07-06-2012, 10:42 AM | #46 |
Rep 8,806
Price drop from $1599 to $1299
Turner's website reflects this change. Still expensive but this is from one of the biggest and best Bmw tuners in the industry. Alan
07-06-2012, 09:45 PM | #47 | |
Rep 7,047
My MPG increased by nearly 2MPG, driving it the same way day to day. However, you get these tunes for one thing, POWER. When you want and use more power, of course MPG will go down lower. If your engine is developing 40hp and 50lb ft more than stock, then it will require more fuel to develop that power. I prefer Full ECU software over piggyback as power levels increase. This is one expensive piggy. It does appear to be an advanced piggy system as it plugs into various sensors, seemingly to take over the readings the stock sensors are putting out. It takes time and money to crack ECU protection codes, and perhaps this company didn't want to crack the ECU or couldn't. ECU tunes also use the OEM sensors, but they are taking the sensor readings by which to adjust maps, instead of using sensor readings and altering them to make the computer think all is well. If this works in a different way, then I hope the manufacturer chimes in and explains. Simple piggybacks are cool for modest gains around 4-5psi. The JB+ is one such piggy and it works great. I've driven a 135i with the JB+ and the added power is very noticeable, very. It increased boost by 4.5psi. over stock. The price is but a fraction of this thing. With CAN tool and JB+ the cost is only $329! Excellent price for the added performance, and the tool allows you read and clear codes before dealer servicing. If there was one for the N55 that would be ideal for those who want more power, but want to keep it safe. It really does wake the engine up when you want it, and drives like stock when driven normally day to day driving. Last edited by RPM90; 07-06-2012 at 09:52 PM.. |
07-08-2012, 09:11 AM | #48 |
///M Specialist South Shore BMW
770
Rep 7,108
I think I'm going to try this out. I just worry about code clearing as this doesn't appear to have it. Will it leave a trace? There is not much info on it though.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
07-09-2012, 01:57 AM | #49 | ||
Rep 665
Dinan's stage 3 tune on the N55 motor for the E90 model cars required $3000 in additional upgrades before labor/tax including an upgraded intercooler and oil cooler. Now you're looking at having to spend probably an extra $4000 on supporting mods, plus they charge an extra $500 on the stage 3 tune. $4500 for an extra 18hp? No thanks. Only if I was tracking the car would I spend the money on the oil cooler and intercooler (but not theirs anyway). Last edited by verbs; 07-09-2012 at 02:05 AM.. |
07-09-2012, 02:01 AM | #50 |
Rep 665
07-09-2012, 02:06 AM | #51 |
Rep 665
07-14-2012, 10:26 PM | #52 | |
Rep 7,047
I actually like the idea of having the greater boost come on later. It's more like turbo's used to be, where the big power came once the revs were up. To me, it's easier to modulate the power at higher rpms, and thus easier to modulate power in the curves. With modern turbo's and direct injection, we get nearly all available torque before 2000 rpm, and in the N55 there is a LOT of it. These modern turbo's power output is like a diesel. Just look at the dyno's, huge torque at low rpm that then fades off as rpm increases. Nearly opposite of how turbo engines used to develop power. Having even more at that low of an rpm makes it harder to get a great launch, as it just ends up in wheel spin. Having the power increase above stock as rpm rises, imo, should give easier launch will better power modulation at higher revs. You may find you do like it if you get that tune. |
07-14-2012, 10:36 PM | #53 | ||
Rep 665
07-19-2012, 11:36 AM | #54 | |
Rep 821
- remove the TOP speed limiter - add Summer tires That's it. So, there *shouldn't* (IMHO) be any real technical limitation to the PPK, rather a recommendation from BMW due to the higher capable speeds. I believe some folks had the e90 ppk installed without the 840 option (I also think 840 on an e90 added the extra oil cooler - correct me if I'm wrong). In any case, we won't know until it's released. I know they said December, but my sources say don't bet on it until next year. |
07-21-2012, 01:06 PM | #55 |
Rep 28
It looks great but I have always been skeptical about these sort of devices. Have a lot of you guys install them? Do they void the warranties? Can it really mess the car up?
07-21-2012, 11:30 PM | #56 |
Rep 665
Bad tune can blow a motor (very rare), or be blamed for other engine/drivetrain problems by your dealer and then denied warranty coverage. It's a risk; many uninstall tunes when taking it in, some don't care. Every dealer is different with how they handle it.
07-25-2012, 01:36 PM | #58 |
770
Rep 7,108
Just learned that the 70% throttle only applies to diesel engines. Full power is available after 1500 rpm. Just spoke with turner and they are changing it on the site. I'm going to test this and burgers.
07-25-2012, 02:07 PM | #59 |
Rep 821
07-25-2012, 05:21 PM | #60 |
770
Rep 7,108
Will do
07-25-2012, 10:41 PM | #62 |
770
Rep 7,108
07-28-2012, 08:00 AM | #64 |
Rep 6
I am just coming out of a Porsche Turbo. There are a significant number of ECU Flashes that range in price from $700 - $2,000. The price variation is largely based on upgradibility (stage 1, 2, 3) and customization but on the low end you can get 70HP for $700 which is a great HP / $ price.
As far as I know, there are not any pig tail options. I am wondering if the limited amount of tuning options for the BMW is specific to the fact that turbo engines are so new to BMW and if we can expect to see some of the major tuners focusing on BMW based on the proliferation of Turbo engines in the BMW lineup ... |
07-29-2012, 08:32 AM | #65 | |
Rep 821
Cobb, Procede, Dinan, Hartge, BMS, Giac, and BMW PPK not enough for you? The F30 chassis doesn't have a lot because BMW altered the DME on the N55 engine this year. If you owned an E90, there would probably be more tunes than your Porsche. The F30 landed earlier this year. In that short time Hartge was released, JB is beta, PPK was announced, and others have stated they are working on it. Patience young Padawan... Last edited by bananachipz; 07-29-2012 at 08:38 AM.. |
07-29-2012, 09:00 AM | #66 | |
Rep 6
