10-18-2017, 09:00 PM | #1 |
Rep 216
2016 340 turbo issue corrected by dealer?
Hi y'all,
I was in for an oil change and told the service advisor to check the turbo as I've read somewhere that there was some cars leaking oil. They checked it, said that the clamp was loose. I hope that takes care of it. Wonder if anybody else had this issue, i'm at almost 17k miles and this bad boy has been baby it. |
10-19-2017, 08:59 AM | #2 | |
Rep 115,980
Mike |
10-19-2017, 10:21 AM | #4 |
Rep 111
I got same issue of turbo oil leak and my turbo was just dead (no air charge)when I was driving on the way home. The attached picture shows the codes I read from jb4.
I put my car back to stock and claimed warranty. The dealer told me I need to replace new turbo. Havnt picked up my car from dealer. Its a 2016 340i MPPSK and only 13000 miles.: I think Im not the first and wont be the last one who will replace turbo sometime. Very disappointed with the poor quality of my BMW. Just take cares of your turbos guys |
10-19-2017, 10:41 AM | #5 |
Rep 775
i had the same issue. Turbo was leaking oil when the car only had ~4500 miles. dealer replaced the entire turbo under warranty
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
10-19-2017, 10:48 AM | #6 |
Rep 3,211
How exactly do you "take care of your turbo"?
How exactly would a loose clamp (18328612537) cause turbo oil leaks? Anyone have access to BMW bulletins on this issue? Hmmm better keep an eye on this one.. hate to see turbo issues after our warranties run out.. |
10-19-2017, 10:51 AM | #7 | |
Rep 369
Bmw is not immune to oil leaks, actually the exact opposite. Beemers leak as much as GM products, but they move out and last if properly maintained Just keep an eye on it and take it in if needed. (Stock obviously) |
10-19-2017, 11:55 AM | #9 |
Rep 775
nope none at all for me. no smoke or smell of burning oil or anything like that
2020 M340i xDrive |
10-19-2017, 02:42 PM | #10 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Anyone have a diagram/pic so I can better locate this hose and keep my eye on it?
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
10-19-2017, 04:26 PM | #11 |
Rep 369
It’s not a hose, it’s a center section leak, located by the center clamp.
You would need to raise the vehicle or remove the intake box and use a mirror to look down at the turbski center section. An oil leak would be obvious and stand out |
10-19-2017, 07:20 PM | #12 | ||
Rep 111
10-19-2017, 07:40 PM | #14 | |
Rep 111
10-19-2017, 07:51 PM | #15 | |
Rep 369
I strongly advise against owning a boosted Bmw without a warranty. Having said that, I would also wait for the S58 based m3. I have a feeling that one will be a rocket ship |
SMOKE EM IF U GOT EM!!216.00 |
10-19-2017, 08:00 PM | #16 | ||
Rep 111
10-19-2017, 08:32 PM | #17 | |
Rep 3,211
besides I've had ZERO issues w/my 340.. what issues exactly have you seen? I just checked my turbo clamp and its on secure no play there.. not even sure why it'd be leaking oil there I would expect where the bearings seal is is where the oil would leak |
10-19-2017, 08:53 PM | #18 |
Rep 216
This is part of the invoice.
K CUSTOMER REQ WE CHECK TO SEE IF REPAIR THAT APPLIES TO SIB 111516 APPLIES TO HIS VEHICLE, AND IF A REPAIR IS NEEDED. CAUSE: LOOSE CLAMP TURBOCHARGER BAND CLAMP LOOSE FITMENT (W) SIB 11 15 16, CHECKED THE TURBOCHARGER BAND CLAMP, FOUND TO BE LOOSE. TIGHTENED THE TURBOCHARGER BAND CLAMP TO SPECIFICATIONS AND INSPECTED GAP, FOUND TO BE OVER 5MM. NO FURTHER SERVICE IS NEEDED, CLEANED THE RESIDUAL OIL. I hope they come out with a recall for this so it can be replaced once and for all. |
10-21-2017, 04:15 PM | #19 |
Rep 248
Lol I've had a check engine for my 340 since I got it as well. I had dinan elite installed and nothing but trouble. Its like the car has the hiccups and while driving it will just start studdering or even when Idling it will start shaking and revs will drop a little as if its coughing or something.
Been to the dealer 6 times for this issue now. The last time it went away for almost 1000 miles and now its back. I am just living with it at this point because I'm sick of bringing it to the dealer for them to not know whats wrong. |
10-25-2017, 12:27 PM | #20 |
Rep 7,047
Just to add some data, here is mine.
2016 340i Msport here. 18,000 miles. I had cold start drive off hesitation, which lasts for 1 minute or less. Went in for yearly maintenance and they updated with new ECU program. Cold start hesitation GONE. I was also told they were taking care of a "recall", but it was not clear if that was the ECU update or something else. Other than that odd short duration hesitation, the 340i has been great. I haven't removed any panels under the engine to see if I have a leak, but no burning oil smell and nothing on the garage floor. My 2012 335i was also quite reliable. Both of my F30's have had some dash and trim creaks here and there, which are very temperature sensitive, and frankly shouldn't be there for such a pricey and, in some areas, over engineered automobile. But as for actual reliability, starting, driving, power, mobility, utility, etc, both have been great. |
10-25-2017, 12:34 PM | #21 | |
Rep 3,211
02-04-2018, 02:21 PM | #22 | |
Rep 1,369
http://www.boston-bmwcca.org/referen...er-beemer.aspx
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
