04-23-2019, 04:49 AM | #14455 |
Rep 29
Hi, I have a F31 from 2013 and need to do some urgent coding but no connection with the car.
I installed everything on my pc with WIN7 (Esys v.3.27.1, Launcher Premium 2.0, realm crack and PSdZData_Lite according to shawns pm) and seems to work ok but the car does not seem to make a connection. No ZGW available. I can't see a VIN code appearing in the ESYS selection/start screen. Connection via UTP cable + OBD cable from aliexpress. All options appear and I can choose 'F020' for my F31 so the Psz data seems ok I guess..? When refresh nothing happens.. I get an error connection code C:0027? Only an orange led appears in the utp cable. Can someone help my because my car is flickering like a Christmas tree with all the LCI LED updates.. Last edited by FrederikD; 04-23-2019 at 05:36 AM.. |
04-23-2019, 07:11 AM | #14456 | |
Rep 40,774
1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good and making good contact in OBDII Port 3) Car must have proper voltage (Make sure motor is running if car is not on a Charger). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it)
04-24-2019, 03:45 AM | #14457 |
Rep 102
Coding advice
Hi.
I'm new here and new to coding and eager to learn. I have just got the I Car pro by Vgate and purchased the bimmercode app. I have tried it to code some basic changes with mixed success. Some changes have worked, others haven't. I have an F33 convertible with memory seats and auto dimming/dipping mirrors. I am about to fit power fold mirrors and the switch this week and wondered if I will be able to code them via bimmercode, or if I will need to get them coded at a local indy garage? Any advice welcomed |
04-24-2019, 11:22 AM | #14458 | |
Rep 17
Found this thread, sorry to dig it up. I have an F30, and I need to change my battery capacity. If I understand correctly, I can simply go to FEM_BODY and change the KLASSE_BATTERIE, then select code FDL. Is there anything else needed for this? Also, why would I change the VO if it is so easy to change the FDL code? Thanks! |
04-24-2019, 12:12 PM | #14459 | |
Rep 40,774
After Coding, you need to Register the battery with ISTA.
04-24-2019, 06:35 PM | #14460 |
Rep 17
shawnsheridan
Okay, another question for this obvious noob. The guide I'm following says after I change the VO all I need to do is select the module that was changed and click code. Question is, how do I know all of what was changed...like which modules. I guess in this case, specifically the battery change I made. Also, side question... how come cheat codes loads for all except FEM_BODY. I looked in the xml, I know there are cheat codes in there. As always, thank you very much for you knowledge!! |
04-24-2019, 08:35 PM | #14461 | |
Rep 40,774
I have no idea why FEM Cheat Code won't load.
04-27-2019, 12:30 PM | #14463 |
Rep 40,774
04-27-2019, 02:43 PM | #14465 |
Rep 40,774
04-28-2019, 11:49 AM | #14467 |
Rep 40,774
PM sent.
