12-16-2020, 12:10 PM | #67 |
Rep 108
So, are we back to the starting point for X-drive? Nothing available (except the pricey carrier for camber correction)??
Powerflex and SuperPro bushings discontinued. Kmac bushing questinable product. Motorsport LCA not possible - wouldn't pass the annual inspection... |
12-16-2020, 01:16 PM | #68 | |
Rep 3,540
My KMAC bushings performed well for ~25k mi with the only issue being the poly urethane creaking noise when the grease dried out. Saw lots of track days, and dirt/gravel roads at speed. The PU was still tight/non-deformed, and the interface between the outer bite washers PU heads, and cylinder and PU inner were all clean/dirt free. The only thing I can think of why mine were solid and others may have failed are because I specifically shaved down the head of the PU parts with my dremel so the end cap/bite washers would fit perfectly on them and flush with the main cylinder (I had to do this since I got a beta part). This removed all slop and made things fit naturally with each other.
12-16-2020, 01:24 PM | #69 |
Rep 143
Farkle is KMac camber bushing still an option for XDrive camber adjustment (looking for something at -2 degree with 1 inch drop on KW) or better start with camber plate? Thrust arm / caster adjustment a must for upto -2 degree?
12-16-2020, 05:03 PM | #70 |
Rep 3,540
Depends on which noise you want to put up with. The camber plate will have more general noise (and slight tapping noise on high compression if you listen closely), whereas the kmac bushings will make creaking noises after the grease has dried only heard at crawling speeds when turning the wheels a lot).
06-15-2022, 06:50 PM | #71 | ||
Rep 7
What can be done? Move Lower arms? Got a problem with different cambers on front wheels and would like to know how can I try to do. Thanks! |
04-07-2023, 02:03 PM | #72 |
Rep 383
Adding some recent info here, to keep it all together. Will add more once install is done.
So I received a pair of the camber bushings recently and will be installing this weekend. The first thing I noticed was the fitment of the outer “washers” doesn’t seem to have been fixed as Farkle thought in his video. You can see in the images that the profile of the bushing vs the profile of the washer doesn’t match. This causes the washers to contact the corners of the bushing, and keeps them from laying flush with the inner cylinder. I used some white paint to visualize where they contact (2nd image). It sounds like Farkle ground the top of the bushing down. I am currently planning to try just adding a chamfer to the corner of the bushing to get them to fit correctly. |
04-07-2023, 08:29 PM | #73 | |
Rep 3,540
04-08-2023, 10:18 AM | #74 |
Rep 383
Interesting.
When I test fit the washers stick out about a mm or so each side. I do plant to try fitting first without modifying it to see how it goes. Part of me wonders if it’s intended to be a tight fit, and compressing the bushing some. |
casualDIYer446.00 |
04-09-2023, 08:46 PM | #75 |
Rep 1,372
I just ordered a set of these as well. Keenly interested in how SuperLomi's install goes.
04-13-2023, 09:00 AM | #77 |
Rep 65
Is this the correct PN for xDrive - https://k-mac-camber-kits.com/produc...inc-193616-8h/ ?
How much camber can I get if HR sport spring are installed? What (driving experience) can be achieved if combined with the caster ones too https://k-mac-camber-kits.com/produc...ive-193916-7j/ ? Thanks |
04-15-2023, 11:08 AM | #78 |
Rep 383
Well, got these installed last night, and what a doosie it was. I'll post pictures later, just taking a break from working on the alignment right now.
