02-02-2017, 10:19 PM | #1 |
Rep 1,771
Which MPSS tires should I go with to not rub?
Hey guys, so basically I got some Michelin Pilot Super Sports installed yesterday. The fronts are alright but the rears poke out a bit past the fender.
Here are the specs: 19x8.5 ET35, 235/40/19 19x9.5 ET35, 265/35/19 Here's my dilemma. I have coilovers that have been sitting around waiting to get installed and now that i got the Michelins installed, I don't know that I'd be able to go any lower in the rear because they already poke and I would most likely rub. I have a few options in mind, or if anyone would like to make another recommendation i would appreciate that too! Option 1: Keep 235/40 front and go 255/35 rear (instead of my current 265/35). Option 2: Go for 235/35 front and 255/30 rear. I have attached some pics too. Thank you!
Instagram: @dg_g20
02-02-2017, 11:19 PM | #3 |
Rep 4,327
i like option 1.
option 2 will make the speedo read lower than actual speed and accrue more mileage than actually being driven. bmw's come from the factory already with speedo's that read slower than actual. the lower diameter would better your acceleration, though. |
02-03-2017, 10:24 AM | #5 | |
Rep 693
02-03-2017, 10:38 AM | #6 |
Rep 536
Drives: 2013 335xi Alpine White
Option 1
02-03-2017, 10:53 AM | #7 |
Rep 456
I picked up a set of used VMRs with the following setup: 19x8.5 ET35 front 19x9.5 ET33 rears and I run 235/35/19 and 265/30/19 respectively. As a result, I am in a similar position as you with the rear being slightly poked with MPSS. You probably don't want to here this, but the ET35 for the rear on our F30s is slightly too aggressive and will poke out like what you and I have experienced. I know it's not feasible, but it's best to go with an ET40 rear and run your 265 or even a 275. Option 1 would be your best bet but what you'll experience is a slight stretch of the 255 on a 9.5" rim. For some reference, feel free to check out the photos I posted of my F30 here:
http://f30.bimmerpost.com/forums/sho....php?t=1348470 |
02-03-2017, 01:08 PM | #8 | |
Rep 3,622
BMW CCA Member #516012
02-03-2017, 01:17 PM | #9 |
Rep 3,622
I would stay with OEM sizes. 225/40 (overall diameter 26.1in) & 255/35 (overall diameter 26 inch).
Or 235/40 (overall diameter 26.4in) & 265/35 (overall diameter 26.3in) These are the perfect sizes, the latter would look less stretched
02-03-2017, 04:21 PM | #10 |
Rep 94
02-03-2017, 08:59 PM | #11 |
Rep 4,327
02-04-2017, 06:24 PM | #12 | ||||
Rep 1,986
Asshole 2 Quote:
02-05-2017, 09:45 PM | #13 |
Rep 246
Hi Kabrich, I'm lowered on Bilstein B14s and am planning to get new wheels. Front is 19x8.5 et35 and rear is 19x9.5 et40. I'm planning to go with square setup 245/35 to play it safe with the xDrive transfer case. Do you think the setup is good?
02-06-2017, 07:02 PM | #15 | |
Rep 196
1. Your wheel diameters will be less than 1% difference in the front and stock in the rear. 2. The rear tire will be less stretched and be the recommended width for a 9.5" wheel. I ran 235/40/18 and 265/35/18 on my E90 with xdrive for years with no issues and plan on using a similar setup on my F30, but in 19".
2019 F87 M2C - DCT / 10mm spacers w 246/265 / RW lip / Suvneer skirts / PSM spoiler / BMW diffuser / 3M gloss black
