07-27-2017, 04:27 PM | #1 |
Rep 201
A puddle in my trunk
So today I discovered a puddle in my trunk. It was raining, so either the trunk of my brand new 340i is leaking or, more likely, the trunk was open and some good samaritan closed it before I got back to the car. There have been a few instances where I've locked my car walked away and come back to find the trunk open. I'm guessing this is the key being activated in my pocket. Any way to disable the trunk open feature on the key fob? Any other ideas? Maybe a case for my key?
07-27-2017, 05:32 PM | #3 |
Rep 1,560
I think if you use the valet switch in the glove box, you won't be able to open your trunk with your fob (or any other way until you turn off valet mode).
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
07-27-2017, 09:16 PM | #4 |
Rep 14,115
Drives: G82 M4C X-Drive
Put some dry towels down in your trunk and close it. Run a hose over your car for a few minutes. Open the trunk and inspect for water around past the seals and on the towel.
FYI I've found my trunk open several times in my own garage. I think I accidentally hit the key fob in my jeans. Use the valet switch in the glove box for added piece of mind if you are so inclined. I think the fobs are poorly designed in this aspect.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
07-27-2017, 10:27 PM | #5 |
Rep 8,942
I forget is the battery in the trunk on your car? If so be very very careful and get this addressed ASAP.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-28-2017, 12:34 PM | #6 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Why is it so exposed? Isn't there carpet mat that covers that or is that getting wet as well?
The benefits of having a GC...I have my hatch programmed to just lift to 'level' with the roof if it accidentally opens..(never has happened).
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-28-2017, 09:49 PM | #8 |
Rep 201
Yes, typically the fuse box and everything is covered by the trunk liner, which i removed so it would dry faster.
