BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > comfort access trunk open
Studio RSR
      02-13-2013, 04:38 PM   #23
tdizzle
Drives: 2017 F80 ZCP
Originally Posted by shivaswrath View Post
it's technique...it's so odd, but once you get the hang of it, and get over how funny you look in the parking lot fake kicking your car (and people walking by wondering if you have some weird form of turrets), you'll love it.
What he said.
      02-13-2013, 04:46 PM   #24
sr5959
Drives: 428GC M-Sport
Originally Posted by Dinh335 View Post
im batting about .00002 ...
going to practice tonight again. fwiw, as a starting pt before you start practicing make sure your trunk is unlocked (glove cmpartment) and the other fob is far far away.
If it doesn't work very well on your car have it checked out by the dealer. On my car it works very well, easily 9/10 attempts on the first try. However I had a loaner recently in which it was very hit or miss getting the trunk kick to work.
      02-13-2013, 05:15 PM   #25
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Originally Posted by KellerKiller View Post
I've found that the distance from you to the bumper is most important. Pretty sure it uses the parking sensors on the bumper to register the movement. That's why it only works when the doors are locked and the car is off. other wise all the asshole tailgaters may pop your trunk. lol
Anyway, you just have to make sure your kick is not inside the range of the center two sensors. That's what's done it for me. Prior to figuring that out, I failed miserable several times. lol
Absolutely. Distance is critical and also snap the leg back fairly briskly. I even graze the bumper a tad with the top of my foot. That must tickle the car some and makes it pop the trunk easier.
F30 Sapphire Black M-Sport 335i 6MT
      02-13-2013, 07:12 PM   #26
BMWforLife
BMWforLife's Avatar
Drives: 2021 330i
think of your foot as if it were riding a swing. it needs to go up behind the bumper, not just under it
Gone but not forgotten
14 335i
12 335i 6 speed
11 328i
06 330i
      02-13-2013, 07:38 PM   #27
DesertSmokeBBQ
DesertSmokeBBQ's Avatar
Drives: 2014 F30 335i M-Sport
2013 BMW  [0.00]
Originally Posted by everettpa1 View Post
I can't get mine to work. I have comfort access.
I had the same issue at 1st but figured that if you stood back as if walking up to it rather than standing where you would to pop it from the trunk latch and count ONE. TWO. It opens every time
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP
Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL
      02-13-2013, 08:15 PM   #28
BavarianFanatic
Too much is never enough
Drives: Too Many
I can't comprehend how so many have an issue with this. It's such an intuitive thing. I've never had a single issue since day one.
You don't need to get anal about pointing your toe, lining up with the roundel or thrusting your leg in a certain manner. Just walk up and give a quick kick in/out. The sensor is up behind the bumper. It measures the longitudinal movement of your foot fore/aft. It does NOT use the park sensors.
Distance from the bumper isn't particularly important (vertically). It has enough range to reach the ground. It also has a pretty reasonable range side to side.
I literally just walk up and give a quick kick. Works 100% of the time. Don't overthink it.
      02-13-2013, 08:18 PM   #29
chazrt
Singapore
Drives: BMW F30 320i Mineral White
Haha you either get it first time or you don't. Takes awhile to get the hang of it, but very useful when your hands are full.
      02-13-2013, 08:34 PM   #30
AndDown
Just Copacetic!
Drives: 2019 F22 230i MSport
I had a loaner recently that had the CA. Didn't have any problems using the kick/pull back technique. I've read in another thread that updating the software helped improve the success of opening the lid.
      02-13-2013, 08:38 PM   #31
batislav
Drives: 2012 335i Sportline
My trunk isn't very finicky. I don't kick, just swipe from right to left under the bumper and it opens every time.
      02-13-2013, 09:06 PM   #32
RPM90
Drives: 340i M-sport AT
Hi all,
I searched, and didn't find a thread , if there is sorry if I may have missed it.
I can't seem to get the foot swipe trunk open to work. I've only gotten it to work 2x and failed about 20. Other key fob isn't near by... trunk isn't locked inside of glove compartment either.
Do i just have crappy foot technique?
It's a cool idea, but poorly implemented in the F30.
I know it's "supposed" to work as I've got it to work, but, it doesn't work every time. My success rate is about 6-7 out of every 10 attempts.
If this were implemented correctly we wouldn't have to have several threads about this very issue discussing the "proper technique".
If it were implemented correctly it should work EVERY time you try it.
I know a technique that works every time, use the button on the fob or simply use the button supplied on the trunk lid.
Don't forget you have to have the fob in your pocket, or you'll just end up looking really silly continually kicking at your cool cars butt.
