BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      10-11-2010, 02:14 PM   #1
bmw111
Drives: BMW 1 Series
Cool BMW 1 Series Changing 1st to 2nd Gear
Hi,
I have a BMW 1 series 2006, i notices that when i change from the 1st gear to the 2nd gear - at 2000 REVS, the car makes a strange noise from beneath- as if the engine cant hold the car. The noise is like metals clinging with each other.
Also the same noise happens when i am on the 3rd gear... slows down ( eg roundabout) and press the gass again to move...
Any ideas ?
Thank you in advance
      10-11-2010, 04:10 PM   #2
123d
Member
Drives:
Originally Posted by bmw111 View Post
Any ideas ?
Post in an appropiate forum here: http://www.1addicts.com/forums/index.php
      10-11-2010, 05:18 PM   #3
FactorX81
Drives: 2010 135i, 2014 Ford Escape Ti
clutch chatter maybe?
      10-11-2010, 10:14 PM   #4
sdpauly
sdpauly's Avatar
18
Drives: 2010 135i, 2008 Taco
Wouldnt shifting at 2000 RPM be kind of bogging the engine?
I usually shift between 3k and 4k under normal driving. Much higher if I'm going for a quick launch...
"...couldn't help but make me feel ashamed to live in a land where justice is a game." -Bob Dylan
      10-11-2010, 10:31 PM   #5
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Agree - but perhaps the OP has a diesel.
Tom
      10-11-2010, 10:33 PM   #6
MikeinAlexandria
Drives: 128i M Sport Convertible
It is a 2006, what? 116, 118, 125? How many miles? Have you changed the differential and transmission fluids? If you have more than 50k miles on the car, I would do this, and maybe even look at the shifter bushings to make sure they are not wearing out. 2000 rpm is pretty low for shifting unless it is a 135i, even my old Z3 coupe would stutter and bog at that rpm in higher gears. (It wanted to rev). Try changing the fluids and shifting at 3000 rpm on a regular basis to see if that helps at all.
      10-12-2010, 02:10 AM   #7
DarkRider23
Drives: 201 335i xDrive
I'm thinking you're describing the known problem in 1-series and 3-series caused by the clutch delay valve. Feels clunky and makes a ton of noise? If that's it, then it's normal. Or did it just recently start?
      10-15-2010, 09:19 AM   #8
bmw111
I bought the car second hand but it was always maintenanced @ the bmw dealer...
It has 35 000 Miles
      10-15-2010, 09:20 AM   #9
bmw111
I bought the car second hand... The owner never mentioned it had this problem therefore it may be the way im driving it ?
      10-15-2010, 09:21 AM   #10
bmw111
It is 2006 116i Petrol
35K Miles
So i should start shifting gears at higher revs ? Thanks
      10-15-2010, 09:28 AM   #11
Boxtyp3
Boxtyp3's Avatar
Philippines
78
Drives: 2015 F32 MG
2015 F32 435  [0.00]
2002 E46 cp  [0.00]
2010 E82 135i  [0.00]
2013 E92 335i  [0.00]
Could be cross joint on the shaft.+1 on the low RPM shifting. Rev match properly bro.
      10-15-2010, 12:03 PM   #12
miiipilot
miiipilot's Avatar
Drives: 2024 M2 Brooklyn Grey 6mt
I've noticed something similar. Although I haven't felt as something was wrong. But this is after 9 years of driving Acura 6mt. BMW, to me, seems to be clunky. And I've noticed if I slow up quick shifts, the smoother the drivetain reacts (CDV maybe?)
miiipilot
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats,
'16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold)
      10-15-2010, 12:58 PM   #13
DarkRider23
miiipilot
I've noticed the same thing too mii. I don't think it can be anything else other than the CDV giving us smoother shifts if we slow down the shifts.
bmw, gear, noise, series
1addicts
