BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Problems with running too much E85 recently
proTUNING Freaks
      04-08-2014, 03:35 PM   #23
RollingLower42
RollingLower42's Avatar
71
Drives: 2012 BMW 335I
Originally Posted by oceanview View Post
The main issue is behind the steering wheel.
Using gasoline the care is not made for?
Obviously you are one of these BMW "Purists" right? Leave the car stock and the way it is. We get it. There are people that like to keep their car stock, their are people that like to slightly mod their cars, and their are people who like to just go balls out crazy and mod the shit out of it. We all are different, and we all get that. You sound like a old record player stuck on repeat though. Your interpretation is one sided and the only way. Anything else not in the manual, seems to bug you. It is obvious the car originally is not made to take E85. But do your homework on people who mod their cars and run tunes like BMS, and with the right upgrades (downpipe, tune, flex fuel wires) , yes you can run a certain amount of E85. And obviously their are lots of people who have and do run this set up. Did i perhaps get a little carried away and put too much in? It seems like it. But that's what I find fun and interesting about this hobby, I am not trying to kill my car or dick some future owner down the road like you assume, I am just trying to see what works and what doesn't. I highly doubt I want to trade my car in after all the $, and time I have spent on it. I love it and it's my baby. So regardless of if you think I am right or not, or what the BMW manual is going to say in fine print set in stone, I am going to do what I want and hope that in the end, my car runs hard and looks sexy while doing it. We get it says in the manual "No E85". We also were told not to think "outside the box" and to conform to all rules and regulations all the time in life, and I am sure you abide by everything as the rules state to the T, in all aspects of your life right? Whether you agree with it or not, I am sure you are absolutely perfect and righteous in everything you do.
2012 BMW 335I F30-- KWV2, VOLK TTA-TE37, HANKOOK V12'S, MEISTERSCHAFT SUPER GT RACING EXHAUST, JB4 STAGE 2 MAP 2, CHALLENGE HFC DOWNPIPE, M-PERF SIDE SKIRTS, M-PERF REAR BUMPER, CUSTOM LTMW F30/F12 FRONT BUMPER (THANKS LONG!!), HID FOG LIGHTS, MATTE BLACK GRILLE, UNDERGROUND EURO WHITE SIDE BULBS, GLOSS VINYL ROOF WRAP AND WINDOW TRIM, CUSTOM STRUT BAR
      04-09-2014, 09:35 AM   #24
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
On one side, you put money in upgrades and on the other side, you use a gasoline mixture which is known to damage engines not made for E85. Why?
If you mix down E85 than that's a different Story. 10% or 85% of Bioeth. is a difference. And E10 is supported for this Engine.
(I don't know about the US, but over here in Europe E85 is seen as an engine killer if the car is not clearly made for use with E85.)
But, freedom of choice, sure.
Well anyhow, I hope your car is coming back to life.
      04-09-2014, 10:01 AM   #25
bmwperson
Drives: 4wheels
Engine killer? eh my buddy has probably 100k on e85 (700whp e36), we have opened up the motor a handful of times and it always looked great. No ridges on top of the cylinder, no carbon buildup, no issues. Everything looked spotless.
E85 has a much higher octane rating, coupled with cooling properties makes it a very boost friendly fuel at a fraction of the price of C16/racegas and without having to deal with LEAD...
The idea that E85 somehow will kill the engine is funny in general, E85 shouldn't even touch anything past the piston rings and valve stems. Piston rings are lubricated by squirts(haha) which mist the bottom of the piston(mostly for cooling) and valve stems guides are brass/bronze. We have a bunch of E85 cars around Chicago, I have never seen any excessive wear attributed to E85.
While the durability of the fuel system might suffer due to the components not being rated for E85, it's a gradual process and as such you should consider the price of replacements as part of high HP maintenance.
Like with everything, some people prefer a unmodified, reliable car that is serviced at bmw and some sacrifice some of it to have more fun with it. To each it's own.
... so is it fixed yet?
1997 BMW M3 Single turbo 723whp GT42R
2000 BMW M5 - Daily
2014 BMW 335i xDrive 6spd loaded
      04-09-2014, 02:44 PM   #26
RollingLower42
71
Perhaps E85 is different from the US and Europe? I am not sure but possibly, and I am guessing European BMWs' are slightly different from the US? Considering E10 is supported in Europe, and I have never heard of that in the US?
Anyways, car is somewhat coming back to life.
I checked for fun my engine oil levels yesterday and I did have to add 1 quart of oil.. I wonder if that had anything to do with it at all or not.
Thanks for the well wishes, and my apologies for calling you a jackass earlier on
      04-09-2014, 02:50 PM   #27
RollingLower42
71
Not fixed yet, still having problems. Turned car on last night in the evening after I was home for work. Started up and seemed to idle fine at first, but then went into limp mode again. I did have to add 1 quart of oil like stated above, I pulled the codes, cleared them, added in the oil and drove it around a little. No codes after that, but I am guessing if I go after work again today and try, it will probably do the same thing. I will keep you updated later on..