04-28-2019, 01:42 PM | #14468 |
Rep 1
Shawn - you've helped me before with coding a 2016 F10 I had and appreciated the help. Sorry in advance for the long post. Now, on to my new problem (project?):
I'm in the process of retrofitting a NBT system (HW31) from a European F10 into a Range Rover L322 with bimmerretrofit system. Because it's a retrofit into a non-F series vehicle, I'm connecting via TCP (169.254.199.99:6801) and Series, I-step is chosen. I am connected via a hardwired ethernet cable to the quadlock harness. Target selected is F010. Lower right says HTTP Connected. Using E-Sys, I was able to read the VIN from the donor NBT head unit using the FSC function (so I assume I'm actually connecting to the NBT unit - if I'm not, please correct me). I'm using E-Sys 3.31.0 via Launcher Pro 3.0.4.90. I believe I have PSDZData level 52.0 (under F010 there is a folder with the title "F010_18_03_520_V_001_000_000"). When I try to do anything else, I receive the following errors: I have received error C061 when attempting to write the FA. Code:
Write FA failed! [C061] negative response error: code: the result contains an error description: Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=53327][ErrorCodeDescription=service execution failed][VendorCode=32768][VendorCodeDescription=VCI-specific error (WRONG_TARGET) occured: 67][InterfaceErrorCode=0x43][InterfaceErrorCodeDescription=interface-specific error]; LinkName: VCM_ETHERNET severity: ERROR [2130759759] HW-Interface Error [67] com.bmw.esys.domain.psdz.PsdzException: Write FA failed! [C061] at com.bmw.esys.domain.psdz.Psdz.writeFA(Psdz.java:1461) at com.bmw.esys.domain.fa.FalLogic.writeFa(FalLogic.java:189) at com.bmw.esys.gui.fa.FalController$FaReadWriteController.doWrite(FalController.java:229) at com.bmw.esys.gui.DefaultReadWriteController.write(DefaultReadWriteController.java:104) at com.bmw.esys.gui.vcm.VCMController.writeVCMFaFp(VCMController.java:546) at com.bmw.esys.gui.vcm.VCMFaFpVinMasterView$WriteAction.doActionPerformed(VCMFaFpVinMasterView.java:148) at com.bmw.esys.gui.AbstractView$AbstractGuiAction.actionPerformed(AbstractView.java:234) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289) at java.awt.Component.processMouseEvent(Component.java:6533) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: negative response error: code: the result contains an error description: Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=53327][ErrorCodeDescription=service execution failed][VendorCode=32768][VendorCodeDescription=VCI-specific error (WRONG_TARGET) occured: 67][InterfaceErrorCode=0x43][InterfaceErrorCodeDescription=interface-specific error]; LinkName: VCM_ETHERNET severity: ERROR Timestamp: Sun Apr 28 11:54:11 PDT 2019 ID: 2130759759 Class: com.bmw.psdz.vehicle.connection.util.ResultUtil ExecutionContext={category=VEHICLE, ecuid=(VCM,0x10),PSdZEvent={message=MCDDiagService<id=46900, job=com.bmw.psdz.jobs.programming.zgw.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=VCM_ETHERNET>, timestamp=Sun Apr 28 11:54:11 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=46900, job=com.bmw.psdz.jobs.programming.zgw.