I did all the work without removing the LCA from the wheel hub. First of all: I did have to shave down the corners of the bushing to get them to fit. I probably could have went a bit more aggressive, but after a few test fits I got something that works. I uses an orbital sander mounted in my bench vise to do the work. Second: The metal bushing is sharp, and I did accidentally "shave" slightly a small portion of the inside of one of the bushing caps. We'll see if it causes an issue long term, but I installed it as is. I did this while dry fitting ahead of time. Third: The pressing cup provided alone was not sufficient. I've seen a few post where people said it didn't come with a "pusher" and that was the case for me - not sure if it's intended to for this kit. Just the cup and a large nut. I attempted to use this alone first, but it ultimately sheared the rubber in the bushing before it moved the bushing itself. I ended up using a 1 1/8" socket as a pusher and it worked well enough. Fourth: Installing the caps was fairly difficult. I ended up using a ball joint press and another large socket I had to press everything together the final 1/4" or so. Firth: minor, but the tie rod boots got in the way of installing the bolt in the same orientation as OEM (bolt head to the front) since it's a bit longer, so I installed the other way around. Shouldn't make any difference, really. Sixth: I saw this mentioned in the 2-series forum as well: there's a small lip on the inside of the subframe underneath where the LCA bushing is. In certain positions the end washer's will contact this lip. This may prevent the bushing from achieving the full range of adjustment, but not by much. The instructions also say to install with the bolt hole in the 12 o'clock position. This position caused an interference with the lip. I found installing the the 4-6 o'clock position to be ideal (if looking towards the front of the car). Image 1 shows the corner shave. I did end up rounding it over a bit more than what you see here. Image 2 shows the carnage from trying to use the pressing cup as is. Last edited by SuperLomi; 04-16-2023 at 06:19 AM.. |
casualDIYer446.00 |
04-15-2023, 05:35 PM | #79 |
Rep 65
Is there a different load on the xdrive front axle while doing the same negative camber by camber plates or by KMAC inner arm bushings? Meaning if the -2° camber achieved by the camber plates was OK(ie tested by driving) would be also OK the -2° camber done through the inner bushing?
04-17-2023, 03:51 PM | #80 | |
Rep 1,372
04-17-2023, 07:47 PM | #81 | |
Rep 383
I personally didn’t bother with it, as I may be making more alignment adjustments as I dial things in. One thing I’ll add: I got these because I need to meet classing rules for the SCCA. You can either have camber plates and bushings OR adjustable arms. If you don’t have this restriction I would recommend getting adjustable arms instead of these bushings. A little pricier, but probably a better solution in the long run. Last edited by SuperLomi; 04-17-2023 at 07:57 PM.. |
04-24-2023, 01:03 PM | #82 | |
Rep 1,372
X-Drive - A technology developed hand in hand with Global Warming? Well, might be a coincidence . . . maybe . . .
04-24-2023, 03:02 PM | #83 | |
Rep 383
05-21-2023, 04:49 PM | #84 | |
Rep 2
Millway Street
J'ai lu attentivement le post sur l'installation des bras M3... Je vis en France, et je les ai installés sur ma BMW 340i... mais comme vous l'avez dit, ça touche... quand je traverse des ralentisseurs... J'ai lu que vous aviez enfin installé des amortisseurs Millway dans la version Street... Pouvez-vous me faire part de vos commentaires à ce sujet ? Je crains que cette installation ne fasse trop de bruit lors des voyages en famille... Est-ce supportable ? Quels sont les inconvénients ? L'essieu avant est-il bon avec cette modification ? Je suis très satisfait de la modification avec les bras M3, mais cela apporte quelques inconvénients comme lorsqu'il frotte. J'attends vos commentaires avec impatience. Merci pour vos commentaires. Pierre |
08-11-2023, 01:14 PM | #85 |
Rep 465
Has anyone installed the rear bushings on a X-drive? I’m sitting pretty low on KW coilovers and my rear tires are getting too much inner wear, hoping these can help with that problem. Anyone have any experience with that?
04-14-2024, 11:29 PM | #86 |
Rep 1,372
Well, despite having received my camber bushings in September, winter showed up and enthusiasm for extra camber took a dive. So, with the first track day a mere month away, I finally installed them in April.
I like 'em. You would think a camber bushing is going to be easier than a camber plate but that was not my experience.The bushing was somewhat of a pain in the a$$ to first get installed, then adjust. But once in, i found there was not a significant change in noise and vibration. The downside of camber plates is, compared with the OE part, they often have insufficient vibration absorption. I used Millway camber plates and while they were among one of the better camber plate options, especially for the street, they did fall short on vibration damping compared with BMW's top hat. Swapping out the BMW control arm bushing with the K-Mac bushing did have a mild effect but given how small the bushing is, especially when compared to the thrust arm bushing, the change is minor. The shop struggled but I was able to get 2.0 of camber out of the bushings left and right. Yes, a little more is helpful and I believe I got 2.1~2.2 out of the Millway plates. And the plates were more convenient. But until the NVH issue is worked out on aftermarket camber plates, I may stick with the bushings for now.
Jvac435.00 |