Codes I got yesterday were: (still don't know what the other codes were from earlier)
140010
140310
14016C
1401AA
      04-09-2014, 02:52 PM   #28
RollingLower42
71
And Justin thought it could have something to do with the wiring or I have loose wiring somewhere. It is a possibility I might have to look into soon. More than likely will eventually have to get it towed somewhere
      04-09-2014, 03:20 PM   #29
oceanview
oceanview's Avatar
Switzerland
207
I'm quite sure the N55B30 is the same. Power and Torque are the same numbers as in Europe (as written in that manual).
The support for E10 on your car is also written on page 262 in the Owner's Manual
(Sorry can't coppy/paste the text and put it here, as the PDF is protected)
Just read below the titel:
Use high-quality brands
Sure accept your apologies, thanks, no problem.
      04-09-2014, 03:26 PM   #30
olehead
Drives: 2018 M240I X drive
Very interesting posts - concerning mods etc - I mod to race period - If I was not into 1/4 mile drag racing the car would stay stock - having said that I am learning a lot about the N55 engine - and it is beast waiting to be released - when the car can turn times like it just did in the 1/4 mile with just a stage 1 - potential is unlimited - I may have to supercharge my Mustang to keep up LOL
      04-09-2014, 04:25 PM   #31
Eric SS
Drives: 2016 Chevy SS Sedan
Bummer you're still having problems. Have you tried removing the JB4 completely or switching to Map 0 or 1 with the E85 wire removed just to try and narrow down the issue?
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone
2018 M4 ZCP: current
2023 X3M Comp: current
      04-21-2014, 04:33 PM   #32
RollingLower42
71
Good news!
Found out the problem was bad spark plugs and bad injectors (all because I used TOO much E85)
That being said, replaced spark plugs and all (6) of my fuel injectors. I am currently on map one and it is running fine.
I was told to run map 2 next and stay off of 7. So once I run this batch of gas all the way down, i will fill all up with 91 and put 2-3 gallons E85, then change to map 2 and see how it does. I should be fine though, I was just advised not to ever put more than 5 gallons of E85 in and that's with a full tank of 91 for the rest. So I think for now on, i will be really moderate and only put 2-3 gallons in, and just be good from that!
I also hear map 5 is in development and it is "Auto tuning map" from my understanding, so I hope to check that map out soon !!!!
Glad it wasn't anything major though and wasn't too much of a hassle at all
      04-21-2014, 05:12 PM   #33
Alpine435i
Drives: 435i
Wow that looks great. Proper wheels.
Is your car wrapped matte white or am I just seeing it that way?
      04-21-2014, 05:38 PM   #34
bmwperson
Drives: 4wheels
Good news, any chance you could take pictures of the injectors? what failed on them?
2000 BMW M5 - Daily
      04-21-2014, 05:43 PM   #35
Bowser330
Drives: i3 REX
Good news!
Found out the problem through BMW was bad spark plugs and bad injectors (all because I used TOO much E85)
Where did you go to take care of that work? BMW dealership? Indy shop?
If BMW, did they do the work under warranty? How did you explain the extra ethanol in the tank? Did they hassle you about that?
If indy shop, which shop?
      04-21-2014, 06:20 PM   #36
JN1
JN1's Avatar
301
Drives: S211 AMG E63
His car is just stock AW, the matte black grills and gloss dark wheels make the paint look more matte in pics.
-JustinNApproved
      04-21-2014, 06:58 PM   #37
RollingLower42
71
Thanks, wheels look great too IMO. Just white paint job, no flat white
      04-21-2014, 06:59 PM   #38
RollingLower42
71
It was my buddy's Indy shop. Pm me if you want the name
      04-21-2014, 07:00 PM   #39
RollingLower42
71
I can try to look and see if I can take a picture of them. Not sure what failed but it was definitely bc I put way too much e85 in, like 10-11 gallons I'm guessing. So considering you shouldn't go over 5, I guess that's what explains it
      04-22-2014, 07:28 AM   #40
avantix
avantix's Avatar
Drives: 2019 M4CS Lime Rock Grey
I recommended you change the spark plugs. Never thought the injectors would foul too. Wow. Glad you got it sorted out mate.
2019 M4CS Lime Rock Grey, MP HAS, GC camber plates, MPE
      04-24-2014, 05:48 PM   #41
RollingLower42
71
Yes good recommendation, and thanks. I read somewhere that once you hit 40K miles you should replace the spark plugs and clean your injectors.
I was at 40,200 or so, so maybe that also had a role to play in that debacle that is no more .