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=VCM_ETHERNET>, timestamp=Sun Apr 28 11:54:11 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=46900, job=com.bmw.psdz.jobs.programming.zgw.MCD3_GetSVKfromECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=VCM_ETHERNET>, timestamp=Sun Apr 28 11:54:11 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=36900, job=com.bmw.psdz.jobs.programming.zgw.MCD3_GetSVKfromECU, service=RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession, description=error: timeout, link=VCM_ETHERNET>, timestamp=Sun Apr 28 11:54:11 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null}}MCD Error Code: 0xd04fMCD Error Code Description: service execution failedVendor Code: 0x8000Vendor Code Description: VCI-specific error (WRONG_TARGET) occured: 67 at com.bmw.psdz.vehicle.connection.util.ResultUtil.checkResponsePositive(ResultUtil.java:75) at com.bmw.psdz.vehicle.connection.util.ResultUtil.getPositiveResponseOrTerminateOnError(ResultUtil.java:175) at com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper.terminateOnError(LegacyJobWrapper.java:666) at com.bmw.psdz.vehicle.configuration.jobs.VehicleConfigurationJobs.requestSVKfromECU(VehicleConfigurationJobs.java:106) at com.bmw.psdz.vehicle.configuration.jobs.VehicleConfigurationJobs.requestSVKfromECU(VehicleConfigurationJobs.java:54) at com.bmw.psdz.programmer.behavior.impl.SecurityBAImpl.signVCMData(SecurityBAImpl.java:162) at com.bmw.psdz.programmer.behavior.impl.SystemFunctionBAImpl.writeFAtoVCM(SystemFunctionBAImpl.java:150) at com.bmw.psdz.programmer.facade.ProgrammerImpl.systemFunction_writeFAtoVCM(ProgrammerImpl.java:958) at com.bmw.psdz.vcm.facade.VCMImpl.writeFA(VCMImpl.java:302) at com.bmw.psdz.facade.VCMBF.writeFA_aroundBody4(VCMBF.java:46) at com.bmw.psdz.facade.VCMBF.writeFA_aroundBody5$advice(VCMBF.java:84) at com.bmw.psdz.facade.VCMBF.writeFA(VCMBF.java:1) at com.bmw.esys.domain.psdz.Psdz.writeFA(Psdz.java:1459) ... 43 more Code:
Runtime error occurred. See "Details >>" or log file for more information. [C027] java.lang.ClassCastException: com.bmw.esys.domain.svt.cmp.TSVTCompare cannot be cast to java.io.File at com.bmw.esys.gui.AbstractTreeController.prepareModule(Unknown Source) at com.bmw.esys.gui.control.EsysController.prepareModule(Unknown Source) at com.bmw.esys.gui.control.EsysController.doOpenModule(Unknown Source) at com.bmw.esys.gui.control.EsysController.openModule(Unknown Source) at com.bmw.esys.gui.svt.SvtCompareController.editFdl(SvtCompareController.java:1121) at com.bmw.esys.gui.svt.SvtCompareView$EditFdlAction.doActionPerformed(SvtCompareView.java:361) at com.bmw.esys.gui.AbstractView$AbstractGuiAction.actionPerformed(AbstractView.java:234) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289) at java.awt.Component.processMouseEvent(Component.java:6533) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) And the following two errors when trying to Read FA event though I've loaded the FA generated from the donor VIN and FP calculates: Code:
Read FA failed! Possibly there is no FA stored in the VCM. [C060] negative response error: code: the result contains an error description: Service RDBI_FA has error in result: [Severity=2051][ErrorCode=53327][ErrorCodeDescription=service execution failed][VendorCode=32768][VendorCodeDescription=VCI-specific error (WRONG_TARGET) occured: 67][InterfaceErrorCode=0x43][InterfaceErrorCodeDescription=interface-specific error]; LinkName: VCM_ETHERNET severity: ERROR [2130759759] HW-Interface Error [67] com.bmw.esys.domain.psdz.PsdzException: Read FA failed! Possibly there is no FA stored in the VCM. [C060] at com.bmw.esys.domain.psdz.Psdz.requestFA(Psdz.java:1423) at com.bmw.esys.domain.fa.FalLogic.readFa(FalLogic.java:96) at com.bmw.esys.gui.fa.FalController$FaReadWriteController.doRead(FalController.java:214) at com.bmw.esys.gui.DefaultReadWriteController.read(DefaultReadWriteController.java:75) at com.bmw.esys.gui.ReadWriteSupport$ReadAction.doActionPerformed(ReadWriteSupport.java:93) at com.bmw.esys.gui.AbstractView$AbstractGuiAction.actionPerformed(AbstractView.java:234) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6533) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: negative response error: code: the result contains an error description: Service RDBI_FA has error in result: [Severity=2051][ErrorCode=53327][ErrorCodeDescription=service execution failed][VendorCode=32768][VendorCodeDescription=VCI-specific error (WRONG_TARGET) occured: 67][InterfaceErrorCode=0x43][InterfaceErrorCodeDescription=interface-specific error]; LinkName: VCM_ETHERNET severity: ERROR Timestamp: Sun Apr 28 10:58:03 PDT 2019 ID: 2130759759 Class: com.bmw.psdz.vehicle.connection.util.ResultUtil ExecutionContext={category=VCM, ecuid=(VCM,0x10),PSdZEvent={message=MCDDiagService<id=258900, job=com.bmw.psdz.jobs.uds.vcm.MCD3_ReadFAFromVCM, service=RDBI_FA - ReadDataByIdentifier Fahrzeugauftrag, description=error: timeout, link=VCM_ETHERNET>, timestamp=Sun Apr 28 10:58:03 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=36900, job=com.bmw.psdz.jobs.uds.vcm.MCD3_ReadFAFromVCM, service=RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession, description=error: timeout, link=VCM_ETHERNET>, timestamp=Sun Apr 28 10:58:03 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null}}MCD Error Code: 0xd04fMCD Error Code Description: service execution failedVendor Code: 0x8000Vendor Code Description: VCI-specific error (WRONG_TARGET) occured: 67 at com.bmw.psdz.vehicle.connection.util.ResultUtil.checkResponsePositive(ResultUtil.java:75) at com.bmw.psdz.vehicle.connection.util.ResultUtil.getPositiveResponseOrTerminateOnError(ResultUtil.java:175) at com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper.terminateOnError(LegacyJobWrapper.java:666) at com.bmw.psdz.vehicle.configuration.jobs.VCMJobs.executeVCMJob(VCMJobs.java:810) at com.bmw.psdz.vehicle.configuration.jobs.VCMJobs.systemFunction_requestFAfromVCM(VCMJobs.java:535) at com.bmw.psdz.vcm.facade.VCMImpl.requestFA(VCMImpl.java:156) at com.bmw.psdz.facade.VCMBF.requestFA_aroundBody0(VCMBF.java:32) at com.bmw.psdz.facade.VCMBF.requestFA_aroundBody1$advice(VCMBF.java:84) at com.bmw.psdz.facade.VCMBF.requestFA(VCMBF.java:1) at com.bmw.esys.domain.psdz.Psdz.requestFA(Psdz.java:1419) ... 41 more and then... Code:
Read FA from the Backup Partner failed. Possibly there is no FA stored in the Backup Partner or there is no connection to the Backup Partner. [C096] negative response error: code: the result contains an error description: Service RDBI_FA2 has error in result: [Severity=2051][ErrorCode=53327][ErrorCodeDescription=service execution failed][VendorCode=32768][VendorCodeDescription=VCI-specific error (WRONG_TARGET) occured: 67][InterfaceErrorCode=0x43][InterfaceErrorCodeDescription=interface-specific error]; LinkName: VCM_BACKUP_ETHERNET severity: ERROR [2130759759] HW-Interface Error [67] com.bmw.esys.domain.psdz.PsdzException: Read FA from the Backup Partner failed. Possibly there is no FA stored in the Backup Partner or there is no connection to the Backup Partner. [C096] at com.bmw.esys.domain.psdz.Psdz.requestFAFromBackup(Psdz.java:1443) at com.bmw.esys.domain.fa.FalLogic.readFa(FalLogic.java:109) at com.bmw.esys.gui.fa.FalController$FaReadWriteController.doRead(FalController.java:214) at com.bmw.esys.gui.DefaultReadWriteController.read(DefaultReadWriteController.java:75) at com.bmw.esys.gui.ReadWriteSupport$ReadAction.doActionPerformed(ReadWriteSupport.java:93) at com.bmw.esys.gui.AbstractView$AbstractGuiAction.actionPerformed(AbstractView.java:234) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6533) at javax.swing.JComponent.processMouseEvent(JComponent.java:3324) at java.awt.Component.processEvent(Component.java:6298) at java.awt.Container.processEvent(Container.java:2236) at