10-05-2016, 06:56 PM | #67 | |
Rep 1,560
Seems you may be the only person with that opinion ... http://www.tirerack.com/tires/survey...sp?type=W&VT=C
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
10-06-2016, 04:00 AM | #68 | |
Infidel
122
Rep 1,102
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
10-06-2016, 04:04 AM | #69 |
Rep 1,291
Can't agree with that...
I have the same experience as the OP with OEM 442M 19" wheels, almost new Michelin PSS tyres (so not runflat, not cheap either) Alignment has been done recently and in all other respects appears to be perfect. I'm leaning towards weak anti roll bars and/or suspension setup. ARBs are due for an upgrade in a couple of weeks so i'll report back then. Suspension might follow depending on the ARB result.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
10-06-2016, 04:23 AM | #70 | |
Infidel
122
Rep 1,102
Edit: I see that you have the M3 lower control arms, just sticking that piece in there without the rest of the "kit" might not be optimal. I donīt know, just a thought...
10-06-2016, 10:44 PM | #71 | |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
I've experienced this before. Driving on Highway 65MPH and car blowing left and right. It's even worse driving behind a lorry. 340i xDrive Msport. |
Avrosse35.00 |
10-07-2016, 02:31 AM | #72 | ||
Rep 105
10-10-2016, 12:32 AM | #74 | |
Rep 1,291
10-10-2016, 03:05 AM | #75 |
Infidel
122
Rep 1,102
10-10-2016, 03:56 AM | #76 |
Rep 15,858
I'm suspicious of complaints about a car, after any modifications are made. Users can change parts and parameters to get a particular improvement, but as we know, BMW have tuned the chassis to get the best balance of inevitable compromises. We can change something to get what we feel is a preferred improvement, but there is a likely to be some negative change as well. We often read users change toe and/or camber, to improve some particular handling characteristic, but so easy to build in other issues. Easy to "rob Peter, to pay Paul". Then we blame BMW.
Vitoco122.00 |
10-10-2016, 04:14 AM | #77 |
Rep 1,291
To some extent you're right, except the handling with original control arm was terrible, and borderline dangerous on some situations where there would be no response then a brutal response, changing the LCA has dramatically improved that.
Now with my former M135i, steering was both very precise and very stable at higher speeds too. So blaming BMW, yes for not building the F30 as well as the F20 M135i. Now I don't blame BMW for potential side effects (to be demonstrated) of a change I made. FWIW, the M135i shares the same tension strut as all the others F20/F30, but has a specific LCA (resembling that of the M3, but not same part number) Bee Pee you might want to complement this as you're running an M135i I believe with upgraded LCAs as well.
10-10-2016, 04:48 AM | #78 |
Rep 938
I've experienced this problem too...but only when driving at speed ( >100mph).
Otherwise the car is completely planted (and I genuinely pass through some very windy roads)
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
Avrosse35.00 |
10-10-2016, 07:10 AM | #79 |
Rep 8
For me, I think it is related to the overall numbness in the steering around center. It makes it harder to get a good feel and/or make minor corrections when wind is pushing the car from the side. The car is planted, but the steering doesn't feel that way.
Avrosse35.00 |
10-10-2016, 09:31 AM | #81 |
Rep 715
I was thinking of this thread yesterday while driving around, it was very windy due to the outer bands of hurricane matthew.
Car was planted and very steady even at 80+ MPH, on the stock staggered 19's with run flats. |
