09-23-2017, 06:16 AM | #1 |
Rep 152
Cant add my vehicle in Connected drive portal
Hello guys,
I am trying to add my car to my connected drive account but i receive an error message ?A message with security code cannot be sent to your vehicle? and that i have to contact bmw customer care to add it manually after providing them with vehicle registration documents. The problem is i have a retrofitted NBT and the NBT Vin is different from my car VIN. Any idea how to work around that. Is there a different way to add the car. Mainly i would like to add to be able to use bmw labs widget with IFTTT Any help would be appreciated ? |
09-24-2017, 08:35 PM | #2 |
Rep 342
The VIN of the headunit must match the VIN of the TCB/ATM. Do you have a telematics module already, and you added the NBT? If you, you need to flash the NBT with the VIN of the telematics module, and add new FSC codes for that VIN.
09-25-2017, 02:04 AM | #3 | |
Rep 488
Had the same issue, askedBMW and they said:
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
09-27-2017, 03:45 PM | #4 | |
Rep 152
I am not sure i fully understand, but i think I dont have a telematics module. I only retroftted the NBT and activated but the NBT has a different VIN then my vehicle Can i still add my car? |
09-27-2017, 03:45 PM | #5 | |
Rep 152
09-27-2017, 04:48 PM | #6 |
Rep 342
You can not add a car to a ConnectedDrive account without a telematics module. Also, you can't use the BMW Labs widget without a telematics module either.
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
09-27-2017, 08:55 PM | #7 | |
Rep 488
Turns out someone on their end screwed up in my case:
