BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > First Day w/ HK System
      06-21-2015, 03:53 PM   #89
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
Originally Posted by thatryan
Are you running the stock HK speakers glennQNYC ?
Yes.
      10-27-2015, 05:32 AM   #90
YeaG30
YeaG30's Avatar
Drives: 2017 540i
Originally Posted by glennQNYC View Post
Still playing with this, but this is how it's set at the moment. Like I mentioned, I move the Bass control quite a bit to compensate for different listening material. I don't seem to move the EQ too often except for 100Hz...
I wouldn't be too against having 5kHz and 10kHz flat... The frequency response might be a bit smoother, but the distortion from the tweeters bothers me so I take them down a touch.
Still need to get an RTA in the car though. Someday!
Treble flat
Bass flat
L7 on
100Hz +5
200Hz -5
500Hz +1
1kHz flat
2kHz flat
5kHz -1
10kHz -1
I have been playing with different settings for over 3 years and over the last year just gave up and kept them where they are at. A few days ago, I decided to search the forums for some newer EQ settings and came across these ^. AMAZING. For the first time I feel like I can truly appreciate the capability of this system (be it may not be the worlds greatest, its still pretty darn good for factory OEM systems). Also, any time I have tried to use the L7, it seemed like an epic failure, but with these settings the L7 sounds awesome.
Thank you for the settings!
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
      10-28-2015, 09:31 PM   #91
2014 335i  [9.74]
Treble flat
Bass flat
L7 on
100Hz +5
200Hz -5
500Hz +1
1kHz flat
2kHz flat
5kHz -1
10kHz -1
Glad I could help!
      11-27-2015, 12:51 PM   #92
ScubaSteve
Drives: 2013 335i xDrive M Sport
Yes, Glenn, thank you very much for your settings. I used to be in the car audio business way back in the day, but now a days, I'm just happy to have a decent sounding oem system that is really not all that bad, it definitely beats anything else I've had in the past including the B&O system in my previous 11' S4. I am in the process of ordering a harness from Technic so that I can install a JL XD500/3v2 amp which I'm going to start with at first to just amplify the under seat subs and see how I like that. I'm waiting patiently to hear reviews on the new bavsound ghost subs that it sounds like many guys on here have pre ordered. I read in Technic's write up, that he was very impressed with the oem subs after adding the aftermarket amp. So much so that he questioned whether the customer would even need a trunk mounted sub. I am not crazy about the idea of a sub box sitting in my trunk as I often carry golf clubs or something else back there and am not keen on giving up the space. If a musicar box comes up for sale anytime in the near future I would probably go that route but for now I want to start by just amping up the oem subs and setting the xovers to see what that gets me. If I feel it could be better I will probably go for the bavsound under seat subs next, and maybe consider doing the bavsound stage 1 speaker upgrade kit. I guess my biggest question is has anyone on here posted a new eq setting with the upgraded bavsound speakers? I'm assuming the midbass response would be slightly better and not so bright on the high end due to the silk dome tweeters so obviously some different eq settings would be warranted. Any opinions?
      01-04-2016, 07:17 AM   #93
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
Subscribed for when my car arrives, copying your settings... Thanks!!
P.S OP = Did you make any changes?
      01-04-2016, 10:29 AM   #94
2014 335i  [9.74]
My current settings haven't changed much but after almost 42k miles this is how it's set...
Bass & Treble = Flat
Balance & Fader = Centered
L7 active
(Speed Volume = Center)
100Hz +4 (sometimes +5)
200Hz -5
500Hz +2
1kHz +1
2kHz Flat
5kHz -1
10kHz Flat
Appreciate 7
      01-04-2016, 11:50 AM   #95
kromix
kromix's Avatar
L7 active
200Hz -5
500Hz +2
1kHz +1
2kHz Flat
5kHz -1
10kHz Flat
Awesome thanks, going to use ur settings as a baseline and adjust to my ears... Out of curiosity what do you listen to mostly?
      01-04-2016, 04:20 PM   #96
2014 335i  [9.74]
L7 active
200Hz -5
500Hz +2
1kHz +1
2kHz Flat
5kHz -1
10kHz Flat
Irrelevant. This is the most accurate settings I have found for the HK, but the system's inherent non-linear response does make for some songs/genre perform better than others. R&B/Hip-Hop may need to have 100Hz at +4, where Classic Rock might have 100Hz at +5, but not much else changes unless the listening material's mix is way out of whack.
      01-09-2016, 12:20 AM   #97
kromix
kromix's Avatar
Perfect that was the answer I seeked, which was how you change the 100hz based on music Thanks again for your settings first thing I'm going to 'mod' on my car before I leave the lot and enjoy the good music :P
      01-09-2016, 02:42 PM   #98
BimmerMad
Drives: 3 wheeler
Any reason why these settings wouldn't apply to an LCI F30 with HK?
      01-09-2016, 04:12 PM   #99
2014 335i  [9.74]
I don't believe there are any audible differences in the LCI and pre-LCI HK systems.
      01-10-2016, 03:15 PM   #100
Spacer
Spacer's Avatar
Drives: M135i, becoming an X3!
GlennQNYC.... Thanks for the settings. Got round to doing it tonight on my car before a 90 min drive. Love the suggestions! Thanks :-)
      01-10-2016, 08:48 PM   #101
2014 335i  [9.74]
I'm so used to aftermarket systems where you have to be in that specific vehicle to listen. It's really cool that you guys can hear how my system sounds in your own car.
      01-12-2016, 06:55 AM   #102
Miacubano13
Drives: 2013 BMW 335 xdrive m sport
L7 active
200Hz -5
500Hz +2
1kHz +1
2kHz Flat
5kHz -1
10kHz Flat
Does flat mean centered or all the way to the left??
      01-13-2016, 07:00 AM   #103
2014 335i  [9.74]
L7 active
200Hz -5
500Hz +2
1kHz +1
2kHz Flat
5kHz -1
10kHz Flat
Centered. No boost; no cut.
      01-15-2016, 04:33 AM   #104
billybeartku
Drives: 435i Convertible M sport
I'm not an expert in terms of sound but I really would love to optimize my listening experience with this HK system. What would be the optimal setting for F33 convertible and I Listen to hip hop/ rap 80% of the time, pop 10%, EDM 10%. I do like bass though.
      01-15-2016, 07:09 AM   #105
kromix
kromix's Avatar
I can't help, but from reading all pages on this thread, I believe you are in the wrong car/sound system if you like bass response.... Upgrade those woofers
      01-15-2016, 02:27 PM   #106
billybeartku
The bass in HK system is good enough for me.
      01-15-2016, 04:20 PM   #107
2014 335i  [9.74]
Did you try setting your system's controls like I have my F30 set? What did you think?
      01-15-2016, 04:30 PM   #108
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
I have set my eq as you have specified..but I added 1 click more to the lowest frequency. .your settings do give a more balanced sound. I also used those settings on my previous e90 car with hk.
      01-15-2016, 10:15 PM   #109
billybeartku
I did. I liked it. I basically just go heavy on the bass. Just wondering if there would be a different setting catering to hiphop/rap to optimize the nature of the genre
      01-21-2016, 01:52 PM   #110
therealm3
Drives: F30 340 MSport
Set it like Glenn did, and then turn up the bass slider to like +3 or 4. Definitely added more bass for me when I want it.
