08-29-2015, 05:14 PM | #1 |
Rep 125
"Required" Maintenance at 73,000
Hey guys, my 2012 335i is telling me that I'm due for a service visit, but I am hesitant to go to the dealership and essentially write them a blank check by asking them to do what whatever they're supposed to do...
My question is this: what is it (if anything) that I *really* need to do? Or in other words, what is it that if I don't do it, I'm putting myself in danger or significantly increasing the risk of a costly repair? The car is running perfectly, I just changed the oil, and the brakes are all fine. The 73K miles are almost all highway miles. Thanks! |
08-29-2015, 05:22 PM | #2 |
Rep 4,323
Plugs? Water pump? We have no insight without knowing your prior maintenance history.
08-29-2015, 06:57 PM | #3 |
Rep 2,290
Taking it in doesn't mean they're going to run all the repairs and send you a bill. There is probably a minimum required to take it in and at least get it checked out (1 hr of labor is my guess?).
Often ignoring maintenance and repairs only means it's going to cost you more down the line, so I would at least get it checked out. |
08-29-2015, 07:04 PM | #4 | |
Rep 125
-- The microfilter was replaced at 20K -- Brake fluid flushed at 20K I think that's it, aside from oil changes, wipers, recall items, etc. |
08-29-2015, 11:54 PM | #5 |
Rep 807
08-30-2015, 03:00 AM | #6 |
Rep 15,858
What is showing up as required on the car's vehicle information list (via iDrive)? Should spell out exactly what is being called for. Dealer can also read the key and get the list.
HighlandPete |
08-30-2015, 09:10 AM | #7 |
Rep 125
I'll double-check later, but I believe it's just saying that it's time for service in general; it's similar to when it says it's time for oil service or brakes or whatever, but it's not pointing out anything specific...
08-30-2015, 09:27 AM | #8 | |
Rep 15,858
HighlandPete |
08-30-2015, 09:34 AM | #9 |
Rep 125
08-30-2015, 09:13 PM | #10 |
Rep 125
OK, so I checked the vehicle status menu and there is no specific item in need of service... Engine oil is "OK", as well as front brake pads, rear brake pads, and brake fluid. "Vehicle check" has a little "warning icon" next to it, and when I select it, it says "Vehicle check overdue! Please make an appointment with your service center."
Thoughts? Thanks again! |
08-30-2015, 10:32 PM | #12 |
Rep 522
Is there a recurring problem with the oil filter housing on the F30s?
2017 430i GC
2013 335i 2004 330ci 2003 330xi (Forever in my heart ) |
08-31-2015, 09:12 AM | #13 |
Rep 1,590
You know that you can always go to a reputable local European indy garage and get it checked there, right? Then you don't have to worry about exorbitant dealer charges.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
08-31-2015, 12:31 PM | #15 |
Rep 125
Thanks for the feedback, guys...
Spark plugs have not been changed; the microfilter is the only "non-fluid" part that's been changed. Yes, I was thinking I might go to an indy garage; I was just wondering if there were any "must-do" preventative items that you all would recommend... I don't mind doing most stuff myself; I just don't necessarily know what it is that I need to do! Thanks again! |
08-31-2015, 12:57 PM | #16 | |
Rep 1,503
Other than those things, have your indie check all the belts, hoses, and other rubber parts for wear and cracking. Also suspension components and mounts should also be checked. |
08-31-2015, 01:34 PM | #17 | |
Rep 125
Hey, since we're chatting, I'm gonna hijack my own thread with a new question... I've noticed that my fuel efficiency has dropped some over the past year or two... I used to get ~33-34 MPG highway and now I'm down to ~29-30 MPG. Tire pressure is OK. No change in driving conditions. Are there things that would be likely to cause this? Thx! |
08-31-2015, 03:27 PM | #18 |
Rep 369
Might add fuel filter to the list, assuming there is one. It was cheap and easy to do in my Audi.
Also, guessing a high compression turbo likely needs new spark plugs a bit more often than the ole NA straight 6.
2013 328i 6MT
1995 S6* 1993 S4* 1984 944* 1988 16V GTI* |
08-31-2015, 03:41 PM | #19 | |
Rep 1,503
08-31-2015, 04:09 PM | #20 |
Rep 15,858
I'm surprised if a 335i doesn't have an air filter element every second oil service, same for plugs. It is listed as such for the 535i (same N55 engine) in the service requirements. My car had plugs and air filter at less than 26k miles, as part of the 4-year service interval, it is part of the condition based service requirement.
It also had the Vehicle Check Service, which is IMO, part of what used to be BMW's 'Inspection II' the "big service", between basic oil services. HighlandPete |
08-31-2015, 08:11 PM | #21 | |
Rep 1,366
For in-cylinder fuel injectors one might be a bit flaky but they aren't cheap so either wait until you throw a code or get them tested. Coil packs were a frequently replaced item on the 135 so i wonder if they might be an issue here. In the 135 flaky ignition coils resulted in hesitation as the car climbed the gear range. Does the car not accelerate as smoothly as it once did? Coil pack. Plugs? Sure. As for transmission oil, get as much info as you can. The 'wrong' oil can kill an auto tranny. Good luck and post back what worked. |
08-31-2015, 09:27 PM | #22 |
Rep 125
Thanks again, guys, for the continued comments... I'm thinking that getting things checked out by an indie shop might be the best way to go...
On a side note, the car runs and accelerates smoothly and no codes are being thrown, so I'm thinking my coil packs are OK... I've always assumed that the plugs are OK if the engine is running smoothly, but to be honest, I don't know what a bad plug feels like... (And interestingly, I've had four bimmers--two with over 100K--and have never changed a plug!) |
