11-22-2013, 11:05 AM | #111 | |
Rep 21
Stupid question probably - what does FDL stand for? Also did you mean F25 or F15 when using E-Sys? New X5 is F15 as far as I know! I know there are a few links on here - but are there any 'idiots guides' (e.g. with screenshots of the exact process)to performing this procedure (which from what I can tell is at the very simple end of coding!). I have seen the changing FA guide, but couldn't see anything about the 2nd part of the process to actually then code to the car. Thanks again! |
11-22-2013, 11:13 AM | #112 | |
Rep 40,789
I meant what I wrote. F15 uses F25 PSdZData. It does not have its own. Same as F30 uses F20 PSdZData, and F12 uses F10 PSdZData, etc. The Guides are all here: http://www.f30post.com/forums/showpo...71&postcount=1
11-22-2013, 11:25 AM | #113 | |
Rep 21
11-22-2013, 11:48 AM | #114 | |
Rep 40,789
Good luck.
11-23-2013, 08:59 AM | #115 |
Rep 259
I have 6NL, should I change to 6NK? Is there a difference? I can currently stream music via Bluetooth but album artwork does not stream. However if I connect via USB I can stream via USB with album artwork.
Is it possible to get album artwork via Bluetooth streaming? |
11-23-2013, 06:27 PM | #116 | |
Rep 40,789
You cannot stream album art via Bluetooth on CIC Head Unit. It is possible though I believe with NBT Head Unit with iDrive 4.2 update. If you are connected with a USB Cable, you are not streaming anything.
11-28-2013, 06:12 AM | #117 |
Rep 256
11-28-2013, 06:18 AM | #118 |
Rep 40,789
CIC and NBT are the hardware Head Units for 609 Navigation Professional, with NBT being the newest version. You can only get Album Art streaming with newer NBT, and even then I believe it needs iDrive 4.2 firmware on it.
11-28-2013, 06:22 AM | #119 |
Rep 256
11-28-2013, 06:30 AM | #121 |
Rep 21
Hi Shawn - quick question...... coding with E-Sys - does that effectively achieve the same result as a garage could get using Autologic? I have a friend who is a mechanic and reckoned he may be able to do the coding for me using their Autologic system. Do you know if this is possible, or if there is any disadvantage as opposed to going down the E-Sys route?
Also - if I were to do it myself, what is the relevance of the version of the data files? i.e. do you need a specific version for a particular model of car? does it matter if the data file version is older than the car software? Many thanks again - really appreciate your help! |
11-28-2013, 08:05 AM | #122 | |
Rep 40,789
E-Sys can code any and everything in all ECU's. There is nothing more capable or better to use. The benefit of Autologic is its diagnostic capabilities, and clearing error codes, not coding capabilities. I believe Autologic is limited to some predefined codings, but I am not very familiar with it, so don't hold me to it. As for the data files, yes, it matters. The PSdZData version you use must be >= to the last version of ISTA/P used to program the car.
11-28-2013, 08:20 AM | #123 | |
Rep 21
11-28-2013, 08:24 AM | #124 | |
Rep 40,789
Tell me your I-Step Current, and I will tell you the ISTA/P version: http://www.f30post.com/forums/showpo...postcount=1403
11-28-2013, 08:26 AM | #125 |
Rep 21
Thanks - I will send you the info once my cable arrives and I have the software working.
What would actually happen if you tried to code using PSdZData version that was older than ISTA/P version of car? |
11-28-2013, 08:36 AM | #126 |
Rep 40,789
You will get harmless E-Sys errors, usually [C012] errors stating "Missing CAFD", but you can do no damage, so it's not something to be concerned about.
11-28-2013, 09:54 AM | #128 |
Rep 40,789
PM sent.
11-30-2013, 09:37 AM | #130 | |
Rep 21
11-30-2013, 09:40 AM | #131 |
Rep 40,789
Already replied. Your car was last programed with ISTA/P 2.50.4 on it so any PSdZData >= 50.4 is good for you.
12-06-2013, 10:45 AM | #132 |
Rep 458
