I couldnt find the fuse 80 in the boot (Trunk) I saw the fusebox underneath the floor panel in the boot but it was not matching up with the fuse card. Weird. |
01-19-2017, 11:13 AM | #42 |
Rep 633
Did you look in the wheel well panel in the boot? (i.e., problem solved?)
10-26-2018, 02:08 AM | #44 |
Rep 1,045
does any one know what the fuse # is for the rear camera and rear electronic module? My rear camera image turned upside down on the screen, its a known glitch, i want to pull the fuse to the REM abd camera to reset it.
Mods: Dinan Tuned, Intake, Catless DP
