10-21-2013, 11:45 AM | #4863 |
Rep 40,765
I am not convinced this statement is correct. We need someone with iDrive 4.2 and factory 6NF and 6NR to confirm this.
10-21-2013, 11:46 AM | #4864 |
Rep 40,765
PM sent.
10-22-2013, 04:50 PM | #4865 | |
Rep 21
so the E-Sys is coming from BMW, but the token was developed by Akiss, but what prevents E-Sys to work as it is, and how it works within BMW then? if it was leaked from BMW/dealer, how do they solve that hassle? EDIT: I've managed to get 3.23.4 and 50.4, are they good enough to tweak a 2010 F10, or shall I dig for some other versions? what is the way to get the proper token? i see it is being sold all over the bmw-forums, not necessarily by Akiss I suppose, so I am a bit suspicious to acquire it that way. I see you PM'ed a few people with links perhaps, my PM will be active in 24 hours after this post is made thanks for your inputs! EDIT: ok I located http://www.f30post.com/forums/showpo...postcount=2356 and currently am getting the files from seeders. Last edited by edgerider; 10-23-2013 at 05:35 AM.. |
10-23-2013, 05:23 AM | #4867 | |
Rep 40,765
2) If you have 3.23.4 and 50.4, then you have all you need. 3) A just programmed 2010 F10 may have newer software on the car than a 2013 F10, so the build date is completely irrelevant. All that matters is that the PSdZData used to code the car is >= the last version of ISTA/P used to program the car. Without reading a car, it is impossible to know what that is, but if you are using the latest PSdZData, then you do not need to worry about it. 4) If you already have 3.23.4 and 50.4, I have no idea why you are also downloading the older versions from the Torrent Links. PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-23-2013 at 05:50 AM.. |
10-23-2013, 05:24 AM | #4868 |
Rep 40,765
PM sent.
10-23-2013, 05:48 AM | #4869 | ||||
Rep 21
4) because I've found your other posts, like those below and got an impression, that with 3.18.4 I might go for free(excluding the ENET cable): Quote:
I also read somewhere, that current version of e-sys doesn't need a token anymore, like 3.22 onwards, maybe misread that though. thanks for your inputs! |
10-23-2013, 05:56 AM | #4870 | |
Rep 40,765
All E-Sys versions require an .EST Token, and when any version, including 3.18.4, is used with newer PSdZdata files, it also requires the patch.
10-23-2013, 12:04 PM | #4871 |
Rep 6
Hello Shawn
I would like to change a few settings on my F30 (2012 316D). Can you tell me where are the links to download the software? (e-sys 3.2? an pszdata 50.4???) Thank you. (Excuse me for my english) |
10-23-2013, 09:14 PM | #4873 | |
Rep 40,765
10-24-2013, 04:56 AM | #4874 |
Rep 4
Sorry Shawn for the never-ending request... would you mind to kindly share all the latest files that work with 2013 F30 please? I just got my car for like 2 weeks or so.
Thank you! |
10-24-2013, 05:08 AM | #4875 |
Rep 40,765
PM sent.
10-24-2013, 01:58 PM | #4879 |
Rep 40,765
PM sent.
10-24-2013, 03:16 PM | #4880 |
Rep 9
Hi,
I'm pretty (completely actually) new to this coding wizardry. I've browsed through the documentation and this thread, but I still have some stupid questions left. So there are basically 2 things I would like to do with my F30 from 09/2013. * Code the extended bluetooth functionality (6NS). I have the basic one (6NH) that came with professional system. I've understood so far this should be possible by 'VO code' this option, basically making the car believe this option came with the standard. What I don't get is the reference to VO coding the HU_NBT. My car is equipped with the NBT system, so it should be there. Also, i've read somewhere you don't need a token to do this. Which token are they taking about here? * The speed limit info (8TH). I have the adaptive high beam xenon lights, so if i'm not mistaken, the camera should be there to capture the images. So is this the same deal: VO code this option and that's it or is there more to it? Thanks. |
10-24-2013, 03:41 PM | #4881 | |
Rep 40,765
2) You have adaptive headlights or Automatic High Beams? Adaptive Head Lights use sensors to measure speed, steering angle and yaw. HBA (High Beam Assistant uses a camera, but in some cases it is a dedicated HBA only Camera, and some cases, depending on other options, it uses the same KAFAS2 Camera as SLI (Speed Limit Info) does. SLI though may also require an FSC Enabling Code be Imported and Activated in the head unit, and if so, even if the car has the hardware, this will be difficult to get, and very expensive if it can be got.
10-24-2013, 04:27 PM | #4883 |
Rep 40,765
PM's for what exactly? There are many different needs I am responding to.
