03-01-2013, 09:28 PM | #1 |
Rep 169
Sport Seats Issue
I am very happy with my 2013 335i M Sport but have a strange problem with the sport seats. When I drive the car for more than 1 hour, I start to have a throbbing pain in my right hip, never had this happen before. If I drive a different car, no problems. I have tried many different seat positions to no avail. I think it could have something to do with the angle of the gas pedal, not sure. After 2 hours it gets really very painful and if I walk around for a few minutes it goes away. Would like to know if anyone else has this problem or an idea what is causing this. Thanks
03-01-2013, 11:30 PM | #5 |
Rep 361
If you're new to BMW sport seats, you'll learn that finding the right settings is a bit of trial and error. Compared to most car seats that, IMO, follow the 80/20 rule and offer a few adjustments, these seats are far more adjustable. Get it wrong, and they will hurt you. But when you get it right, you'll be able to go on very long drives and not suffer the aches and pains / fatigue you'll get from more standard seats.
Play with different combinations of side bolstering, seat angle, bottom cushion adjustment, and lumbar support. You'll find the right setting eventually and when you do, you'll appreciate what you have and sitting in regular car seats will never feel right. BTW, it took me about 6-8 months to really dial it in.
03-02-2013, 03:14 AM | #6 |
Rep 2
I too tend to feel this same style pinching annoying feel in the sport seats in my 335is.moving from a 5 series I thought I was just in a smaller seat but.im glad.to hear someone else has the same.issue.I have 2k miles on the car so far Im hoping I just need.to break them in/find the right position.
03-02-2013, 04:47 AM | #7 |
Rep 4,323
DVT?
03-02-2013, 12:24 PM | #8 |
Too much is never enough
655
Rep 3,079
Fat wallet in your back pocket? This is the root cause of discomfort in many cases but is overlooked. You may also be correct in that it might be related to pedal position. Try raising the entire seat and tilting the seat base rearward slightly so you have more support under your thighs.
03-02-2013, 12:31 PM | #9 |
Rep 426
I am not even joking when I say this but personally I weight about 180. When I fluctuate by as little as 5 pounds more, I get the absolutely most sore lower back and right hip but when I am back to 180 the same seat position is perfect. So I know you said other seats don't bother you but the bmw sport seats are decently deep bucket which puts a bit more pressure on your sacral area and any extra weight there can actually place that much more strain on that hip area.
I use it as a motivation to stay at my ideal weight! lol |
03-02-2013, 12:34 PM | #10 |
Rep 1,180
How true !!! For all but the shortest drives, it's a good idea to carry your wallet in a front pocket rather than a rear pocket, so one's hip is not displaced.
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
03-02-2013, 01:27 PM | #11 | |
Rep 1,111
Hope the 335i isn't like that or ED will be a struggle. |
03-02-2013, 01:32 PM | #12 |
Rep 169
I thank you all for your responses and taking this seriously. Here's some more information to try to resolve this. No wallet in back pocket. For the past 30 years I have owned only Volvos and never had this issue. My last Volvo was a V70R I drove for 9 years, greatest seats ever. All my cars have had manual 6 speeds and this is my first BMW. I have tried every adjustment on the seat. I even tried sitting on my Airhawk seat pad that I use on my Yamaha FJR motorcycle that I rode for 62,000 miles. If that didn't bring out a hip or back problem, nothing will. I am in good shape, but a little chunky, 235 lbs 5ft 9 in. The pain first starts in my right cheek (hip) then as time goes on radiates down my right leg to my knee, it throbs, after 2 hours I have stop, get out and walk around, pain goes away. I look at my georgous car and just can say WTF. Help!!
03-02-2013, 02:34 PM | #13 | |
Rep 219
2013 335i M Sport- EBII / BLACK / Dk Walnut /Packages- Prem / DHP / Tech / Driver Assist / DA Plus Options- 8 Sprt AT / Htd FS / HK / Hi Bm Asst /403 19" w/perf tyres Ordered: 12/15/12, ED Delivery Date: 04/23/13 |
03-02-2013, 03:25 PM | #14 |
Rep 5,660
It could just be the design of the BMW seat is highlighting something physiological that's been there. If you have your M.D. check it out and he finds nothing, would say it's the way the seat is adjusted.
One thing I'm pretty sure about is that if there's nothing wrong in your hip, there's going to be some position that you'll eventually be able to find that's comfortable. Good luck and here's hoping it's the seat adjustment and not something physiological.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
03-02-2013, 07:38 PM | #15 | |
Rep 1,180
The good news in your case is that the pain eventually goes away and you do not have to use painkilling drugs 24/7. I think you should continue to experiment with different seat positions. If that does not bring relief, you might also consider consulting your physician and/or chiropractor.
03-02-2013, 09:12 PM | #16 | |
Rep 219
03-02-2013, 10:06 PM | #18 | |
Just Copacetic!
177
Rep 616
http://www.amazon.com/Forme-Ultra-Er...edic+back+rest I have the regular seats on my F30 and E53 and don't have any problems, only on the E46 sport seats. Sounds like what you're experiencing is a pinched sciatic nerve. Best wishes in your search for a remedy! |
03-03-2013, 07:56 PM | #19 | |
Rep 176
cheers vern |
03-03-2013, 08:48 PM | #20 |
Rep 4,323
I think you might need to do some yoga and sit ups-I have a feeling at your weight and height, don't take this the wrong way, the sport seats are highlighting poor core strength.
04-14-2014, 08:41 AM | #21 |
Rep 70
Drives: 340i
I have the same issue with my e92 335i and also my e46 330ci. My lower back screams in pain after more than 5 min in the car. The only other brand to do this to my back has been Honda.
The solution for me was to remove the back cover of the drivers seat and pull the lower horizontal spring away from the seat cusion. I held the spring against the frame of the seat with zip ties. This allows the lower seat cushion to flatten much more than just deflating the lumbar. It worked great in the e46 and eliminated my pain, but only helped for a few months in the e92. Now my back is killing me again and I'm trying to find another solution. |
04-14-2014, 09:00 AM | #22 | |
Rep 704
Drives: 2014 328d
2014 328d SportLine