      02-13-2013, 09:21 PM   #33
RPM90
Exactly. It SHOULD be very intuitive and simple and it should work every time, especially after you've had several successful prior openings.
Yet, here we are again with another thread on this subject, over thinking it.
I know how to do it as it's worked for me many times, and yet it doesn't work every time.
As one poster suggested maybe something is wrong or out of alignment with some of these sensors.
It just shouldn't cause this much issue for something that is supposed to be easy to use and part of "comfort" access.
      02-13-2013, 09:30 PM   #34
snowghost
snowghost's Avatar
No it's over think. For those of us that have had hard contact lenses back in the day, it was a certain knack to blink them out. Over think it and the bastards got stuck to your eyeballs. Be loose and let the trunk happen.
      02-13-2013, 09:35 PM   #35
AndDown
Just Copacetic!
I recall a TV ad that had a dog wagging its tail under the rear bumper and caused it to open; believe it was on the E90 series. Maybe BMW was getting complaints of the trunk lid opening unintentionally?
      02-13-2013, 09:51 PM   #36
BavarianFanatic
Drives: Too Many
Here are the "sensor wires" that are mounted behind the bumper.
Each sensor will detect the movement of your foot (or any object) as it passes under it them. The sensors can detect the direction of movement of your foot by evalutating the timing of the trigger events from each sensor. The motion itself is not what triggers the opening, it's the rapid change in direction. You need to make a pretty quick and purposeful in/out motion, not a lazy wave. It's not like a typical motion sensor. Just moving your foot around isn't going to trigger it. Thrust with purpose!
      02-13-2013, 10:11 PM   #37
Decepax
Drives: 2013 328i xDrive; Z4; X3
Originally Posted by chriskd
In my experience, if you stand too close to the bumper, you'll fail more often. Try stepping farther back before attempting the kick.
+1
Following this technique my kids can even do it
      02-13-2013, 11:20 PM   #38
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
+1
I have NEVER failed since day one and when I tell my friends (incl. my mother who knows nothing about tech stuff) who doesn't know that it exist to kick behind the car they also make it on their first kick.
      02-13-2013, 11:29 PM   #39
MadZarBMR
MadZarBMR's Avatar
Drives: Current: '18 M3 ZCP - 6MT
From my experience it seems to fail only when I accidentally touch the sensor. The trick for me is to not touch the car and almost wave your foot in and under the bumper in a rapid but somewhat circular motion. Hasn't failed for me since I figured that out.
      02-13-2013, 11:30 PM   #40
DrivenByE30
DrivenByE30's Avatar
France
592
Drives: '12 F30 Lux 335i 6MT
you dont need to kick quickly...
Actually, a slow kick in and up, then gently pull swing back out your leg and voila
fast is no good... try a gently kick up and pull out...
      02-13-2013, 11:49 PM   #41
Dinh335
Drives: 2004 RX8/2015 M3/2017 X5 35i
im batting about .500 now... in fact first time i tried it when i left work it worked.
it's not so much that i was or anyone is over thinking it. it's more figuring out how it needs to function. I'm not surprised some people have issues w it... it's sort of advertised as a 'just stick your foot under it' and it's not exactly that simple.
it'd be the same thing as if to lock your car you had to snap our thumb back instead of just touching the handle.
2015 Tanzanite Blue M3 /19 silver/exec/SS full leather/hk/cams/6speed_Wife 2017 x5 xdrive 35i
      02-14-2013, 06:31 AM   #42
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
Originally Posted by SamS View Post
It's becoming a more common feature on cars now, so I don't worry/care about any strange looks.
i know, i didnt mean it in demeaning way, just looks funny...
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      06-14-2015, 10:05 PM   #43
arjav
Drives: 2022 X3 M40i
I've been trying to figure this out for six months and have yet to master it. I think I have gotten it work a handful of times. It does work though its awesome!
      06-16-2015, 05:38 PM   #44
Portimao Blues
Portimao Blues's Avatar
Drives: 2021 M340i xDrive Sedan
Believe it or not, I didn't know my car had this feature until I saw this thread...LOL! My Client Advisor never mentioned it and I never looked into it.
I just went outside to try it and nailed it on my first "kick." Ha
Thanks!
2021 M340i xDrive Sedan | Portimao Blue Metallic | Cognac Vernasca Leather | Maple Matte Finish Wood Trim | 19-Inch 792M Wheels | Red Brake Calipers | Premium Package | Driving Assistance Package | Adaptive M Suspension | Harman/Kardon Surround Sound | Painted Rear Spoiler (Z50)
2014 335i xDrive Sedan | M-Sport | Estoril Blue Metallic | Venetian Beige Leather (Sold)