java.awt.Component.dispatchEventImpl(Component.java:4889) at java.awt.Container.dispatchEventImpl(Container.java:2294) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466) at java.awt.Container.dispatchEventImpl(Container.java:2280) at java.awt.Window.dispatchEventImpl(Window.java:2746) at java.awt.Component.dispatchEvent(Component.java:4711) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86) at java.awt.EventQueue$4.run(EventQueue.java:731) at java.awt.EventQueue$4.run(EventQueue.java:729) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) Caused by: negative response error: code: the result contains an error description: Service RDBI_FA2 has error in result: [Severity=2051][ErrorCode=53327][ErrorCodeDescription=service execution failed][VendorCode=32768][VendorCodeDescription=VCI-specific error (WRONG_TARGET) occured: 67][InterfaceErrorCode=0x43][InterfaceErrorCodeDescription=interface-specific error]; LinkName: VCM_BACKUP_ETHERNET severity: ERROR Timestamp: Sun Apr 28 10:58:03 PDT 2019 ID: 2130759759 Class: com.bmw.psdz.vehicle.connection.util.ResultUtil ExecutionContext={category=VCM, ecuid=(VCM_BACKUP,0x40),PSdZEvent={message=MCDDiagService<id=260900, job=com.bmw.psdz.jobs.uds.vcm.MCD3_ReadFAFromVCMBackup, service=RDBI_FA1 - ReadDataByIdentifier FA Teil 1, description=error: timeout, link=VCM_BACKUP_ETHERNET>, timestamp=Sun Apr 28 10:58:03 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=262900, job=com.bmw.psdz.jobs.uds.vcm.MCD3_ReadFAFromVCMBackup, service=RDBI_FA2 - ReadDataByIdentifier FA Teil 2, description=error: timeout, link=VCM_BACKUP_ETHERNET>, timestamp=Sun Apr 28 10:58:03 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null},PSdZEvent={message=MCDDiagService<id=36900, job=com.bmw.psdz.jobs.uds.vcm.MCD3_ReadFAFromVCMBackup, service=RDBI_ADS - ReadDataByIdentifier ActiveDiagnosticSession, description=error: timeout, link=VCM_BACKUP_ETHERNET>, timestamp=Sun Apr 28 10:58:03 PDT 2019, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__, event id=default, event type=DiagService error, null}}MCD Error Code: 0xd04fMCD Error Code Description: service execution failedVendor Code: 0x8000Vendor Code Description: VCI-specific error (WRONG_TARGET) occured: 67 at com.bmw.psdz.vehicle.connection.util.ResultUtil.checkResponsePositive(ResultUtil.java:75) at com.bmw.psdz.vehicle.connection.util.ResultUtil.getPositiveResponseOrTerminateOnError(ResultUtil.java:175) at com.bmw.psdz.vehicle.connection.wrapper.LegacyJobWrapper.terminateOnError(LegacyJobWrapper.java:666) at com.bmw.psdz.vehicle.configuration.jobs.VCMJobs.systemFunction_requestFAfromVCMBackup(VCMJobs.java:593) at com.bmw.psdz.vcm.facade.VCMImpl.requestFAFromBackup(VCMImpl.java:169) at com.bmw.psdz.vcm.facade.VCMImpl.requestFAFromBackup(VCMImpl.java:1) at com.bmw.psdz.facade.VCMBF.requestFAFromBackup_aroundBody2(VCMBF.java:39) at com.bmw.psdz.facade.VCMBF.requestFAFromBackup_aroundBody3$advice(VCMBF.java:84) at com.bmw.psdz.facade.VCMBF.requestFAFromBackup(VCMBF.java:1) at com.bmw.esys.domain.psdz.Psdz.requestFAFromBackup(Psdz.java:1439) ... 41 more Last edited by BMWAaron; 04-28-2019 at 02:07 PM.. Reason: Add error info |
04-28-2019, 03:59 PM | #14469 | |
Rep 40,774
I have no idea on the FDL Code error.
04-29-2019, 09:51 AM | #14470 |
Rep 2
Hi Guys,
Can I also get PM with all new SW? I'm going to retrofit rear PDC in my F30. I have enet cable, new REM module with correct pin numbers, sensors and wires and a litte bit experience with coding... BTW I used BMWAicoder 4.6 to do some simple coding. Many thanks |
04-29-2019, 10:20 AM | #14471 | |
Rep 40,774
04-29-2019, 04:36 PM | #14473 |
Rep 40,774
PM sent.
04-29-2019, 04:38 PM | #14475 |
Rep 40,774
