10-01-2014, 12:36 AM | #1 |
Rep 463
I hate trees
The amount of tree sap drops I have on my car are uncountable. How the hell do I get them off without having to scrap it off real hard with my fingernail!?
10-01-2014, 02:56 AM | #2 |
Rep 441
Don't park under trees?
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
10-01-2014, 04:49 AM | #3 |
Super Spectacular Awesome Dude
69
Rep 577
As I recall, BMW sells tree sap remover in their service/parts dept. I'm sure there's a 3rd party one as well.
Maybe wax your car so it comes off more easily? |
10-01-2014, 08:03 AM | #4 |
Rep 45
Drives: 2013 328i, 2014 328i
My experience is:
a. In my neighborhood it isn't really tree sap, actually insect poop from bugs that are eating the tree leaves b. Comes off relatively easily with soap and water. I think the stuff is pretty water-soluble. The only moderately difficult part is getting the goo off the windshield wipers. If what you have is actually tree sap, a non-polar solvent should take it off. I'd use either mineral spirits (first choice) or denatured alcohol. Either solvent will likely take off any car wax along with the sap, but won't harm paint. I like to use a professional paint cleaner like PPG Acryli-Clean (DX-330), available at automotive paint suppliers. AcryliClean will clean off everything on the paint surface, including any silicone agents, tar, tree sap, and I have never had it damage cured paint. I would not use it on fresh lacquer. |
10-01-2014, 08:13 AM | #5 |
Rep 516
Mineral spirits is going to take whatever wax or sealant on the paint right off.
But yeah, parking under trees is a sure way to beat up your paint. |
10-01-2014, 08:31 AM | #6 |
Rep 4,981
Drop of optimum no rinse?
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
10-01-2014, 09:01 AM | #7 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
Put really hot water on a paper towel and throw it on top of the spot for a good 10 minutes to soften. Usually wipes right off if you have been a good boy or girl with waxing your car
10-01-2014, 09:23 AM | #8 |
Rep 5,316
Drives: G80 M3 6MT
I used to have my car covered in what looked like sap but and I couldn't even scrape it off with my fingernail but it always washed completely away whenever I washed my car.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
10-01-2014, 09:30 AM | #10 |
Rep 74
This stuff will take it off with ease and also get rid of any tar spots:
http://www.polishedbliss.co.uk/acata...rdis-cat6.html But this will also strip any protection off the car so you will have to re-apply a wax or some form of protection. |
10-01-2014, 09:34 AM | #11 |
Rep 241
This stuff has worked wonders for me. Spray it directly on the sap and then wait about 60 seconds. Take a wet rag and it comes right off. This stuff is thick too so it won't run onto other spots it will stay right on the sap.
http://www.amazon.com/Turtle-Wax-T-5...e+wax+tree+sap Walmart has it too. |
10-01-2014, 11:13 AM | #12 |
Too much is never enough
655
Rep 3,079
Don't use clay bar to try to remove sap. Sheesh.
Buy some sap remover. Done. Though it's just mineral spirits with a little polish mixed in. This is assuming it's actually sap and not something else... |
10-01-2014, 11:20 AM | #14 | |
Rep 1,267
10-01-2014, 11:22 AM | #15 |
Rep 1,267
Would mineral spirit not soften the clear coat even just temporarily? Especially if BMW uses a waterborne clear coat.
10-01-2014, 11:25 AM | #16 |
Rep 463
There are two things I find- sticky residue like a sticker was taken off. And little dark orange drops. (Like dried drops of super glue) I need to scrap those off with my finger. But the residue is horrible. Doesn't come off no matter what
10-01-2014, 11:26 AM | #17 |
655
Rep 3,079
No. Once it's cured you'll have no issues. Also, bear in mind you don't "soak" it on the paint. You apply it to a cloth and wipe the sap. A couple of passes will take it right off. The key to dealing with sap is getting it off as quickly as possible before it has a chance to harden or bake on. Then mechanical means might be needed to get the bulk of it off.
10-06-2014, 08:50 AM | #19 |
Rep 205
Drives: 2014 335xi MSport
Yes, IPA is the trick detailers use to remove sap.
Regular strength stuff from the drug store, dont even need the 90%+ stuff. But it does indeed remove your wax so you must wax or seal afterwards. Dont scrub with it though, simply dab with a soft cloth. But the best thing to do is put a good sealant and wax on your car if you cant avoid the trees. Then most sap will just wash off after you let the soap sit for a minute. (unless its globs)
2014 335i xdrive MSport AW/CR, SAT, Prem, Tech, HK, DHP, MPPK, MPE, NWA, KMFDM, etc... |
12-02-2014, 09:26 PM | #20 |
Rep 1,374
Drives: Audi R8 v10 Spyder
Just use WD-40, spray on to the tree sap and leave it to soak for about 5-10 mins then wipe off with a towelette. Spent hrs scratching it off before I realised this from their site.
