02-05-2014, 08:32 AM | #155 |
bimmer noob
Rep 23
Hi, so I did my first coding last night. Added connected drive with BMW live. I have a Canadian 2013 328xi, am I correct that the combox is part of my HU Entry head unit? There's nothing in the trunk.
02-06-2014, 12:37 AM | #156 |
Rep 1,976
Drives: 2020 G20 320i M Sport
It's not going to work if your F30 is a 2013 model without Navigation. In order for this to work, your car must either be a 2012/2013 model with the Navigation System Professional or any 2014 model with or without Navigation.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
02-06-2014, 02:09 AM | #157 | |
Rep 131
I haven't try the bmw live coding yet on my 335. thanks |
02-06-2014, 09:26 AM | #158 |
Rep 156
I received my cable from bimmer-tech yesterday but am unable to get a hold of the tech. I assume that is my user error(PEBKAC so to speak) Anyways I am willing to give this a go on my own but need the e-sys, could I get a PM to get the software?
Thanks. EDIT: Once I figured out how to use skype, bimmer-tech was more than helpful. Don't want to put their name through the mud because I had never used skype before. Never will after this, closed source software makes me feel icky. Last edited by doug piston; 02-06-2014 at 11:44 AM.. |
02-06-2014, 10:08 AM | #159 |
Rep 40,789
PM sent.
02-07-2014, 09:59 PM | #161 |
Rep 156
This was the error I was getting
Code:
Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. ExecutionID=2014/02/07-20:34:57.279 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [CMB_MEDIA - 36] prepareECUforCoding started [CMB_MEDIA - 36] prepareECUforCoding finished [CMB_MEDIA - 36] authenticateECUforCoding started [CMB_MEDIA - 36] authenticateECUforCoding finished [CMB_MEDIA - 36 - cafd_000005b6-004_002_017] Transaction type: cdDeploy; Message: TA started [CMB_MEDIA - 36 - cafd_000005b6-004_002_017] Transaction type: cdDeploy; Message: TA finished [CMB_MEDIA - 36] finalizeECUCoding started [CMB_MEDIA - 36] finalizeECUCoding finished [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "Finished". [C207] TAL execution finished. Duration: "7s". [C206] MSM update: Read current SVT. [C194] MSM update started. [C215] MCDDiagService<id=378649, job=com.bmw.psdz.jobs.uds.MCD3_ReadF11DataFromMSM, service=RC_GET_PARAMETER_N11 - RoutineControll GetParameter N11, description=error: negative response : requestOutOfRange, link=MSM_ETHERNET> [Exception - UNKNOWN] No entry in sec_transkeys.xml is valid for given Bootloader-Id. ID=btld_00001556-003_101_010 MSM update finished with error. [C217] Error in MSM Update: Error during MSM update. [C214] No entry in sec_transkeys.xml is valid for given Bootloader-Id. ID=btld_00001556-003_101_010 [1400] VCM Update: Write FA to VCM. [C188] VCM Update: Write FP to VCM. [C190] VCM Update: Read current SVT. [C191] VCM Update: Check current SVT with TAL. [C192] VCM Update: finished with error. [C196] Error in VCM Update: No ECU found in SVT with base variant "CMB_MEDIA" and diagnostic address "54" ("36"). [C177] Abarbeitung beendet So all seems succesful but I cannot see it in the bluetooth options. Locked the doors and will let it sit for 15 mins but I expect to met with disappointment. EDIT: Yep, I have failed yet again. Last edited by doug piston; 02-07-2014 at 11:22 PM.. Reason: Yes, code tags. |
02-08-2014, 02:58 AM | #162 |
Rep 40,789
Did you VO code the Head Unit (HU_xxx) too?
02-08-2014, 07:20 AM | #163 |
Rep 156
I did not, I went back and read http://www.f30post.com/forums/showpo...0&postcount=79 and it does state to do both. I will now do both, thanks for your patience. It's appreciated.
02-08-2014, 07:23 AM | #164 |
bimmer noob
Rep 23
Yes, it worked. I'm not sure if we can post threads from other sites, but google BMW live. That got me most of the way there, I enabled one other "online" option under 3000. I'm going to try office next. I run it tethered to my iphone.
02-08-2014, 08:45 AM | #165 |
Rep 156
Ok, I tried coding the HU_ENTRY but I get an error.
I am connecting via VIN. The machine is a macbook running parellels with Win7 in which I am using a thunderbolt to Ethernet connector Code:
Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] [] use default timing parameters as an exception occured ExecutionID=2014/02/08-06:36:45.556 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [HU_ENTRY - 63] There was an error during TAL execution, please check the log files. [Exception - HU_ENTRY_63_ETHERNET] openECUConnection for link HU_ENTRY_63_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name HU_ENTRY_63_ETHERNET doesn't map to an item [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207] TAL execution finished. Duration: "5s". [C206] Abarbeitung beendet Last edited by doug piston; 02-08-2014 at 09:00 AM.. |
02-08-2014, 10:32 AM | #166 |
Rep 40,789
That TAL looks like you tried to Flash your Head Unit. What are you doing? You need only VO Code it:
Connect => Expert Mode => Coding Module => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on HU_ENTRY (the ECU itself not the underlying CAFD) => Select CODE.
02-08-2014, 10:40 AM | #167 | |
Rep 156
When I got that error I hit the code button that is on the right. I will try doing the right-click option. |
02-08-2014, 10:43 AM | #168 |
Rep 40,789
The Code Button on the Right is the same as Right-Click Code, so that is not the issue.
But your TAL looks strange, so I am not sure what you did leading up to it. Do only and exactly what I wrote above for HU_ENTRY and CMB_MEDIA.
02-08-2014, 10:59 AM | #170 |
Rep 40,789
It does not matter.
02-08-2014, 11:03 AM | #171 |
Rep 156
Went out and tried again, still same error. CMB_MEDIA goes through a ok, just HU_ENTRY fails.
Screen shots CMB_MEDIA https://www.dropbox.com/s/070wvtte7f...2008.57.20.png HU_ENTRY https://www.dropbox.com/s/95fhpwrbfd...2008.57.54.png |
02-08-2014, 11:10 AM | #172 |
Rep 40,789
Hmm...maybe 6NK is not a valid option code for EBT and HU_ENTRY Head Unit.
Your VO has only 6NH removed and replaced with 6NK? Was there any error calculating FP in FA Editor?
02-08-2014, 11:15 AM | #173 |
Rep 156
02-08-2014, 11:18 AM | #174 |
Rep 40,789
Have you checked to see if EBT is working or not?
02-08-2014, 11:24 AM | #176 |
Rep 40,789
Is your Combox factory installed?
I see in your pictures that you also have CMB_ECALL, which means you have Telematics Combox, which also means you should be using 6NL instead of 6NK.
